Question about Kenmore Refrigerators
Freezer drain clogs and water drips into refridge. i unclog drain and problem returns a year later?
  • 700 Answers
Then you are goinng to have ot put something like chlorox into the drain line periodically to kepp it clear.
Posted on Feb 22, 2009
Top freezer whirlpool refrigerator condensation water leaking/dripping
there is a drain in the freezer that sum time get Clogged the drain is located below the evaporator coil you have to remove the evaporator cover to unclog it make sure the refrigerator is unplugged before trying this you can't unclog the freezer drain without removing parts
Sep 10, 2013 | Refrigerators
Tip
Water Leaking Inside Refrigerator
If water leaks inside your refrigerator
(and it WILL, at some point) you can fix
it yourself. My 26 year old fridge was leaking
and I fixed it completely. It is a Kenmore
top freezer, bottom refrigerator model.
In the good old models, one had to defrost the
fridge every few months manually.
In the recent models, the fridge defrosts automatically,
once or twice a day, and the water is supposed to drain
down a long drain tube into a pan located at the bottom of
the fridge. This collected water in the pan evaporates
by the heat under the fridge.
Now the drain tube can get clogged, by food debris and/or
ice. Thus when the water cannot drip through the drain tube
the water drips inside the fridge.
The drain tube is located behind the fridge, which is pretty
easy to take it out and clean. However usually the clog is
not in the long tube but in the connector assembly located
in the backside of the fridge that leads to the long drain tube.
To get to the connector assembly, you need to unscrew and
take out the back panel of the freezer compartment. You would
see the evaporator coil and a tray under the coil where the water
is supposed to drip through. If you find the tray completely frozen
with ice, let it melt off. To speed up melting, you may blow
hot air via a hair dryer. Once the ice is clear, you should see
a drain hole in the middle of the tray. This could be clogged,
which needs to be unclogged.
Next unscrew and open the thermostat control assembly located
in the inside of the back of the refrigerator compartment just above
the light bulb fixture. Once you take the cover off (you will
also have to take the knobs out) you will see a small tray cup about
2" x 2" x 1/2" into which water from the top freezer compartment
drain hole is supposed to drain. Pull out the tray cup, and if clogged,
unclog it, clean it and put it back.
To check if the drain works ok, pour some water on the tray
under the evaporator coil (top freezer compartment) and see if it
immediately drains into the tray located at the bottom of the fridge
at the floor level. If it does, you got it; and you can assemble things
back in the reverse order you took the pieces apart.
Needless to say, use a vacuum cleaner with a long suction tube to clean
out all the collected mess under the fridge. No matter how good
your housekeeping is, the bottom of the fridge will be full of dust.
With lot of patience (I mean lots of it) you should be saving hundreds
of dollars. Attached are some pictures I took. Call me before you dig !
on Mar 01, 2010 | Refrigerators
Water from defrosting leaks into the bottom of the freezer and freezes into a solid sheet of ice, which I chip out every 1 to 2 weeks. Kenmore bottom freezer refrigerator Model 795.65002400.
it yourself.
To get to the connector assemble, you need to unscrew and
the light bulb fixture. Once you take the take the cover off (you will
Good luck and hope this helps
Aug 01, 2010 | Kenmore 65212 Bottom Freezer Refrigerator
Water dripping insie the fridge
Water accumulating on the ceiling of the refrigerator is usually caused by a clogged drain in the freezer section beneath the evaporator. The clogged drain will cause water from the self defrost cycle to leak into the divider between the freezer and refrigerator. This water may then freeze and cause condensation build-up on the refrigerator ceiling. The solution to this problem begins with unclogging the drain. It may also be necessary to remove the entire freezer/refrigerator divider to thoroughly dry the insulation in the divider. Occasionally the insulation needs to be replaced to prevent a recurrence of the problem. This can be a big job – you may want to hire a qualified appliance repair technician.
Jul 28, 2010 | Frigidaire FRS26R4A Side by Side...
My Kenmore refridgerator with freezer on bottom leaks water from bottom and I have ice build up in freezer and it's suppose to be a frost free freezer?
I had the same problem with my refrigerator/ bottom freezer. It is a Kenmore and would build up ice in the bottom and would eventually drip water on the floor in front of the bottom drawer. I solved the problem by doing a few different things. First I took off the back cover to see where the drip pan was located. Look for the drain tube that goes into the drip pan and in my case cut two plastic ties to gain a better angle for my next steps. I took a turkey baster and a cup of hot water and shot it in the drain tube several different times. Then I took a string trimmer line (pretty thick) and pushed that into the drain tube as far as I could get it and worked it back and forth. My final step was to blow air into the drain tube in towards the freezer at which point I could hear the ice in the icemaker blowing around. The following day the water was draining into the drip pan and not into the bottom of my freezer :>)
Sep 16, 2009 | Kenmore 19.7 cu. ft. Bottom Freezer...
Water accumulates inside the refrigerator, Kenmore, Mod. 71194100
You get to it from the freezer. Remove the back wall in the freezer and you will see it there. Unclog it with some wire or check to see if it has ice over it.
Sep 13, 2009 | Kenmore 71112 / 71114
Leaking frig.
  • take out the back wall of the freezer and physically clean out the line. you may need to run a coat hanger or something down the drain to unclog it. also pour some hot water down the drain after you think you have it unclogged.
  • the water is coming from the freezer when is defrosts. the drain line is in the back wall of the freezer and may be clogged up with ice. clean out the freezer and pour some hot water in the very back of the freezer, this will hopefully unclog the drain. if not, then you have to take the back wall out of the freezer to get directly to the drain line. there should just be a couple screws holding it; it is just an aluminum or plastic panel.
Jul 06, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
LG Refrigerator
  • the drain line in the freezer may be clogged forcing water to drip into the freezer. clean out the freezer and pour some hot water in the back of the freezer to unclog the drain.
  • another cause of this would be if the door is not sealing properly then the inside of the refrigerator will build up condensation.
Jul 05, 2008 | Refrigerators
Ice built up on bottom of freezer then dripping down front
Probably a clogged drain. Use a pipe cleaner to unclog, then a turkey baster with hot water to clean out anything else. Then when the drain is clear, pour a weak bleach solution down the drain to kill the mold that probably caused the blockage If possible remove all food and let it sit unplugged for a day or two. This will clear some defrost problems.
Jun 22, 2008 | Frigidaire 14 cu. ft. / 396 liter Upright...
Refrigerators Logo
51 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
