Question about Gaggia Baby Espresso Machine
Baby Twin, Strange Smell and Taste?
My Baby Twin has started making a terrible 'plastic' smell and this reflects in the taste... its awful! It seem to be when you use the steam.... any ideas?
  • Anonymous Mar 06, 2009
    I have the same problem :(
  • 2039 Answers
SOURCE: Coffee not strong enough
our waste coffee is it consistant like stay in 1 round piece or loose lock at it if it lock like it was fine grind i suspect that our machine dont grind fine enough our coffee should have that lovely brownish cream on top maybe grinder need ajustment it wasnt done properly at the compagny and you said you adjusted the dial in the grinder but what about the quatity of coffee look in our manuel fine grounded coffee good quatity of coffee our suppose to get that perfect expresso i think ajust our dial for quatity of coffee thanks for using fixya pierre
Posted on Feb 09, 2008
Coldcut
  • 1554 Answers
SOURCE: Plastic Smell & Taste
take up smoking
and then you will loose you smell and taste.
every thing is made of plastic and aluminum now.
only a stainless pot does not leach plastic cfc into water when hot.
Posted on Apr 02, 2008
rickzilla
  • 706 Answers
SOURCE: metallic taste
Try flushing the system with white vinegar.. see if that helps..
Posted on Sep 23, 2008
  • 57 Answers
SOURCE: strange taste in ice cubes
Did you use new water lines? If you did then clear the icecubes from the tray and use an appliance store cleaning solution to wash it out with. their solution is designed for fridge use and wont leave an after taste......Rinse well...... Also for awsome Ice......Install a large in-line water filter.... Makes mine taste like frozen mountain spring water with no nasty taste or smell. Hope it works for ya!
Posted on Jan 04, 2009
  • 400 Answers
SOURCE: ice maker has bad taste and smell
Add a cap of Miltons or a couple of granules of pool chlorine. Allow it to stand for a couple of hours and then drain.
Posted on Mar 09, 2009
Coffee has a bitter, plastic, toxic taste. Even after cleaning and running many cups through new machine
Debris was left in the chamber when manufacturing the unit. Flus and clean accordingly and it will survice.
Dec 27, 2011 | Keurig Special Edition B60 Coffee Maker
We have a strong "plastic"
try washing with vinegar solution. it is just the new factory smell and taste.
Feb 03, 2011 | Samsung Refrigerators
Awful smell and taste to water boiled in a stainless steel kettl
I have the same problem. Noticed it was in two different pots. The comment number one must be correct because I only use VERY high alkaline water to boil my foods. I had a feeling it was my water. So interesting! I will clean it w white vinegar and see if the smell goes away. SAME weird chemical smell- turns your stomach.
May 25, 2010 | Kitchen Appliances - Others
Ice tastes funny and a strange metallic or plastic type smell
Sometimes the smell comes from something in the freezer or even the refrigeratior and makes the ice taste funny. My suggestion is to clean out the freezer compartment of anything frozen that has been there a while and may have freezer burn. That may be the funny smell you are experiencing.
Hope this will help you.
Jan 15, 2009 | KitchenAid KSRS25IL Side by Side...
Strange taste in ice cubes
Jan 04, 2009 | Jenn-Air JCB2388G Side by Side...
Just because its made of plastic doesn't mean it should taste like plastic! The engineers made a mistake in design! Get your money back and don't risk taking in carcinogens!
Feb 25, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
New danby kegerator - tastes like rubber hose
There is a check valve inside the coupler of the danby kegs that cause this problem. The valve is mainly there to prevent beer from back-flowing when changing the keg. Next time you change your keg check for a little black plastic retainer and also a small white plastic ball inside the coupler. Remove those (or just smell it) and you should notice that this is the taste/smell your beer has. I removed mine after this discovery, and there isn't any issues with the taste/smell since. I've heard this is a common issue with the Danby D coupler systems. Also, you won't have any issues with beer backflow when you change the keg, provided the line going to the tap is empty (which usually is if keg is kicked).
Dec 30, 2007 | Danby DKC646BLS Full Size / Pony Beer Keg...
Gaggia Baby Espresso Machine Logo
143 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
