Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Appliance is not cooling
When I came back after being gone for 3 weeks, I was greeted by a HOT moldy fridge. there is power and the fan runs but no cooling. PLEASE HELP! It still smells really bad even after cleaning a few times with a bleach solution
  • Whirlpool Master
  • 3,361 Answers
Check the fan motor at the compressor.
If it is running you should replace the compressor start relay.
Posted on Feb 22, 2009
LG Fridge not cooling refrigerator (freezer is fine, fan is running)
those sensors do fail but if the freezer is not as cold as it should be .then the refrigerator part will also not get proper cooling . TEST the freezer temp .
Sep 25, 2015 | LG Refrigerators
The compressor runs and freezer is cold, however the refrigerator side isn't cooling well. Doesn't feel like any air is blowing in the fridge, only the freezer. I tried turning off/resetting the system...
Your model numbers are a waste of time...
Kenmore 5522 / 655224 / 55222 / 55229
Side by Side Refrigerator... PICK One...!!!
"The" fan...??
There should be TWO fans running...
and the FAN that REALLY make the difference in your
described symptoms ... will not run with the DOOR
open (your evaporator fan).
Possible issues:
Fan motor, blades/air blocked by ice, broken blade,
defective door switch or control board...
I always preach... giving a troubled refrigerator
a THREE DAY defrost... but the other day I found
a solid ice block sitting all SNUGGLY in the middle of
an evaporator...
If you are not willing to do that... (3 day defrost)
open it completely and have a REAL GOOD look
around the EVAPORATOR & FAN.
Never use HOT air... soft plastics can be easily ruined.
Take your MODEL NUMBER...
And look on:
Appliancepartspros:
Search Over 2 1 Million Appliance Parts
PartSelect Appliance Parts and Repair Help
repair clinic
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Happy hunting...
Carnac the Magnificent
Aug 16, 2017 | Kenmore 5522 / 655224 / 55222 / 55229 Side...
Freezer cold but fridge warm
first leave it off for 24 hours, and then put it back in operation. if its doing it again , then chck the heating element, defrost timer...
Apr 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
New westinghouse side by side fridge is not working. it was installed 6 hrs ago.The light is on but it is not cooling at all.
get behind the fridge and see if the black compressor is running and warm not hot if it is thenu may have a fan gone out inside the back panels inside the unit take the panel off and see if the fans running if not make sure it has power if it does and not running then replace the fan and see if this cures the problem
Mar 01, 2010 | Refrigerators
Inside strip of fridge is very hot. cleaned out behind fridge and the coils, etc. fan is barely moving/not moving. any suggestions???
Replace the fan. The strip has a freon line running behind it, and when it is hot, this tells us that you have a dirty condensor, bad condensor fan motor, bad evaporator fan motor, defrost problem, or a freon system problem. When you say your fan is barely moving, I am assuming this is your condensor fan motor, which sucks air through the hot freon lines in the condensor coils, and cools the freon off. If it is barely moving, it can't cool the freon. In some brands a slow moving condensor fan can be caused by a bad main control board. Good Luck, Appliance Specialists
Jan 28, 2010 | Refrigerators
Whirlpool sbs fridge freezer - freezer stopped working
There are 2 or 3 things that would cause this. first make sure the condenser coils are not plugged with dust (vacumn or blow them out) next check to make sure the fan that cools these coils is running, (this is the most likely problem). if both of these check out ok then you would need to check to make sure your interior lights ar going off when the doors are closed as these will add extra heat and cause the center rails to run hot. last and most uncommon would be a freon system problem.
fyi there is a hot gas freon line that runs in between the doors to prevent exterior sweating. when poor or no air flow problems for the condenser coil exist it causes this area to become hotter.
One more thing. if you do determine that the condenser fan motor is bad you can put a normal house fan blowing on to the coil to help cool this area down until you can get the unit repaired.
If you need any further assistance leave me a comment here and I'll gladly get back to you. Thanks Peyton
Feb 24, 2009 | Freezers
DOOR JAM BETWEEN FREEZER AND FRIDGE IS GETTING HOT
This usually means that your condenser fan has stopped. That's the fan outisde (under or in back of) the fridge. It should be running whenever the compressor runs. Heavy accumulation of dust or anything that obstructs airflow could also cause it. But the most likely culprit is the fan.
Nov 05, 2008 | Frigidaire Refrigerators
Fridge powers on but does not cool
Try pressing light blub switch whist doors are open as fan will only start when doorsclosed. If compreesor is running but not chilling it is either the compreesor has gone and wont be pumping or it has lost its refigerant. Hope this helps
Aug 23, 2007 | Frigidaire FRT18B4A Top Freezer...
Samsung RS2555SL humming noise
don't know this model specifically, but have had loads of problems with these samsung fridge-freezers. the no water in drinks dispensor is probably due to the water bottle at the bottom of the fridge being frozen. this is endemic with samsung the noise you hear is ice hitting fan. samsung use two systems for fan. the one i think you have is separate fans for fridge and freezer and a separate evaperator for fridge and freezer. take of the back plate of the fridge and you will find the fan mounted in it. disconnect the plug and socket connection. you will probably find ice build up round the fan blade. melt off with hot water. the bar you had showing on the "8" is a fault code - the most common fault being the defrost termination sensor. unless you are experienced, this is not really a diy appliance
Apr 02, 2007 | Samsung 26 Cu. Ft. Side-by-Side...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
97 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
