Question about Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304)
How to stop others using it
How to stop anyone connecting to our router
    Problem Solver:
  • 5 Answers
you can do that by make it secure by WPA protocol you find this option when you setup your router.you can use installinion guide for your devices to help you or tell me the model of your devices and i well help you.
emmy
Posted on Feb 22, 2009
I was just watching Roku and it just stopped saying "can't connect to the wireless network. Does anyone know what is wrong? I'm using my internet now.
Yes, you are using the Internet, but with other devices. Probably Roku lost its connection to WiFi. Try to reconnect it.
Dec 28, 2014 | Computers & Internet
I am using 3g wireless router buyed from wifi digisol company. can anyone please help me to tell is this product is right for internet communication. for more details related to this product visit htt
Sir
Using 3g wireless Linksys Routers is best router you use for inter net connection,
For customers using the AT&T 3G MicroCell and a Linksys / Cisco router model WRT54G2 or equivalent, the following settings should be made to the router.
NOTE: Changing the broadband router / modem / gateway settings may cause other applications to stop working, and / or change the broadband router security settings for outbound data transmissions. Please see the router / modem / gateway instruction manual for more detailed information.
Procedure
1.Open Internet Explorer and navigate to the router setup page at http://192.168.1.1
2.Enter the User name and Password, click OK
3.Verify the following settings:
Automatic Configuration - DHCP
MTU: Auto
4.
Select the Security tab, verify IPSec Pass through is set to Enable
5.Click Save Settings
I Hope Your Router Linksys Routers Problem Is resolved By now:
In case you need online Linksys Routers help then follow us on for:
Linksys Router Support
Apr 02, 2014 | Linksys Computers & Internet
Samsung Galaxy Core I8260
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
Then make certain all your devices login to the wireless network with the SSID and Key.
Nov 26, 2013 | D-Link AirPlus DI-524 Wireless Router
Blinking lights
when the router looses connection, it is best to just leave it as it tries to reconnect automatically
the blinking lights is the communication process and when connection is made for each section the light stays full on
there should be a on/off button that you just press to restart the searching process or a reset button under a small hole that you use a paper clip to gently press to reset
remember that it is not always the router that looses the connection but the server that it is connecting to
Jul 10, 2017 | Cisco -Valet Wireless Router
Netgear router wireless loses connection
1. Many wireless routers are using the same wireless channel. Many manufacturers choose channel 6 as the default. Change to another channel. 2. Analogue video senders used to send audio and video to other TVs in the home. 3. Microwave ovens emit interference in the 2.4GHz band. 4. Wireless speakers and console controllers can cause interference with the wireless router. 5. Bluetooth devices, newer Bluetooth devices can jump to different frequencies if there is a connection problem. 6. Power cables located near the wireless router can cause dropouts and speed reduction. 7. Fish tanks and mirrors will cause massive Wi-Fi shadow on the other side of the tank from the wireless router. 8. Depending upon the location of large mirrors will reflect wireless signal away your computer. 9. Building materials will block wireless signals such as plasterboards with metal foil, reinforced concrete walls and floors. Also objects near the wireless router such as metal filing cabinets and other electrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performance by 25% when it is close to the wireless router.
Mar 25, 2013 | NetGear WGR614 Wireless Router
Not a problem with router but I need to put a security password in place as I think someone else is using my router.
Go to your IP for that router and put it in Internet explorer.
Most IP's are 192.168.1.1
It may let you set a password up, some do not.
Oct 18, 2009 | NetGear DG834G Router
Continues lost of connection using router
- Kindly make sure you already configure the required ports of emule to your router.
Mar 14, 2009 | SMC Barricade N Draft 11n Wirele Router
Hard Wired Port Problem
please dont assign any manual addresses in ur computer..let it be automatic...
u said that u connected the computer to Ethernet ports in the router...
check whether the light are lit in the router corresponding to that particular port..
check the ip address to that particular computer(hard wired to the router)
ip address should be 192.168.1.100 or 101 or 102..if the ip addres comes in this range means its working good...
if ther is no ip means please follow this steps...
1,connect the blue cable between the computer and the router(any 1 of the 4 ports in the
router)
2,connect the other Ethernet cable between the Modem(came from ur internet people) and the
Router's Internet port(standalone port at the back of the router)
3,In the rear panel of the router u can see the reset button.with the help of the paper or
ball point pen,press it hardly and hold it for 1 minute..
4,Now turn off ur modem and the router..wait for other 1 minute..
5,turn onn only the modem first and wait till all the lights lit.now turn on the router and wait
till the power light is solid..open the internet Explorer it should work..
May 31, 2008 | Linksys Wireless-G WRT54GS Router...
MSI Router connecting well but to some sites
May I suggest you resetting the router by pushing and holding the reset button. Let me know if this works.
Aug 30, 2007 | MSI Wireless-G RG54G3 Router
Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304) Logo
55 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
