Question about Sanyo PLC XU35 Multimedia Projector
SANYO PRO XTRA X MUTLIVERSE PROJECTOR SHOWS FILTER FAULT
YELLOW LIGHT ON START UP AND YELLOW MESSAGE ON PROJECTION SREEN
    Problem Solver:
  • 14 Answers
Clean filter
Posted on Aug 13, 2009
Sanyo pro xtrax projector
Lamp LED should be lit when the projector is in Standby. However, the problem you are describing sounds like one of two issues. Either the lamp is bad and needs replaced, or there is a power supply fault. If you have tried replacing the lamp already, make sure you reset the lamp counter or the projector may still not function properly.
does the temp warning light come on when the projector shuts off? if so you may also try cleaning the air vent filters and ensure there is proper air flow around the projector. if that checks out then have the projector serviced as the power supply is likely suspect.
Dec 09, 2013 | Sanyo Office Equipment & Supplies
Picture dull colours incorrect on sanyo pro xtra x projector
reset to factory default settings (from the menu). after that if it's not where you want them, you can go into the menu and set them to where you like them.
Aug 04, 2009 | Sanyo PLC XU35 Multimedia Projector
Projection issue
sounds like you might need to change the KEYSTONE settings
Nov 14, 2008 | Sanyo PLC XU35 Multimedia Projector
2 projectors that have blown their lamps
My guess is with them so high in the air, no one seems to clean the air filter often enough. Also, the projector is at 840 hours which is just a few hundred below the normal lamp expectancy. Also, I would wonder how they are shut down. Do they actually go through their normal shutdown process as requested by the manufacturer, or has someone that programmed the shutdown to just kill the power to the circuit. That would definately be worth checking.
Nov 11, 2008 | Sanyo PLC XU35 Multimedia Projector
Yellowed image projection
The yellow you see is all dust on the mirrrors inside your projector.
If u are lucky you can get the mirrors cleaned by a pro, if you are unlycky as i was, the blue mirror has burn and u need to replace it.
Take your projector to someone who repaire tv:s ot other electronics, they will help you. If its only the cleaning its cheap, if you need to replace a mirror its expensive.
Good luck
Oct 23, 2008 | Sanyo PLC-SW30 Multimedia Projector
Sanyo PRO xtraX Multimedia Projector Mod.# PLC-XP1ONA
this is the normal condition> only when green led is off and warning temp led(yellow) is on something is wrong!!
Jun 08, 2008 | Sanyo PLC XU35 Multimedia Projector
Sanyo PLC-SW30
The filters are starting to show their age. This is a normal occurance for projectors and is the result of heat. The filters and/or the mirrors might need to be changed.
Dan
May 08, 2008 | Sanyo PLC-SW30 Multimedia Projector
Sanyo Pro xtra projector - warning light
We have a similar situation with our Sanyo Pro Xtrax. It will be on for about a hour and then the "warning temp" light would come flashing red, and the project would turn off on its own.
Feb 08, 2008 | Sanyo PLC XU33 Multimedia Projector
Sanyo PLC XU35 Multimedia Projector Logo
1,197 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
