Question about Canon FAXPHONE L80 Laser
Paper sticking together when receiving a fax
I have a Canon L-80 fax machine. When receiving a fax, it seems that most of the time five or six pages will stick together when only one page is received. Any suggestions??
  • 318 Answers
There is a separation pad under the feed roller,that pad needs to be cleaned or replaced.If you open the fax and remove the cartridge,inside at the back were the cartidge was you will find a roller,cleen that roller.Under the roller there is a strip of rubber-the separation pad.Take a ruller cover it with a cloth and use it to clean the sep assembly under the roller.If the problem pressist the sepparation needs to be replaced.
Posted on Feb 27, 2009
When receiving large faxes, it prints a blank page (numbered in succession though on the top as __ of __) in between each page of the fax. How do I stop this?Canon LaserClass 9500 -- When receiving l
What size paper is set as default on your end? If legal size, that may be why. Also- how quiet is the telephone line? If it is getting interference from a close proximity flouorescent light, or just noisy, it may be the noise being interpretted as a new page break.
If it is set up to autoselect the page size, look at noise as a possibility. If it is only a random occurance, it may be as simple as the paper itself sticking together slightly, (if it sticks together on the other end, there is not much you can do about that.) or the pickup feed may need the rubber tires cleaned.
If it only happens from one or two numbers and not others, it is likely line noise on either end. On your end, you can install some ferrite beads to reduce it, if on the other end, they will need to do it.
Apr 11, 2012 | Canon Office Equipment & Supplies
I using a roller fax machine. today i had fax a documents that have 4 pages and i put together and let it run auto. i confirmed that i fax once only but the receiver received the first page more than 10...
By "roller fax" if you mean auto document feeder, so what's the problem? If you didn't see each of the 4 pages feed into the machine one at a time then what happened at the other end could be because something happened at your end. It's the reason we scan and email most critical documents today.
Carl
Apr 14, 2011 | Office Equipment & Supplies
Sir, can anyone help me with my fax (canon fax l295)for a problem, it was always indicating that "load paper" even though i put paper on the tray once it was start feeding it makes an paper jam error and...
You either have a paper path blockage or your feed rollers are worn. You'll need to take it apart to check though. Try removing paper, turning machine off and on and re-inserting paper. Remember to fan (separate) paper before loading, it could be static causing the sheets to stick together and jam in the machine.
Jun 11, 2009 | Canon L295 Plain Paper Laser Fax
When receiving a fax, it seems that several pages of paper always
you mean you're getting 1 or 2 extra sheets when machine is printing faxes? Feed roller and separation pad that pull paper from the tray are worn.....cleaning will help in the short term.
Feb 22, 2009 | Canon FAXPHONE L80 Laser
Two pages print
Paper could be sticking together or paper is set up for 14 inch and you are running 11 inch paper...
Aug 07, 2008 | Brother IntelliFax-2820 Laser Fax
Canon Fax-JX200
First, you may be dealing with two separate and distinct problems - or did they both start happening at the same time? In regard to the beep on scanning of faxes, the first thing to check is the machine memory. If you are storing documents, there is a limit of 30 documents (60 pages maximum). If the memory is not sufficient to allow for scanning the material you are attempting to fax, this will create that error. You should still be able to send the fax manually (directly) rather than through memory, if you need to retain all the documents in memory.
Regarding the paper jam, make sure you have checked every area of the machine for any little scrap of paper or other residual that may have been left in the machine along the way. As you have the manual, follow the cleaning and maintenance instructions to make sure everything is clean and in proper working order.
Then, I would also suggest that you physically unplug the unit from the power source for at least five minutes, if the problem has not been solved. Then plug it back in and see if this has cleared the internal error. If it is not cleared, your FINE cartridge should be checked and/or changed, and the manual gives good instruction on this as well. Make sure your paper is of proper quality and is not bent or sticking together, etc. According to Canon, if these things do not solve the problem, the unit may need service. However, please let me know where we stand and we'll see what else we might try if this does not resolve your issues.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Jul 21, 2008 | Canon FAX-JX200
All Fax pages not received or sent.
have you watched the paper going through the doc feeder are thay goning one by one or is it pulling more then one. try making a copie withe 4 sheets does that work. if not open cover of doc feeder clean rollers. serperation pad. ( pad would be twrods the top of the cover )
C.W.H.
Jul 21, 2008 | Canon LaserClass 2050 Plain Paper Fax
Check paper size comes up all the time. Also pulls anywhere from 4 - 10 blank pages through at once.
dear sir pleaz select the correct paper size in the user data programing of your machine
Sep 10, 2007 | Canon FAXPHONE L80 Laser
Canon FAXPHONE L80 Laser Logo
128 people viewed this question
old marine
old marine
