Question about Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Bad tire I have a 6.6 HP rear tine tiller and one of the tires need changed, I cannot figure out how to get the tire off. Any ideas
  • 48 Answers
SOURCE: Troy tiller tines
they should point inwards and towards the rear of the machine
Posted on Oct 17, 2008
SOURCE: My rear tine tiller lurches out of control when I use it
Hi it sounds like you are trying too till the soil with the tiller in the fast position and probably too deep for your first pass. Really the fast position is for transporting the tiller from the field. Try putting the tiller in slow which would be the down position. Turn the throttle all the way foward, engage the tines and push your depth rod on the back down to where it is only going into the soil about four inches or even less depending on the hardnes of the soil. Even though a Troy is the best Tiller made it will try to run away with you when your trying to hog the soil all at once. Your depth setting is very important and people seem to forget the importance of adjusting it. Try these things, and remember to alway's start your tilling in the slow full throttle position. Lowering your depth a little at a time. Till you find the appropriete feed for your speed.
Posted on Mar 07, 2009
SOURCE: What type oil goes in the tranmission?
Trans oil! 90 or 140 wt.
I use 140 in my older tiller.
G
Posted on Apr 27, 2009
  • 22 Answers
SOURCE: Troy Bilt Tiller tines do not engage
You likely have a clutch problem, never saw one that a simple adjustment would fix. I'd take off the tiller (there are two bolts that hold the tiller portion to the transmission, and check to make sure the clutch is sliding in and out. My hunch is either the lever is loose on the shaft or the allen-head little bolt that they use to shift the clutch has come out. Be sure to grease the clutch while you're in there.
This should be covered in your owners manual. Shame on them if they didn't mention this.
Posted on Jun 14, 2009
  • 110 Answers
SOURCE: I need to replace the seals on my Troy-Built Pony
I presume you opened the port and removed the grade 8 placement bolt? If you have then you need to polish the shafts with 400 then 800 sandpaper, clean then lube them before trying to slide thru the support bearings. If your tine shaft is bent? your screwed, or just remove the shaft seals with a screwdriver and replacing them without removing the shaft. REmember to put a thin coat od RTV arround the outer lip to help make a better seal
Posted on Nov 15, 2009
I have a 1940s rear tine tiller that runs great. I have to replace a tire. I removed all the lug nuts with no problem, but the wheel will not pull off the machine. There is a cap in the center of the
If it has lug nuts then you have a sperate hub and wheel get out your big hammer rust is holding it together. Wouldn't hurt to spray it down with penetrating oil the day before its hammer time. I always find striking a wheel from the rear on the tire is the most leverage.
Apr 06, 2014 | Garden
Tires and tines will not engage
model number would be VERY helpful here because craftsman made many different styles/models throughout the years
Nov 28, 2013 | Craftsman Garden
Husqvarna shear pins break within minutes
if we are speaking about the shear pins on the tines, the ground is the problem and you need to begin your first pass on a more shallow setting and progress to a deeper setting gradually. if we are speaking about the shear pins on the tires w/o engaging the tines then these should not be breaking and I recommend that the tiller be examined by an authorized dealer.
Jun 15, 2012 | Husqvarna Garden
My mtd yard machine bogs down in the tilled /cultivated dirt. the belly support is only less than 2 inches to the bottom of the tires! when I till the next row the tires just turn freely and I have to...
Sounds like a depth adjustment or a leverage problem.
Check your manual to see if you are able to lower the tines to a deeper position.
There usually is also a handle adjustment to raise the handle to get more leverage. (Not all Models) By pulling back on the handle it forces the tines into the soil and raises the tires. This allows the tines to agitate and do the work while at the same time walking the machine forward. When you push up on the handle the rubber tires provide traction and forward movement and less digging on the tines.
Method: Possibly by allowing a little space between passes your wheels won't hang up in the previous dead furrow. You can then go back over the skipped spaces or cultivate from the other direction and a criss cross pattern.
Best wishes,
TF
Jun 02, 2011 | Mtd Garden Tiller (Mtd)
Hi! i have older troybilt rear tine tiller and would like tires and if possible a owners manuel the only serial # i could find is 464932. do you have access to older parts for equipment such as mine?...
http://www.mtdparts.com/webapp/wcs/stores/servlet/OperatorManualView?storeId=10101&catalogId=19502&langId=-1
Go to the above website and put in your model and serial number. If it is a Horse tiller just type in Horse and your serial number and you can download a copy of your operator manual. If it is the Horse model it was built between 1/1/80 and 7/1/80. i believe you have a Horse II four speed model that will just have one drive belt the older Horse I tillers were two speed with two belts.
Most any good tire shop can supply tires for your tiller or you can order them online and take then to a shop to mount for you. If your tires are not real bad they can just put tubes in them so they will hold air. Almost all parts are available through MTD who owns the Troy Bilt name now or through many sites online.
Good Luck,
Frank
Aug 11, 2010 | Troy-Bilt Garden
We are trying to remove the wheels and tines from the craftsman roto tiller in order to replace a broken drive chain. We are having a very difficult time getting the wheels and tines off. Any suggestions?
there should be a cotter pin or pin holding a large washer once you have removed these then you have to get the wheel to slide off the axle it has a keyway on it.i have taken a hammer and hit one side of the tire on the backside then turn the tire half way round and hit the tire from the backside and walk the wheel off the axle.if the axle is rusty shoot wd-40 around the axle and wheel .the wheel should slide back on as you line up the keyway when putting them back on.if your going after the chain the tines will have to come off too and the chain box split
May 28, 2010 | Craftsman 8.50 Torque Rating Dual...
Rototiller won't engage into gear
You will need to split the gear case if iam not mistaken it has chain drine the chain links break and you have to replace them
May 09, 2009 | Garden
Troy Bilt Pony 6.5 Hp Rear Tine Tiller Logo
247 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
