Question about D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge
Two computers network. One not connecting. One LAN green light not on. Double checked connections, all ok. Restart computer in the very beginning LAN green light flickers on only for a few seconds.
  • 3 more comments
  • margiek821 Feb 22, 2009
    Please, explain, "paired up again." Thanks.
    Spoem. It is a simple router network in one room. This computer I am typing this on is connected to the Internet just fine thru the same router. The other computer not connecting with the Internet and the LAN green lifhgt on the router is off. Thanks.
  • margiek821 Feb 23, 2009
    No they are not wireless
    Just observed the loffowing. When the computer is completely shut down, the LAN green light at the router is on (connected) and stays on. But at the computer start up while booting up, after 10 sec., the green light goes off (disconnected)'
  • Barry Parks May 11, 2010
    Good morning! I'm Spoem. Let's start with the basics. Please describe your network for me.
  • 202 Answers
I started to assist you with this in chat, but the window closed. Please let me know how your network is setup. Are you connecting directly or through a router? Have you added both PCs to a workgroup or domain?
Let me know on this and we can go to the nest step.
Posted on Feb 22, 2009
  • 1 more comment
  • Barry Parks Feb 22, 2009
    Has the second computer been on the network before? I would start by opening the Device Manager and making sure that the network card is enabled. If it has a red X on it, right click on it and choose enable. I see that frequently in my work environment.
    Let me know what you find.
  • Barry Parks Feb 23, 2009
    Let's step back and make sure we are aiming at the same target. Do you want the two computers to 'talk' to each other, or just share the internet connection? I wish we could get back into the chat area, it would save time. Have you checked to see if the network card is enabled?
    I'll be online for a while. Let me know.
  • Barry Parks Feb 24, 2009
    Have you been able to resolve the problem?
  • 265 Answers
They need to be paired up again this will solver your problem
  • Alex Keen Feb 22, 2009
    Are these wireless?
No internet or lan lights on? Tried reset, hard reset. All other lights, power, wireless, router are on and green. No lights on internet and lan connection. I have tried another wireless router and have no...
The LAN lights will only turn on once you have an Ethernet cable connected to it and the other end of the cable is connected to a working computer.
If you already have a computer connected to the Ethernet port of the router via an Ethernet cable and the lights are still off. Check if the computer you have connected recognizes a network via LAN.
If the lights on the router are still off and the computer doesn't recognize a network then that means that the port for the ethernet of your Router is bad and sadly there's no way of getting that fixed but to have the router replaced.
Otherwise if the lights are off and the computer recognizes the Network and lets you connect to the internet or other computers on the same network then its just the LED of the LAN light that's broken and I think you can live with that.
Hope this helps!
Jul 18, 2011 | Buffalo Technology AirStation Nfiniti...
Just install XP PRO sp3 on P4C800 board and current version of 3Com 3C940 onboard LAN. Installation went fine but LAN can not acquired network address and get no or limited connection.Therefore internet...
When your using Internet connection via LAN you need to configure the Internet Protocol (TCP/IP) Properties at the Network Connection Wizard. To configure the Network Connection just follow this steps:
1. Double click the My Computer from your desktop/screen.
2. At the left side of the My Computer menu click the My Network Places then click View Network Connections in the left side of that window also.
3. Double click the Local Area Connection and click Properties.
4. When the Local Area Connection Properties was appear select Internet Protocol (TCP/IP) then click Properties.
5. The Internet Protocol (TCP/IP) Properties are also apear, then click Use the following IP address and fill-up the following: IP Address, Subnet Mask, Default Gateway, Preferred DNS Server and Alternate DNS Server.
6. After all you fill-up click OK Button.
Note: Make sure that the IP Address you fill-up in your network connection are not the same with the other computer to avoid conflict. Just copy the configuration on the computer like: Subnet Mask, Default Gateway, Preferred DNS Server and Alternate DNS Server. Only the IP Address are unique to the other computer. Example; 192.168.0.5 that is the IP Address of last computer are connected in the network. The IP Address you able to use is 192.168.0.6, only the last digit of the IP Address your going to change.
