Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
What should the PSI be? Amanna ARS2464BW
What should the PSI be on the low side the of the compressor. The refrigerant is r134a?  ..........Thank You.
  • Amana Master
  • 3,361 Answers
About 3 psi if the box is cold.
Posted on Feb 22, 2009
What is the gas pressure on both compressors on subzero 321
The pressure of the refrigerant in the systems vary depending on the temperature of the refrigerant gas and the type of gas used. So this is a question that can't be answered without a lot of additional information.
Mar 02, 2015 | Refrigerators
How many gas pressure need in whirlpool refrigerator 220 ltr model
Rathish,
You are asking a very vague question. I will attempt to help you but I will have to assume a few things. Like: This is a residential frig, that uses R134a refrigerant, and the compressor is no larger that 1/4 H.P.
In this case what you are looking for is ABOUT 3 to 7 PSI on the LOW side or the suction side. High side could be 160 to 210 depending on many factors. Be careful!
Oct 11, 2013 | Whirlpool Refrigerators
Where is low side of a/c system to cahrge with 134
The low pressure side of the r134a system is always located on the thicker pipes vs. the thinner pipes leading away from the compressor.
So, just followi the larger diameter piping from the compressor until you come to a quick connect fitting that attaches to the hose quick connector that is attached to a can of r134a.
The pressure reading should be 25 psi to 45 psi on the low side when the compressor is turning and the a/c is on.
If it's higher than this, the compressor may not be turning, and the normal non turning psi is 75psi to 100 psi or so on a hot day.
Aug 26, 2010 | 1999 Jeep Grand Cherokee
Where is the ac lowside port located on a 2005 gmc savanna van
The low side port of the 2005 GMC savanna Van is located on the low pressure side of the compressor.
This is found by locating the compressor driven by a belt that has a clutch that engages and disengages as the a/c cycles.
The low pressure piping is always in the larger diameter piping, and the high pressure side is always contained in the smaller diameter piping.
Therefore, follow the thick pipes from the compressor up to the accumulator, which looks like a large can of soup. On the accumulator receiver/drier is a port that connects to the tube that is connected to the can of r134a freon refrigerant.
Simply quick connect the tube to the low side port, which is located on the 'thick' tubing or on the accumulator and then fill until the low side pressure is 25 psi to 45 psi while the compressor is running.
When the car is off and the compressor is not running, the pressure should be 75 psi to 100 psi on a hot day.
Hopefully the system doesn't have a leak slow or fast in it.
Aug 17, 2010 | 2005 GMC Savana
The air is blowing out hot. how fo i fix
If the a/c compressor clutch is not engaging, then the freon or r134a pressure may be low.
Pressure on the low side should be 25 psi to 45 psi.
Since your car is a 1990, it may have been made before r134a was used and may require an r134a retrofit kit that includes oil, r134a, and adapters to update the a/c.
R12 used to be used but is very expensive and requires a certified techncian and recovery and recycling equipment to use, and probably would leak out faster than the r134a system.
Aug 10, 2010 | 1990 Chevrolet Corvette
Were di i recharge the ac on my car
if it is the 3.4 v6 the low side is on the passager side behind the motor. it should have a blue cap on it, and the low side is the fatter of the two ac lines
Aug 08, 2010 | 1994 Pontiac Grand Am
1984 honda accord AC problem, Clutch does not engage fuse good
The clutch will not engage unless there is sufficient refrigerant in the system.
I believe the 1984 Honda originally had r-12 which is largely illegal in the U.S. nowadays in that a certified mechanic must recover and recycle that kind of refrigerant.
I would recommend that you convert it to r134a if you can afford to do this, by putting new fittings on for a quick connect on the low side.
Add about 2 or 3 cans down at the compressor's low side (low pressure) which has larger pipes than the high side (high pressure).
Charge until the hose says you have 25 psi to 45 psi on the low side while the compressor clutch is turning.
good luck to you on this problem.
Jul 08, 2010 | Honda Accord Cars & Trucks
I want to recharge my air conditioning in a 1991 cadillac deville
Here's what you do.
Get an R134a recharge kit or R134a recharge hose (with an optional gauge) that has the adapters to put on to the low side port located near the firewall on the passenger side.
If the system is down already, the computer may have disabled the compressor.
To reenable the compressor, disconnect the battery for a few minutes and reconnect.
Charge the system with about 2 or 3 11 oz. or so cans of R134a while the car is running and the temperature is set to the lowest (say 60 deg. F).
If your recharge hose has a gauge on it, the right pressure should be in the green area ranging from 25 psi to 45 psi on the low side when the compressor is running.
Jun 10, 2010 | 1991 Cadillac DeVille
2004 lincoln town car v8 What is the type of refrigerant and what is the psi
R134A, system low side should be at 28-32 PSI when compressor is running, it should kick off at about that pressure and then re-engage at 38-42 PSI, high side depends on the outside temp and humidity..
Jun 08, 2009 | 2004 Lincoln Town Car
(Frigidair refrigerator R134a system) 3 months after a new compressor was installed it stopped cooling, it leaked. I found and repaired the leak. Then bought some automotive R134a it had dye,conditioner,...
The stop leak probably stopped up your cap tube system and the filter drier.You can try by replacing the filter drier, vacuum the system to 500 microns and recharge.The automotive 134a is the same as any other 134a.
Jun 08, 2009 | Frigidaire Refrigerators
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
217 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
