Question about ATI RADEON X1650 Graphic Card
I have a 915pl7ae-8s foxconn motherboard and i am trying to put a ati x1650 agp video card in it and when i start up the screen dont turn on and the board beeps two time real quick. and i have put my test card which is a gefore mx440 and it works fine.
  • 1,602 Answers
The 2 beeps is parity error or parity curciut failure
the device is not getting pluged in right, the connector are dirty, the slots in the motherboard are dirty,
the first 64kb is the problem,
if the chips on the board can be removed than remove the chip and re install them, same on the motherboard if you have that option,
clean the leads on the video card with a #2 pencil eraser
clean the eriaser with a lint free towel or rag.
blow some air threw the card slots where you plug the cards into
Posted on Feb 27, 2009
So I'm trying to install a ATI Radeon X1650 Pro AGP card, I've seen where other people have tried and got the same results as me, but my question is, I've got 2 gigs of ram on a ADM Athalon 2400 Is this...
Firstly you must make sure your motherboard actually has an AGP slot. The newer ones have PCI-Express instead and you can't plug it in and there are no converters.
Yes, the card will work with that CPU and RAM. Everything depends on the motherboard, but if it's AGP and can do AGP x8 then all's well.
Make sure if the card requires extra power that your power supply can power it (for example if the power supply has the correct connector for the graphics card, and if it has the necesarry power to power it). Since it's not a high end card it probably doesn't even have the power connector in which case it's low power and it should work on pretty much any power supply over 350W.
You ask if that's enough; enough for what? A particular game or software? It'll run ok on older games, but newer ones like Call of Duty 4 should work but on very low settings. I'm not sure if your cpu can take that game tough, but the graphcis card can and the ram is enough.
Dec 01, 2009 | ATI RADEON X1650 Graphic Card
I have Windows 7 RC (patches etc. up to date) with
You could try this link, but with all Beta software nothing is guaranteed until the approved verisons are released.
http://drivers.softpedia.com/get/GRAPHICS-BOARD/ATI/ATI-Catalyst-64-bit-Driver-Beta-for-Windows-7.shtml
Not put down your video card though x1650 is not a "screamer" in todays standards, I'm running a 3870OC myself because it was cheaper than to buy the latest and greatest. I believe you are limited by your motherboard only having AGP? Take a look at this link:
http://www.ewiz.com/detail.php?p=AS-345AG51&c=pw
http://www.buy.com/prod/visiontek-radeon-hd-3650-agp-512mb-ddr2-128-bit-directx-10-1-video-card/q/loc/101/211110588.html
http://www.ewiz.com/detail.php?p=AT-3850AGP&c=pw
You would be able to retain the already installed drivers. It all depends on your budget. On another note try lowering your colors and changing the monitors frequency. I hope this helps.
Jun 24, 2009 | ATI RADEON X1650 Graphic Card
I installed the ATI x1650 but the monitor is blank when I turn on
Yes the card does support the screen. If you have blank screen right from turn on, chack that you have not plugged the monitor into the onboard graphics port instead of your Radeon. If you have plugged it into the right port then you have hardware problems. Could be any of the following:
1. Monitior
2. Video Card
3. System memory
4. Motherboard
5. Powersupply
6. CPU
Try a different monitor and get back to me if you want troubleshooting tips.
Cheers
May 09, 2009 | ATI RADEON X1650 Graphic Card
NO VIDEO FEED
just connect to your built in video card first , go to the bios next and disable the built in video card, F10 to save your settings , restart your PC. and connect to your geforece.
try it out.
Mar 24, 2009 | Foxconn 915PL7AE-8S Motherboard
ATI x1650 Pro Stops!?
For this card they recomment at leat a power supply rating of 450 watts. If you have lower than this then I would suggest upgrading the power supply. A 550 watt psu is reasonably priced and should give you plenty of power for future use. Hope this helps.
Oct 17, 2008 | ATI RADEON X1650 Graphic Card
Graphics cards
Hi noxiney, you're MSI motherboard does have 1 opened AGP 8x4x slot. You can install & run the ATI Radeon X1650 PRO AGP. You can not run PCI-Express because there are no PCI-E slots on the board. There are PCI (White in color) on the board but the AGP slot is much faster than the PCI (White in color slots). The manual states the AGP card can only support 1.5volt video cards & not 3.3volt AGP cards. (Keep this in mind when looking for an AGP card).
Below is a link to a bunch of AGP 8x4x video cards. One or two include DDR2 memory. Carefull where you buy. Check the warranty. (Longer is better). The first one on the list would be compatible. Its not DDR2 but it does have 512MB of memory.
http://www.google.com/products?hl=en&q=AGP+ATI+Radeon+X1650+PRO&um=1&ie=UTF-8&sa=X&oi=product_result_group&resnum=1&ct=title
This card is 1.5v compatable.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3101648&CatId=318
& this is compatable.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1642902&CatId=318
Just remember, if the card can run both 8x & 4x it should support the 1.5volt needed to function on the MB.
Enjoy!
Mike
Jul 08, 2008 | MSI PM8M-V Motherboard
AGP 8x not supported
Just a thought, but have you tried going into the bios setup and setting bios to system defaults or safe setting, saving and rebooting?
Dec 25, 2007 | ASUS P4S800D-X Motherboard
Video card troubles
Hi, with my own Foxconn mobo [661FX7MI] I had to run the installation disk that came with the motherboard and reinstall the AGP driver. Then run the AGP card driver [ATI]  disk.
Regards mistyman
Oct 20, 2007 | Foxconn 760GXK8MC-RS Motherboard
ATI RADEON X1650 Pro, AGP Graphic Card 512MB compatibility
Maybe this post is a bit old, but on last deceber I bought an AGP 512MB ATI Radeon X1650 PRO for my Foxconn motherboard and I must say that it's simply awesome!
I can play most games on mid-high settings on reasonable resolutions (most on 1024x768) with good FPS (except with Crysis... but let's face it, did Crytek bought a time machine to warp a 2010 game??).
So, if you already have it, then congratulations, and if you still are thinking on buying it, then what are you waiting for!?
Also, it's AGP x8, if your motherboard support x8, then it should run perfectly fine.
Also, I have a bit of problems trying to run Prey on the X1650...
It always appears an error... it's not of much importance, as I have much better games, but I haven't tried it with high fancy graphics... :P
Oct 13, 2007 | ATI RADEON X1650 Graphic Card
Does my (this) mother support agp ddr2?
MOTHERBOARDS Hi there, does my motherboard support video cards like ATI RADEON X1650 512MB AGP? ---YES, When you installing AGP card, please make sure the following notice is fully understood and practiced. If your AGP card has "AGP 4X/8X (1.5V) notch"(show below), please make sure your AGP card is AGP 4X/8X (1.5V). Caution: AGP 2X card is not supported by Intel® 845(GE/PE) / 845(G) / 850(E) / E7205 / 865(G/PE/P) / 875P. You might experience system unable to boot up normally. Please insert an AGP 4X/8X card. Does it support ddr2 or ddr3 memmory for the agp? ---YES, see the above notes can the agp memmory be over 512 mb? ---YES, see the above notes More more information go here >>> http://asia.giga-byte.com/FileList/Manual/motherboard_manual_8ipe1000g_e.pdf Hope This Helps =============================================== If you are having trouble with a Newly bought items then return them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 19, 2007 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
ATI RADEON X1650 Graphic Card Logo
90 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