Jun 04, 2010 | ASUS P4C800 Deluxe Motherboard
VAIO VGN-NS190J/S 15.4-Inch Notebook PC (2.0GHz Intel Core 2 Duo Processor T5800, 4GB RAM, 250G: The wifi light won't turn on when I put the switch...
They issue is due to the corrupted SmartWi Connection Utility Software in the Computer.
You will need to re-install the Wireless LAN Driver, Updates, and the SmartWi Connection Utilities in the Computer to fix the issue with the Wireless.
You can download the Wireless LAN Driver, Updates and the SmartWi Connection Utility from Sony Support Site.
Below are the links.
Wireless LAN Driver
Wireless LAN Driver Update 1
Wireless LAN Driver Update 2
  1. Please download and save each file on the Desktop.
  2. After that double click on the Original Wireless LAN Driver to begin the installation.
  3. Please follow the onscreen instructions to complete the installation.
  4. After that, restart the Computer for the settings to take the effect.
  5. After restarting the Computer, please install the Updates.
  6. Make sure that you restart the Computer after each installation.
  7. Then, please re-install the "SmartWi Connection Utility in the Computer.
You can download the SmartWi Connection Utility from here.
  1. Download and install the SmartWi Connection Utility in the Computer.
  2. after the installation, please turn ON the Wireless Adapter using the SmartWi Connection Utility.
  3. Please click "Start", "All Programs" and SmartWi Connection Utility to open the Program and turn ON the Wireless Adapter.
  4. After that, please re-configure the Wireless Network connection in the Computer.
  5. This should fix the issue with the Wireless Network connection.
May 18, 2010 | Sony VAIO VGN-NS190J/S Notebook PC
Up wirelessly with my home network.My printer is showing as offline on my computer, how can i get it back online. I have it set
The BRAdmin Professional utility for Windows® is designed to manage your Brother network connected devices such as network-ready Multifunction devices and /or network-ready printers in a Local Area Network (LAN) environment. For more information on BRAdmin Professional, visit us at http://solutions.brother.com.
Installing the BRAdmin Professional configuration utility
1 Put the supplied CD-ROM into your CD-ROM drive. The opening screen will appear automatically. Follow the on-screen instructions.
2 Click Install Other Drivers or Utilities on the menu screen.
3 Click BRAdmin Professional and follow the on-screen instructions.
Setting your IP address, Subnet Mask and Gateway using BRAdmin Professional
2 Click Devices, then Search Active Devices. BRAdmin searches for new devices automatically.
3 Double-click the new device.
4 Enter the IP Address, Subnet Mask and Gateway, and then click OK.
5 The address information will be saved to the machine.
You can use the BRAdmin Professional utility to set a password. (See the Network User’s Guide on the CD-ROM.)
Start BRAdmin Professional, and choose TCP/IP.
Note
49
For Network Users
BRAdmin Light configuration utility (For Mac OS® X users)
The Brother BRAdmin Light software is a JavaTM application that is designed for the Apple Mac OS® X environment. It supports some of the features of the Windows BRAdmin Professional software. For example, using the BRAdmin Light software, you can change some network settings on Brother’s network ready printers and multifunction devices. The BRAdmin Light software will be installed automatically when you install the MFL-Pro Suite. Please refer to installing the driver and software in this Quick Setup Guide if you have not yet installed the MFL-Pro Suite. For more information on BRAdmin Light, visit us at http://solutions.brother.com.
Setting your IP address, Subnet Mask and Gateway using BRAdmin Light
If you have a DHCP/BOOTP/RARP server in your network, you don’t have to do the following operation. The print server will automatically obtain its own IP address. Make sure that version 1.4.1_07 or later of JavaTM client software is installed on your computer.
