Question about Bosch AquaStar Indoor Natural Gas Tankless Water Heater with Vent Hood #125
Pilot blows out on n.g. tankless water heater when it's windy
It only happens when the wind is really blowing outside. I reach in to relight the pilot and I feel a a lot of draft. It will come on after I relight the pilot but it won't stay on and I watched the pilot while it happens and it looks like the pilot gets sucked out. Once that happens the burner flames go off. Safety precaution because I do smell carbon monoxide when it happens. We thougth we had this well vented but it seems like we need to stop some of the wind from coming down the pipe when it's windy and we are using it. It only happens when it is in use.
  • blueextc3221
    blueextc3221 May 11, 2010
    Carbon Monoxide is odorless. You are smelling unburned Natural gas in the regulator.
    Check that the vent is not CLOGGED (with animal now debris) - so there is a defficiency of fresh air for the pilot.
    As a temporary fix - position a tarp around the vent opening blocking the wind. If this helps, then install a diffuser at the end of the vent pipe that will not allow wind to enter.
Hi. I have a tankless water heater that Bosch says they manufactured. It's point-of-use under the kitchen sink. It services the kitchen sink, dishwasher and the bathroom sink and shower. (We live remotely...6 miles from town). It's a little house. Anyway, the unit was installed in late 2005. It's blown the flex water pipe, now twice - once was this afternoon. What's going on? I was hand washing a few pots, smelled ozone and heard wooshing and hammering noises under the sink. After contacting Bosch's technicians, the water hose to the hot side blew completely off, spraying the kitchen with water. Big mess. I don't know what to do about this, this is the second time it's happened.
Any ideas? (By-the-way, Bosch said it was installed incorrectly because the guy that installed used a pig-tale instead of hard-wiring. It's been working all this time...now I'm afraid to leave it alone).
Posted on Jul 08, 2009
    Novelist:
  • 152 Answers
There are many anti-back-draft systems on the market, but there may be only a few that could possibly be Incorporated in to your application. You might contact the manufacturer for their product list of, flue pipe anti-back-draft devices.
Good luck...
Posted on Feb 23, 2009
Would high winds and rain cause pilot light on a rannai tankless water heater to go out?
Yes.
High winds can cause reversal of air flow down vent pipe causing pilot flame to blow out.
If situation happens frequently, then special roof cap has to be added.
Have plumber check natural draft up vent pipe.
Other things can cause same problem, for example if vent fan is located in same room as water heater, or house is tightly insulated, and vent fan is ON, then it will draw air down the water heater vent and blow out pilot.
http://waterheatertimer.org/pdf/Bosch_Checking_the_draft.pdf
Oct 29, 2012 | Water Heaters
I have a Bosch 10P water heater. Pilot light has blown out and while trying to relight the pilot the stop button has been pushed down and won't pop back out. What am i doing wrong? Cheers
What leads you to suspect that pilot blew out instead of another problem?
Fact that pilot will not relight, indicates other factors at play.
Open following link for Bosch troubleshooting resources including manual, and Bosch contact info:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Best place to start is your manual.
http://waterheatertimer.org/pdf/Bosch_10P-installation.pdf
1) Manual recommends 'cleaning by authorized person, never less than once a year.'
Tankless water heaters, and most newer tank-type gas water heaters, are highly technical and finicky devices that require continual maintenance, with tankless requiring 'yearly' maintenance while tank-type require 'periodic' maintenance.
2) Troubleshoot in manual says 'no gas supply' or 'blocked pilot' replace pilot injector
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 21, 2011 | Bosch & Tankless LP Hot Water Heater
When the wind blows the pilot light out, I have great difficulty in pressing the buttons in to relight it.
You are getting negative pressure in the burner ... this can be caused by the access panel not being reinstalled properly after you relight the pilot. Vents can cause a "venturi effect" and if the access door is not on tight it will indeed become a real pain
Feb 18, 2011 | Bosch & Tankless LP Hot Water Heater
Pilot is not heating thermalcoupler
You may have a dirty pilot orifice. Try this. Turn off the pilot by turning the control knob to off. Remove the front panel to get access to the pilot orifice. Use a can of compressed air with attached straw (the same stuff you use to clean computer keyboards) and blow out the pilot orifice, which is inside the pilot assembly where the pilot flame burns. Blow it out from the top and from the sides through the air holes. Then relight the pilot and see if that improves the flame size and color (blue) to heat the thermocouple. Douglas
Jul 26, 2010 | Bosch & Tankless LP Hot Water Heater
I have a Rheem direct vent gas water heater. When
If you are not seeing a spark at the pilot assembly where the pilot flame lights, then it is probably not sparking in the right place. You may have a short in the wire or a cracked porcelain ignitor, causing it to spark elsewhere. If you can remove the access panel, you may have to relight the pilot manually with a butane lighter. To resolve the issue of the flame blowing out, make sure your vent outside has a cap on it and that the vent is not partially blocked with a bird nests, etc. Hope this helps. Douglas
Jun 27, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Pilot light will not stay on Bosch natural gas tankless water hea
Check to make sure the flame of the pilot is hitting the thermocoupling. If not then you can use compressed air to clean the pilot port and relight and check again. If the flame is hitting the thermocouple, then it may need to be replaced.
May 05, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
Why does the pilot light blow out on the water
Your vent pipe needs a cap. You should be able to find one at your local building supply store; just tell them your problem, and they will find the right product and let you know how to best install it.
Oct 12, 2009 | Bosch AquaStar Indoor Natural Gas Tankless...
I have an Ascot wall hanging hot water heater.The wind frequently blows out the pilot light. Can I make a safe housing around it to protect it from wind and rain
Yes you can, but make sure that it has access to air. Leave at least 6" of space between the shelter and the pilot. Is it outside? I've never seen one outside.
May 29, 2009 | Water Heaters
Smell gas leaking out on windy days, pilot is still lit though
it sounds like the flue pipe out side may have something blocking it , it has a fresh air return on it and when the unit is blowing out it also pulls in the outside air, make sure ther is nothing in the way making the air circulate back in,
Mar 25, 2009 | Bosch AquaStar Indoor Natural Gas Tankless...
EA error msg on Bosh tankless unit
How I fixed it was got rid of it...support help never called back..and to get parts for it was looking into the new year can't go without a shower that long...can we now?
Dec 22, 2008 | Bosch & Tankless LP Hot Water Heater
Bosch AquaStar Indoor Natural Gas Tankless Water Heater with Vent Hood #125 Logo
371 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
