Question about Canon FAXPHONE L80 Laser
When receiving a fax, it seems that several pages of paper always
Any solutions for paper always sticking together when receiving a fax ?
You mean you're getting 1 or 2 extra sheets when machine is printing faxes? Feed roller and separation pad that pull paper from the tray are worn.....cleaning will help in the short term.
Posted on Feb 27, 2009
When receiving large faxes, it prints a blank page (numbered in succession though on the top as __ of __) in between each page of the fax. How do I stop this?Canon LaserClass 9500 -- When receiving l
What size paper is set as default on your end? If legal size, that may be why. Also- how quiet is the telephone line? If it is getting interference from a close proximity flouorescent light, or just noisy, it may be the noise being interpretted as a new page break.
If it is set up to autoselect the page size, look at noise as a possibility. If it is only a random occurance, it may be as simple as the paper itself sticking together slightly, (if it sticks together on the other end, there is not much you can do about that.) or the pickup feed may need the rubber tires cleaned.
If it only happens from one or two numbers and not others, it is likely line noise on either end. On your end, you can install some ferrite beads to reduce it, if on the other end, they will need to do it.
Apr 11, 2012 | Canon Office Equipment & Supplies
I have an HP 8500A printer/scanner/fax. Everything works but the fax. I can receive but I can't fax out. I get error 348, 321 & 358.
Hello and Welcome to FixYa!
Sir/Ma'am these error are basically due the Communication error of Receiving/Remote Machines. But each error shows different meaning.If during fax you receive the Error 348 then it may be because of several reasons like:-
  1. The remote machine failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise,Other reasons can include power outages and other power-related problems.
  2. When The call-waiting service can cause this error or the remote user pressed the Stop key while the reception was in progress.
You can solve the Error 348 by the following
  • Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
  • Disable ECM. Errors might still occur, and might result in a degraded image quality on the received page. However, the ability to send the entire document will be improved.
  • Try sending at a lower transmission speed.
If during fax you receive the Error 321 then it is because of:-
  1. There was a communication error with the receiving fax machine due to poor telephone line conditions.
You can solve the Error 321 by the following:-
  • Set the receiving machine to receive at a slower transmission speed
  • If the session fails after sending several pages of a large document, resend the document as several smaller documents.
If during fax you receive the Error 358 then it is because of:-
  • The remote user pressed the Stop key, causing the session to be terminated.
  • The remote machine encountered a system problem such as no paper or a paper jam. This prevented the fax from receiving any more pages, and caused it to terminate the session prematurely.
  • The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
  • The remote machine encountered an incompatible feature causing it to terminate the session.
You can solve the Error 358 by the following:-
  • Configure the remote machine for document reception by clearing any paper jams, loading sufficient paper, and clearing any other error messages.
  • Configure the local fax machine to use a slower reception speed.
  • Enable or disable the ECM setting.
I hope this solution helps you and you have clear picture in your mind.
Let me know if you have any confusion in your mind
Sir/Ma'am, Your Rating as Five Stars for this solution and Words of appreciation as Feedback for me will be really esteemed
Thank You for taking my service
Concerned: Muhammad Uzair Team : FixYa
Dec 05, 2011 | HP Photosmart 2710 All-In-One InkJet...
I need assistance with fax error codes # 322 and # 358. What do they mean?
Error code 322- There was a communication error with the receiving fax machine due to poor telephone line conditions.
Solution
Error code 358--
Try
Disable ECM mode on your machine.
Try sending a fax to another location.
Mar 03, 2010 | HP Officejet Pro L7680 All-In-One Printer
Sir, can anyone help me with my fax (canon fax l295)for a problem, it was always indicating that "load paper" even though i put paper on the tray once it was start feeding it makes an paper jam error and...
You either have a paper path blockage or your feed rollers are worn. You'll need to take it apart to check though. Try removing paper, turning machine off and on and re-inserting paper. Remember to fan (separate) paper before loading, it could be static causing the sheets to stick together and jam in the machine.
Jun 11, 2009 | Canon L295 Plain Paper Laser Fax
Pages sticking together when transmitting
This is caused by the feed and separator rollers are dirty or worn out. The simplest thing to try is to clean the feed rollers. you will need a cleaning solution, isopropal alcohol works very well. Available at local drugstores. you can approach this one of two ways, you can open up the document feed section and manually clean the rollers or put a few drops of Alcohol in the center of a piece of paper let it soak in a little and pass it through the document feeder, the paper should have a streak on the last half of the page if it made contact with the rollers. For best results do this a couple of times, for better results do both the manual and the pass paper methods.
Hope this is of some assistance.
Ed
Apr 20, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Paper sticking together when receiving a fax
There is a separation pad under the feed roller,that pad needs to be cleaned or replaced.If you open the fax and remove the cartridge,inside at the back were the cartidge was you will find a roller,cleen that roller.Under the roller there is a strip of rubber-the separation pad.Take a ruller cover it with a cloth and use it to clean the sep assembly under the roller.If the problem pressist the sepparation needs to be replaced.
Feb 22, 2009 | Canon FAXPHONE L80 Laser
Fax double feeds sheets
This may occur if:
-the paper is too thick or too thin
-the roller mechanism is not properly aligned or has worn out
-the sheets of paper stick together
things you can try:
-unload the paper in the main tray and bend the stack of paper to loosen it up. Reload the paper to the main tray
Hope this helps!
Feb 17, 2009 | HP 1240 Plain Paper Inkjet Fax
Two pages print
Paper could be sticking together or paper is set up for 14 inch and you are running 11 inch paper...
Aug 07, 2008 | Brother IntelliFax-2820 Laser Fax
All Fax pages not received or sent.
have you watched the paper going through the doc feeder are thay goning one by one or is it pulling more then one. try making a copie withe 4 sheets does that work. if not open cover of doc feeder clean rollers. serperation pad. ( pad would be twrods the top of the cover )
C.W.H.
Jul 21, 2008 | Canon LaserClass 2050 Plain Paper Fax
Sending faxes
SEEMS THE RECEIVING FAX IS SET ON AN EXTENSION , SO U WILL HAVE TO FOLLOW THE PROCESS. HAPPY FAXING OMNIPRESENT
Sep 05, 2007 | Panasonic KX-FHD331 Plain Paper Thermal...
Canon FAXPHONE L80 Laser Logo
82 people viewed this question
old marine
old marine
