Question about Maytag Atlantis MDE7400AY Electric Dryer
Timer does not advance, even in timed mode
Maytag Model MDG8400AWQ Serial # 19037208CE everything else works but timer will not advance in any mode. Suspect the timer because of no advancement in the timed dry mode, which does not use the electronic intelli-dry ckt board. Original timer had no valid part number on it. Was told part # 33002855 was proper replacement. However, the part is electrically different. For example, when an ohmmeter is placed across the timer motor contacts on the timer, the original timer measures approx. 2-3K ohms, on the 33002855 it is open. Is this the correct part for a series 19?
  • Anonymous May 06, 2009
    I have the same problem with aMDE8400AYQ, the connections inside
    the timer are different from what the wiring diagram pictures is there a diagram for 33002808
  • Maytag Master
  • 3,361 Answers
My parts sources list 3 different timers for this dryer depending upon the MAN.#.
They are
33002855
33002808
33002854
Posted on Feb 22, 2009
Maytag atlantis dryer wont shut off. changed the timer and it still wont move.
send the model number.if this is electric try this.put it on air fluff and start it,if it has heat your element is bad,it's grounding out,part of the element is touching the metal case around the element.if it just did this on auto i would say change the cycling thermostat but on timed dry it just counts down like a clock.i saw this once and the element was bad,grounding out.it was tricky i thought it was the timer also.
Nov 27, 2017 | Maytag Dryers
Maytag Dryer MDE6400AYW. Dries clothing but does not shut off in Auto Mode. Tried Timer mode but the knob does not advance on its own and dryer does not shut off in that mode either. Replace Timer?
Some of them timer can be oiled, (just a little zoom oil no wd-40) if it is real hard to turn, the knob can become cracked and the timer motor itself it may not have enough ump to move the gears and sometimes oiling the timer and moving it around many times loosens em up.
Jan 11, 2017 | Maytag Dryers
Dryer wont stop buzzing
follow this steps and fix it. God bless you
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is bad and need replaced. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. replace the heating elements
Jul 09, 2013 | Dryers
What is the originaltimer for Maytag model # MDG8400AWQ serial 19
Where I can buy this timer
Kinston 70959-A00798
May 24, 2013 | Dryers
Maytag dryer wont turn off
I thank you need a new Timer part# 3979617
Jan 21, 2013 | Maytag Dryers
My Maytag MDG6400AWW timer does not advance in the Auto mode. The clothes will dry but it will spin and spin for hours until you open the door. In timer mode everything appears to work normally
sounds like it is not sensing the temperature, which is the thermostat, here is a website that will help you out, #6 dryers basic, Good Luck Tim:
http://www.applianceaid.com/general.html#timers
Nov 27, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer won't turn off
hi please rate the last solution atleast as thanks for trying.
Dec 31, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis dryer model # mde6400ayw
sounds like the timer is not completing the cycle in this mode will the dryer shut off if you manuelly advance timer in that mode
Oct 21, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Washer sticks in spin mode during most loads
hi there,
the timer is actually a mechanical switch. sounds like you have answered your own problem. it's time to replace the timer.
Oct 01, 2008 | Maytag LSE7806A Top Load Stacked...
Timer does not advance and dryer seems to get extremely hot. Ireplaced the timer mechanismbut I still have the problem.
This may not be the solution to your exact problem but for those looking for why there timer will not advance and why it keeps running even when the items are dry: The usual problem is not the timer but the mosture sensor (if your dryer has one).
1: Check the mosture sensor light/indicator. If is still shows some mosture or flashes even when the items are dry, you have a mosture sensor problem, probably not a timer issue - luck you.
2: Check if the timer will advance and the dryer will turn off when you have it in the TIMED mode (i.e. 10mins - NOT the more/less dry modes.) If so, then it is indeed a sensor problem.
2: Check that the wires to the mosture sensor have not fallen off (as in my case - a simple repair). The senor is usually two metal bars somewhere near the front part of the inside of your dryer. You may have to take off the door and the front pannel (be sure to unplug the dryer first) to get at the two wires to clip on to the sensor. Clean any lint and make sure they are conneted. If well connected then replace the sensor ($15-$20 and very easy to do).
Sep 15, 2007 | Maytag Atlantis MDE7657BY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
450 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
