Question about Dishwashers
Stainless steel face plate/front cover for a black dishwasher
I bought a stainless steel refridgerator and would like to change the face plate/front cover on my dishwasher to match. Does Whirlpool or any after market company make this item?
  • 3 more comments
  • Anonymous Feb 28, 2009
    I am also looking for a face plate in stainless steel for my bosch dishwasher - anyone have any recommendations?
  • Anonymous Mar 08, 2009
    I have a GE Triton XL Dishwasher with a white face plate and would like to replace it with stainless steel face plate. Who cares replacement parts that allow for this transfer of face plates?
  • Anonymous Mar 30, 2009
    I am looking for a black front cover for a GE dishwasher.
  • Anonymous Apr 14, 2009
    I would like to change my GE profile face from white to Stainless, is there a way?
  • Anonymous Mar 16, 2014
    can i change the front panel to stainless steel
Here you go, there is a company that makes them
http://www.kitchensource.com/kau/frigodw.htm
Posted on Apr 24, 2009
    Champion:
  • 246 Answers
Go to www.applianceart.com - they are SOOOOO much cheaper than frigo
Posted on Jun 09, 2010
Is there a stainless steel door panel replacement for bosch dishwasher shx43c02uc
If there isn't, you might try having a local metal shop cut you a piece of stainless, fold and weld the edges to make a cover for the door and adhere it either with epoxy or a small tack-weld. I wound up having to have a cover made for my Mom's stainless-steel fridge when only white and black ones were available and a metal shop doesn't charge much for it.
Alternately, if the metal panel is housed in a frame, try taking apart the frame, removing the panel and flipping it over. They usually just paint the one side, and if the other side is bare metal, such as aluminum, you can use sandpaper to give it a brushed finish and some clear-coat spray paint to give it that shiny stainless look and durability. Then just reassemble the door with the stainless-looking side facing outwards and the wrong-color side facing in. Worked for Mom's dishwasher!
Aug 31, 2012 | Bosch Dishwasher Door Panel White - 245067
Want to change front panel from cream to black
These guys make dishwasher and refrigerator covers that simply fit over the front of your appliance. They have solid colors, textures, designs and even stainless steel. They even have a product called instant chalkboard which comes in very handy for grocery and to-do lists.
Nov 05, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Can i change the face plate on my GE refrigerator from black to stainless steel?
they do make magnetic front covers for refrigerators. an online search will likely show you someone in your area.
Jan 13, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
How do i change the door panel on an intergrated neff dishwasher
check out www.applianceart.com./ You may not need to change the panel just cover it. They have hundreds of designs and colors and even a stainless steel option
Apr 09, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
I have a frigidaire dishwasher FDB2415LFSO white and would like a stainless steel finish. Are there door panels available for this model?
yes / when changing to ss from white . most people wasnt the black control panel . as it looks best . the cost of the panel and stainless . is costley . and inless dw is newer model . most would look at the cost of a new one .. hple this helps mm
Dec 08, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
The plastic screws to remove the front face plate just turn and
You do not turn them. It is a pin so use some pointey nose pliers to grab the little bar and pull it out. Push them in by hand when you finish but make sure the little bar that you grabbed with the pliers is vertical, just like you found it
Jul 17, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Want to remove front of Asko dishwasher to paint it
usually you can remove the panel with a series of screws. you can tell how old it is by the serial #. depending on the brand the third to fouth #'s should tell you when the unit was made
Jun 21, 2009 | Dishwashers
Stainless panel for Kenmore 3631532 dishwasher?
I have two options for you to consider. One is to take your panel to any sheet metal fabricating shop and have them make a stainless steel version for you. The other is to get a spray can of stainless steel appliance paint and apply it. i have used the stainless steel paint on entire appliances with excellent results.
Jun 05, 2009 | Dishwashers
Want to replace dishwasher panel with stainless steel
Yes indeed! If you know the measurements, you can buy a stainless panel from www.applianceart.com cut to any size you would like. THey also have a cheaper "faux" stainless option too. Many colors and designs as well.
Mar 03, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
I'm not sure if that replacemetn part would work, but I know you can get cheap stainless panels and faux stainless options at applianceart.com. They have colors, textures, seasonal, designs, and stainless steel. You can choose between faux stainless (as seen on HGTV and the Today show) or regular stainless metal. check out www.applianceart.com
Jan 19, 2009 | Kenmore 13593 Stainless Steel Built-in...
Dishwashers Logo
9,794 people viewed this question
Top Dishwashers Experts