1 Double-click the Macintosh HD icon on your desktop.
2 Choose Library, Printers, Brother and then Utilities.
3 Double-click the BRAdmin Light.jar file. Run the BRAdmin Light software. BRAdmin Light searches for new devices automatically.
4 Double-click the new device.
5 Enter the IP Address, Subnet Mask and Gateway, and then click OK.
6 The address information will be saved to the machine.
Note
50
For Network Users
How to set the machine’s network settings to wireless
Restoring the network settings to factory default
LAN or wired LAN
To connect your Brother machine to a wireless or wired network you must configure the machine from the machine’s control panel for the network type you are using.
For wireless LAN On your machine, press Menu. Press a or b to choose LAN and press OK. Press a or b to choose Network I/F and press OK. Press a or b to choose WLAN and press OK. The wired network interface will become inactive with this setting. Press Stop/Exit.
It will take about a minute for the LAN menu on the LCD to become available again.
For wired LAN On your machine, press Menu. Press a or b to choose LAN and press OK. Press a or b to choose Network I/F and press OK. Press a or b to choose Wired LAN and press OK. The wireless network interface will become inactive with this setting. Press Stop/Exit.
To restore all network settings of the internal Print/Scan server to factory default, please follow the steps below.
1 Make sure the machine is not operating, then disconnect all the cables from the machine (except power cable).
2 Press Menu. 3 Press a or b to choose LAN.
Press OK. 4 Press a or b to choose Factory Reset.
Press OK. 5 Press 1 to select Yes. 6 Press 1 to select Reboot.
7 The machine will restart, re-connect cables once this is complete.
Apr 29, 2010 | Brother MFC-665CW All-In-One InkJet...
Network connects without router. Install router
is your router powered? make sure your router is powered properly.
are you connecting your computer to the LAN ports? (the ones with a number not the one that say WAN? connect your computer to one of the LAN numbered ports and check to see if you get a green light on the front pannel. if you don't have green light, try a different port until, if you run out of ports and still no green light try a different cable.
have you by any chance disable your lan ports? I don't know if it is possible on your router to disable some ports, if that's the case is better to start fresh and simply reset your router by pressing a reset button for a minute while your router is getting powered and retest to see if you a green light on the lan port where you are connecting your computer.
if all this fails, it's very likely that your router has died. replaced accordingly.
Apr 04, 2010 | D-Link DGL-4100 Router (DGL4100)
Second computer connected to this model gives message "Network cable unplugged" when it is not! network connection intermittent. What can we do please?
Hi Jackie!
It sounds like a communication problem between the router and the computer. Try the following solutions to solve this:
1.Connect the LAN cable to other free LAN port in the router.
2. Try using a different LAN cable.
3. a. Open Device Manager
b. Go to Network adapters. Click on the "+" sign next to it.
c. Double-click on your network adapter.
d. On Advanced tab, look for Speed/duplex settings (or Media Type)
and change it's value to Full autonegotiation (or AutoSelect).
e. Click OK on all windows.
f. Close the Device Manager and restart your computer.
4. Reinstall or update your network adapter device drivers.
A "workaround" solution - use a wireless network adapter to connect wirelessly to the router.
Hope I helped,
Pelu.
Mar 16, 2010 | Belkin F5D7630uk4A Wireless Router
No internet connection
Internet connection solutions
  1. Restart the computer.
  2. Test the jack.
  3. Test the equipment.
    1. Try a different jack that you know works.
    2. Try a different cable that you know works.
  4. Check your computer settings.
  5. Renew your IP Address
    1. [x] Windows Vista
      1. Look for your Ethernet card:
        1. Right-click on My Computer from the Start Menu or on the desktop.
        2. Left-click on Properties.
        3. Click on Device Manager on the left side under "Tasks".
        4. Expand the Network Adapters and look for any yellow exclamation points. Make sure a card is listed.
        5. If there are exclamation points, or if there is no card listed, you need to reinstall the card.
      2. Set your IP address to configure Automatically (through DHCP):
        1. Go to the Control Panel in your computer (in the Start Menu).
        2. Go to Network & Sharing Center.
        3. Under "Network", go to Local Area Connection and select "View Status". In new window, choose Properties at the bottom.
