Question about Frigidaire GLER341A Electric Dryer
Which groove in the bearing cradle does does that pesky ball bearing fit into, and lubricacation tips
  • 1,543 Answers
Hi. I don't work on many Frigidaire's, but that pesky ball bearing does not go into any of those grooves. It goes in the very back center of the cradle, sandwiched between the ball and a metal strip on the back side of the cradle. (It is suppose to drain off static electricity from the drum. If it gets lost, it's not a major loss) As for lube, just put a gob of the stuff that comes with the kit in the bottom of the cradle before reinstalling drum.
Posted on Feb 22, 2009
After replacing valve coils it now makes thumping noise reassembled it twice
Thumping noise is usually something with the drum system. You didn't list make and model so I'll give a few suggestions. If its Whirlpool--- the drum rides on 2 rubber rollers at the back edge that wear and need replaces if the rubber gets too bad. The front edge of the drum has a 2 piece plastic bearing strip that snaps into square holes in the front drum edge. Those 2 strips sometimes break or chip and need replaced.
If its a Frigidaire dryer----the back drum bearing is a small round metal ball that looks like a small trailer hitch ball. If fits inside a slotted plastic retainer block. The plastic block wears and the ball sometimes gets grooved and needs replaced. It comes as a complete kit (ball and socket) for about $20. The front of the drum has a similar system plastic strip as the Whirlpool I described above. Hope this helps.
Jun 10, 2015 | Dryers
I have a Frigidaire Gallery dryer model gler341as2 that squeels cer loud at times. what kind of grease do I use on the back shaft and tensioner?
That is a Hi Temp grease. It is sold under a Frigidaire part number
#5303307893. If any of the parts at that back ball assembly are worn, it should be replaced. Don't try buying the parts separately, they sell a complete back bearing kit that sells much cheaper than if you purchased each part. The kit also comes with the HI temp grease inside. Here is the kit # 5303281153. Includes that trailer hitch looking ball and the socket it fits into. Also look at the drum front edge. Should be a plastic bearing strip all the way around the drum opening that just snaps in place. Its in 2 section. If broken or missing replace those also. Thats the front bearing surface..
Apr 06, 2015 | Frigidaire Dryers
Model fde336resi loose drum
There are 2 areas to check for this dryer drum. The back center bearing looks like a small trailer hitch ball which is attached to the drum. It fits into a plastic socket on the back wall of the dryer. To remove the drum, you need to take the dryer front off and disconnect the belt that goes around the drum. Then use the belt as a handle and yank up the back of the drum to lift the ball of the drum out of the socket. The plastic socket is what usually wears but you can get a complete kit including the ball and socket for about $20. While the drum is out, look at the inside edge of the drum opening. Should be a white plastic bearing strip completely around the opening.If cracked or missing replace those also. Should be 2 strips. Thats all that supports the drum in the front.
Mar 24, 2012 | Frigidaire Electric Dryer
My dryer is a model number GLER341AS2 and when I turn it on it makes a sreeching noise. Now the screeching has turned into a louder noise almost like a rubbing thud.
The symptoms you describe indicate that your dryer drum bearings are faulty: there is usually a large 'felt' bearing around the opening which support the drum and prevent metal to metal contact (screeching noises)- The drum must be removed to get to this front bearing (which is normally glue to the dryer front panel at the drum opening): it is not a trivial job and is not normally replaceable by end-users.
Hope the explanation helps.
Sep 23, 2011 | Frigidaire Dryers
Dryer repair
The ball gets bolted to the drum first. Then the white bearing gets installed on the back of the dryer. Then It all goes back together when you install the drum into the dryer.
May 04, 2010 | Frigidaire GLER341A Electric Dryer
My dryer makes this high pitch screaming noise...what's going on?
In the cradle where the center drum bearing fits is a plastic bearing mounted on a metal bracket. When that plastic bearing wears down the ball begins to contact the metal bracket. Bad things are ahead also. Because now as the drum turn the bracket is cutting into the ball.c44ef56.jpg
A typical Laundry center repair manual
Mar 12, 2010 | Kenmore 98702 Stacked Washer/Dryer
Drum making sqeaky noise
The squeak is the rear bearing mount rubbing on the hanger ball. The plastic bearing is gone and that metal piece is cutting a groove into the ball mount. I have a picture. If the ball will be cut off and the drum will fall into the heating element and the belt will break. Not good!
8a3a785.jpgTo get to this bearing you must pop the top and get the belt loose,lift out the drum and inspect the bearing. The kit is fairly reasonable.This is something that a DIYer can easily handle.
May 11, 2009 | Frigidaire Electric Dryer
Squeaky dryer
The tub rides on a ball in the rear center. The ball sits in a plastic bearing with a metal mount. When the plastic wears down the bearing begins to rub the metal mount. WARNING: procrastination can cause this metal mount to eat into the ball and litterally cut it off causing the drum to fall into the heating element. To repair simply pop the top using a putty knife, remove the front and take the idler loose from a small hatch in the rear. Use the belt to help you get the drum out the front. NOTE. the kit comes with everything needed to make the repairs. If you are frugal the bearing it sold seperately. cd5464b.jpg
Dec 14, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryer bearing
you need to oinstall the bearing little ball and bearing first then install the drum and belt the last thing is to rinstall the 3 screws inside the back of the drum to the bearing this is the easy way rather than tryingto get the bearing in the scoket while on the drum
May 14, 2008 | Frigidaire GLER341A Electric Dryer
Frigidaire GLER341A Electric Dryer Logo
410 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
