Question about Dell Inspiron 700M Notebook
Dell Inspiron 700m Problem
Hi my 700m laptop, when it is plugged in the charging light turns on but when i press power button nothing happens. any suggestions
  • 1 more comment
  • idhaliwa Feb 22, 2009
    The only thing that happens is the light to notify me that the battery is charging turns on. Other than that nothing happens.
  • Anonymous Apr 18, 2009
    nothing comes on .. even when plugged
  • John Miller Jr May 11, 2010
    Does the laptop turn on when its plugged up or it does nothing plugged up or on battery power? Clarify, please...
Dell inspiron 1525 does not power up. i powered
Hi
Thank you for yuor query
Please can you try the following
1) Remove battery
2) Remove wall charger
3) Press and hold the power button in for 30 seconds
4) Plug in wall charger only
5) Retry powering the laptop and if it switches on plug battery in after 5 minutes
Regards
Shauqat
Apr 28, 2010 | Dell Inspiron 1525 Laptop
Hi i have put power supply in anbd powered up my power supp;y shows green light but when i press power on butoon on my e1705 nothing happens no lights flash nothing totally dead
Hi
Please can you try the followinf
1) remove wall charger
2) Remove battery
3) Press and hold power button down for apporx 30 seconds
5) Power on laptop
6) If successful plug in battery
Regards
Shauqat
Apr 19, 2010 | Dell Inspiron E1705 Notebook
Hello, i got a DELL 700m. it did not start. i didnt make anything... no sound, no beeps, no lights, no fan spinning... just nothing. Powersupply is ok, i tested it with a defintivly working one from my...
Looks like the input for your power has failed... a common problem. You will need to open up the laptop and have the power jack replaced. Happy New Year to you and yours
Jan 05, 2010 | Dell Inspiron 700M Notebook
Dell Inspiron 700m won't start
It sounds like there is an issue with the system memory.
Remove both the power adapter and the battery. Turn the laptop over and locate the RAM (memory) cover and remove the holding screw.
Take out the system memory and clean the brass contacts, also clean the slots that the memory sits in.
Re-seat the memory making sure it clips into place nice and tight and replace the RAM cover.
Return power to the laptop and turn it on to see if that has helped.
If it still won't boot up then you may need to purchase new memory for the laptop.
Good luck.
Sep 28, 2009 | Dell Inspiron 700M Notebook
Dell inspiron 700m wont power up
Which way do you power up the laptop?
The AC power or laptop battery?
If the AC power, you should check the wire is connected well.
If the battery, you should check whether the battery is charged full.Maybe the battery is aging, you need to get a new Dell inspiron 700m battery.
You can get a replacement at shop-batteries.com
Aug 26, 2009 | Dell Computers & Internet
I want a driver for motherboard of dell inspiron 700m please
Hi, go to the internet and go to dell.com then go to drivers & downloads
then select your laptop model Inspiron 700m
OR
here is a link to get all your drivers for your model of dell Laptop Inspiron 700m
http://support.dell.com/support/downloads/driverslist.aspx?c=ca&l=en&s=gen&ServiceTag=&SystemID=INS_PNT_PM_700M&os=WW1&osl=en&catid=&impid=
hope this solved your problems
Nov 11, 2008 | Dell Inspiron 700M Notebook
Dell Inspiron 700m
I have a Dell Inspiron 5100. I've had it for about three years. One day it did the same thing, no power, no fan, nothing. I replaced the power supply with a 350 watt unit from Office Max. I spent about $40 and I'm using my Dell to send you this response.
Jul 22, 2008 | Computers & Internet
Dell Inspiron 700M Notebook Logo
161 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
