Question about PfaFF Quilt & Craft Pro 7530
Where can I find needles for my hobbylock 794? The machine says # DBX1 no. 9-16.
  • 3 Answers
I have a Hobbylock 797 and that takes standard 130/705H sizes 11-14
Posted on Mar 05, 2009
Pfaff hobbylock 4842 serger - how to thread
here is a manual:
PFAFF hobbylock 4842 Instruction Manual
Be sure to ALWAYS RAISE the presser foot when threading the machine. Also, thread each thread in the ORDER specified or your machine will most likely never stitch correctly (usually, the upper looper first, lower looper next, and then the needles).
Jun 14, 2017 | PfaFF Sewing Machines
Where to find a Replacement Spool Holder for Pfaff Hobbylock 794
Pfaff Hobbylock 794 Parts
You can also try eBay. If not lucky there, try finagling one using a nail with a drinking straw over the nail to hold the spool.
Jul 17, 2015 | PfaFF Sewing Machines
I can't find the way to change the left needle.
You can order a manual here - http://www.sewusa.com/Sewing_Machine_Manuals/Pfaff_Manuals/794_796_Hobbylock_Instruction_Manual.htm
In the meantime, contact your local Pfaff dealer. Ask if someone can help you if you bring the serger in.
Mar 18, 2010 | PfaFF Hobby 4260
Price of hobbylock 794 in todays market.
Price depends upon how much the machine has been used & what condition it is in. My hobbylock 794 has barely been touched since it was first made and they advised I just throw it out instead when I took it in for a little 'freshening up' at Quality sewing & vacuum in Washington! Everywhere else I've had great feedback that this is a good serger, so check out what similar machines are selling for on Ebay... you could get $100~$400 for your trusty serger {depending on supply & demand}.
Mar 27, 2009 | PfaFF Hobby 4260
How do you get the blades to cut on a hobbylock 794 serger
It should just cut. Don't know too much about this machine as I'm new owner, but from what I can gather, either you need a new blade, or the upper knife is disengaged. The metal knob inside the threading area should be turned downwards, engaging the upper knife. The upper knife doesn't usually need replacing unless damaged, apparently. Hope this helps somewhat.
Dec 04, 2008 | PfaFF Hobby 4260
Hobbylock 794
You have a timing problem which needs a technician to repair. to do this properly, you need some special gauges which, generally , are not found just anywhere. Take it a technician and get an estimate before you leave it.
sewman7
Oct 27, 2008 | PfaFF Hobby 4260
Hobbylock 774
If the needle bar is no longer available, the current needle bar can be repaired by cutting new threads in it and changing the screw. Not simple but not rocket science either.Most mechanics can do this.
sewman7
Aug 08, 2008 | PfaFF Creative 7570
Pfaff hobbylock 794
The needles are changed by inserted the hex wrench into what looks to be holes on the front and left side where the needles go into the machine.I'm not sure what size the hex wrench is but it's pretty small. From the manual,
"Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out." and
"Inserting needle: When the neddle bar is at the highest position, insert a new needle in the needle holder, making sure that the groove of the needle faces you. Push the needle as far up as it will go and tighten the needle clamp screw." "Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out."
The machine takes DB x 1, or 1738 needles, and a size 14 needle is recommended.
Hope this helps!
Mar 31, 2008 | PfaFF Hobby 4260
Sewing Machines Logo
479 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
