Question about Dell Dimension 3000® Pentium® 4 2.8GHz, 256MB, 80GB, 48x CD-RW PC Desktop
Dell Dimension C521 power shuts off spontaneously
While working on my computer, power spontaneously shuts off without warning. I then have to reboot. Compter will operate for 5-10 minutes, and then suddenly shut down again
    Novelist:
  • 180 Answers
It sounds like your power supply fan may be overheating. The easiest way to determine this is to open the case and look at the fan while it is spinning- if it is indeed spinning at all. I find the best way to get an idea of the functionality of the fan is to shine a flashlight on it at an angle. If you can detect fluctuations in the rpm visually, you know where the problem is. Then it's a matter of changing out the power supply. If, however, the fan seems to keep the same rotation speed constantly, we'll need to look further. Let me know what you find out before we go deeper into the system.
Posted on Feb 23, 2009
  • 43 Answers
Procssor over heat can cause this kind of problem
check your processor cooler
Monitor lights orange
If the monitor gets no signal it will show orange. or ,It's hibernating or sleeping. Shut down computer, reboot, open Control Panel, Power settings, change to High Performance, change Hibernate to never or disable, change sleep to never or disable. Shut down the computer and monitor when not in use. It will last longer and reset the computer every day when turned on.
Dec 23, 2012 | Dell Dimension C521 PC Desktop
Dell c521 is stuck in power save mode
Restart the system.
Still if does not works.
Keep pressing the power button for 3 mins while the system is in power save mode.
It will Shut down.
Restart Now.
Rate this solution, Write a comment to keep in touch.
Sep 16, 2010 | Dell Dimension C521 PC Desktop
How do i restore my dell dimension c521 to the way
This is done 1 of three ways depending on how your restore information is stored. 1. After you push the power button start pushing the F8 key and when you get the option screen select restore to previous or restore to factory settings. This method works if your system has a special restore partition still. If you received System Restore Disk insert the CD in the CD player and reboot the system. It will boot from the CD and present the Restore menu for you to make a selection from. Your third choice is to select System restore from the system tools sub menu under the Accessories menu in your program list and chose to restore to factory settings.
Jul 23, 2010 | Dell Dimension C521 PC Desktop
Blue screen Dell Dimension C521
This problem occures when ther is an conflict with drivers, so try to updat your Bios from dell web site orm you may try to update the video driver or have an option to replace it and try Try to boot the system safemode and chk if you get the same BSOD if not then its the video drivers
Regards
Samson Ved
Feb 05, 2010 | Dell Dimension C521 PC Desktop
Sudio 17 spontaneously shuts off
Troubleshooting With PSA Diagnostics on a Laptop Computer
STEP: Run the Preboot System Assessment (PSA)
Additional Information
  1. Ensure that the computer is powered off.
  2. Press and hold <Fn> and press the power button to power the computer on.
  3. Release both buttons. The PSA diagnostics sequence begins.
  4. Make note of any PSA beep codes or PSA error codes
  5. check PSA error code on support.dell.com
Dec 09, 2009 | Dell Studio 17 Notebook
Dell Dimension C521 power shuts off spontaneously seems the fan on the power supply isn't working.
If the fan on your power supply is not turning then you need to replace the power supply as soon as possible. The machine is overheating and then shutting off. If the power supply is not replaced it can cause additional problems with the motherboard, cpu, and hard drive. Open your case and look on the power supply for your replacement parts number, check Ebay.com for a replacement. They are easy to replace, just a few screws and power plugs.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of PC and printer support/repair
Jun 28, 2009 | Dell Dimension C521 PC Desktop
Dell 5150c shuts down orange flashing light
It was a faulty or worn out power supply fan. I just replaced it and the computer has been running for about an hour and a half and still no shut down. The system temperature is stable. It runs quieter now. New fan cost 13.88CAD.
Mar 09, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Blue error screen and system shutdown on Dell Dimension C521
Rule of thumb test ram out first usally that is the cause what does the code say on the blue screen
Feb 13, 2009 | Dell Dimension C521 PC Desktop
Reboot
If you are running XP CNTL+F11 after the Dell Splash Screen
Here is a Dell Document on how to restore your system for factory defaults:
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&dl=false&l=en&s=gen&docid=3E48AE3870775D64E040A68F5B2877D4&doclang=en&cs=
May 14, 2008 | Dell Dimension C521 PC Desktop
Dell Dimension 3000&#174; Pentium&#174; 4 2.8GHz, 256MB, 80GB, 48x CD-RW PC Desktop Logo
439 people viewed this question
Alun Cox