        4. Scroll down "This connection uses the following items" list to Internet Protocol (TCP/IP).
        5. Select Internet Protocol (TCP/IP) and click Properties.
        6. Change to "Obtain an IP address automatically".
        7. After you have changed this, restart computer.
      3. Check to see if your network connection is on:
        1. Go to the Control Panel in your computer.
        2. Go to Network Connections. If you cannot see Network Connections, go to Network and Internet Connections and then go to Network Connections from there.
        3. If there is a red X through the Local Area Connection, or the Local Area Connection is grayed out, double-click on the X to enable.
    2. [x] Windows XP
        2. Left-click on properties.
        3. Go to the Hardware tab and click on Device Manager
        3. Right-click on Local Area Connection and go to Properties.
        4. Scroll down the "This connection uses the following items" list to Internet Protocol (TCP/IP).
        7. After you have changed this, restart the computer.
        3. If there is a red X through the Local Area Connection, or the Local Area Connection is grayed out, click on Local Area Connection and click "Enable."
    3. [x] Macintosh OS X (10.4 or "Tiger")
      1. Look for Network Cards:
        1. Go to the System Preferences panel from the Dock or Apple Menu.
        2. Open Network icon under Internet and Network.
        3. This shows your current network settings. Green lights for each device means it is connected and red mean there is no connection.
        4. Go to Show and then click on Built-in Ethernet.
        5. Under the TCP/IP tab make sure "Using DHCP" is chosen under the top option.
      2. Renew IP address. Hit "Renew DHCP" or change it to a manual address. Then restart and change it back to DHCP to renew the connection.
      3. Set your IP address to "Configure Automatically using DHCP". Under the Ethernet tab make sure that configure is set to "Automatically". Click OK until you are back to the main System Preferences windows.
      4. Check your privacy setting
        1. Go to Sharing under Internet and Network in System Preferences
        2. Under Services everything should be unchecked.
    4. [x] Macintosh OS X (10.5 or "Leopard")
        3. The left menu shows your current network settings. Green lights for each device means it is connected and red mean there is no connection.
        4. Select Ethernet from the left menu. Go to Advanced.....
        5. Under the TCP/IP tab make sure "Using DHCP" is chosen under the top option, "Configure IPv4".
      2. Renew IP address. Hit "Renew DHCP" or change it to a manual address. Click OK.Then restart and change it back to DHCP to renew the connection.
      3. Click OK until you are back to the main System Preferences window.
    // MAIN FUNCTION: new switchcontent("class name", "[optional_element_type_to_scan_for]") REQUIRED // Call Instance.init() at the very end. REQUIRED var bobexample=new switchcontent("switchgroup1", "div") //Limit scanning of switch contents to just "div" elements bobexample.setStatus('[x] ', ' ') bobexample.setColor('#674a80', '#3b5998') bobexample.setPersist(true) bobexample.collapsePrevious(true) //Only one content open at any given time bobexample.init()
  6. Make sure your computer is clear of all viruses, spyware, and adware.
Oct 03, 2008 | Computers & Internet
Network, Internet, or Base Station Management Tool Are Unavailable
To resolve this issue, turn off Internet Connection Sharing on your network connection: 1. Click Start, click Control Panel, and then double-click Network Connections. 2. Click your network connection, and then under Network Tasks, click Change settings of this connection. 3. On the Advanced tab, clear the Allow other network users to connect through this computer's Internet connection check box. 4. Click OK. 5. Restart your computer.
Feb 16, 2006 | Microsoft Broadband Networking MN-500...
Feb 16, 2006 | Microsoft Broadband Networking MN-100...
Open Questions:
See all D-Link DI-604 4-Port Cable/DSL Router (DI-604) Questions
D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
