Question about SimpleTech (STT440HD/40) 40 GB Hard Drive
Dell Inspiron 2650 laptop is not recognizing hard drive
Hello! My SimpleTech 40gb hard drive is not recognized on my Dell Inspiron 2650 laptop and I don't know what to do. I put the OS CD in the laptop and tried to reboot many times but it is not recognizing the OS or the harddrive. My brother thinks that we should just focus on recovering the files on my hard drive by buying the part we need online, but I want to make sure we try everything before we spend money on parts that may not help recover the system anyhow. The computer was working just fine before this happened so I'm hoping I can fix it!
Anyhow, I would greatly appreciate any tech support. Thank you!
Molly
  • 558 Answers
Do you have the dell diags cd that came with the computer.If you do ,boot to the cd and run a diag.Once in the menue do a quick test,check the device you want to check and wait for the result.You may want to test all devices since you want to make sure the computer is working and you might have only a failed hard drive.
Posted on Sep 22, 2009
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
HP windows 8 does not recognize simpleteck hard drive
I purchased a SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx for my Vista machine and all was well. Then I purchased a Windows 7 machine. It would not recognize the devise. I contacted SimpleTech only to be told my model cannot be used on machines newer that the Vista. Recently I purchased a Windows 8.1, did a little research, plugged the SimpleTech into the 8.1 and reformatted it using the Windows feature. The SimpleTech is alive and well on my 8.1.
Aug 02, 2013 | SimpleTech SimpleDrive Pininfarina 500GB...
The HD suddenly stops getting recognized by the laptop, in the middle of any action.
Sounds like a conflict. Disconnect any other USB attached devices while running HD. Worked for me with same problem.
Aug 26, 2012 | LaCie 500GB Rikiki USB 3.0 Portable Hard...
New computer doesn't recognize device
uninstall the drivers for the hard drive then reboot install drivers that came with drive and then plug it in.
Mar 27, 2010 | SimpleTech 250GB USB2.0 7200 RPM External...
Dell inspiron 1501 won't recognize hddr250, but it
check to see if the drive is a master or a slave if the system finds it then theres a pin issue of the drive malfuntioned
Jan 26, 2010 | Computers & Internet
Simpletech model sp u25/120 not recognized
Sounds like you have a failing enclosure, are you still under warranty?
If you're under warranty and have other copies of all your files, simply visit the western digital website and file a warranty claim. They are very good about replacing any drives that fail.
If you do have files you'll need recovered then you do have a cheap solution to try before commiting to more expensive solutions. It will void your warranty but frankly the warranty is useless if you need your files.
Take your drive to a PC shop and ask the technicians to test the hard drive in a new enclosure. If you're lucky it's just a failure in the enclosure and you should be back in business for less than $50. If this fails to work and you're located in North or South America contact www.armor-it.com if you live outside the Americas, contact me by replying to this page and I will direct you to an apropriate facility nearer to you.
Crankstart
Jan 07, 2010 | SimpleTech (SP-U25/120G) 120 GB USB Hard...
The computer does not recognize the Simpletech external hard drive. I plugged in a different external hard drive into the same USB port and the computer recognized it right away. What is wrong with the...
not all usb devices work on all machines
You need to find a driver or ask simple tech what the issue is i had the same issue with My WDC drive Western Digital gave me a driver after emailing them
Aug 13, 2009 | SimpleTech 750 GB USB Hard Drive
My SimpleTech 320GB external hard drive is no longer recognized
trying using it on another system and and see if it happens like that. if it does, you may want to get a driver for the hard drive. it is likely the driver is corrupted. try it on another port also.
Jun 09, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Won't recognize my USB
i have a feeling its not the hard drive thats bad i think it sounds like the case .
you can try buying another case and transfering the hard drive to it the case is around $20.00
Nov 30, 2007 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech (STT440HD/40) 40 GB Hard Drive Logo
135 people viewed this question
Top SimpleTech Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Gareth Cockram
Gareth Cockram
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
