Question about Makita MAC5200 Electric Powered Air Compressors
Makita MAC 5200 3 HP 5.2 Gallon electric compressor
I have lost the manual need to know what type oil the motor uses.
  • davesouders Feb 24, 2009
    Thanks for the info
    President:
  • Makita Master
  • 1,388 Answers
Use non detergent air compressor oil. It can be found at Lowes, Homedepot, and even Walmart. It is sold in small containers for about $2-3 dollars. A synthetic blend air compressor oil is needed when the unit is used in severe conditions. Synthetic air compressor oil sold at Lowes $6.95 and other stores will take more heat. Second choice is 30w non-detergent motor oil. Engine oils tend to produce carbon on the reed valves in the head if used extensively. I have been using the Lowes Kobalt brand of air compressor oil for some years in my Makita and Rol Air compressors with good results. The part number for Makita brand of oil is 18112-A quart size. It is only available by special order where I live. Good Luck!
Posted on Feb 23, 2009
The proper oil is dependent upon the ambient temp,
-15 to 0C - 10W or ISO32
1 to 26C - 20W or ISO68
27 C up - 30W or ISO100
As noted in the reply above, synthetic blends perform better under heavy use.
Posted on Aug 23, 2012
What type oil for model 90234 4 HP 10 gallon
The model number is not enough info but assuming it's a run of the mill, Home Depot or Craftsman type electric air compressor, you need to buy compressor pump oil at Wal Mart or an auto parts store. Please don't use Automotive motor oil because that's not going to withstand the heat of your compressor pump and you'll be buying a new compressor because of it. If your compressor has a gasoline, 4 Hp. motor, it needs Mobil 1 synthetic and change it after every 30 hours of operation.
May 19, 2017 | HP Air Tools & Compressors
5 gallon compressor tries to start then stops
it sounds like the unloader is not working so it's trying to start with to much head pressure. One cause is a bad check valve another is a bad pressure switch. Those are the more common problems.
Jan 04, 2013 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
We have Ingersoll Rand Type 30 Reciprocating Air at about 20years old.. what type of oil is used in the crankcase?
Almost all compressors use sae 30, you can buy it labeled compressor oil. The key is compressors use a non detergent oil.
Mar 07, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
Mac 5200--what type of oil and how much oil does it take?
Use air compressor oil only, motor oils like 10W-30 will leave carbon deposits on components and reduce their performance and compressor life. No manual lists an exact amount of oil to put in, they just say fill until the oil is half way up the sight glass. It's usually +/- one cup depending on the model, some take as much as one pint. Go by the sight glass for the best performance and to protect your compressor.
Feb 17, 2011 | Makita MAC5200 Electric Powered Air...
Makita 5200 Mac doesn't run
one of two things, either you have a bad start capacitor on the motor or a defective start switch inside the motor, either one can be checked at a electric motor shop
Dec 12, 2009 | Makita MAC5200 Electric Powered Air...
I have a Sanborn 60 gallon vertical compressor ( Blackhawk 5 hp ). What weight oil goes in the crankcase?
there is actually air compressor oil available at most hardware stores be sure it is compressor and not air tool oil
Jul 23, 2009 | Makita MAC5200 Electric Powered Air...
Wiring installation for ss5l5 IR 5hp 60 gallon compressor
A #10AWG wire can be use and 40Amp breaker can be use also. Your 5hp/230V/1/60hz motor amp is 30A.
May 30, 2009 | Ingersoll Rand SS5L5 Ir Electric...
Dont know what kind of oil to put in my makita mac2400r compresso
If your compressor is used all day purchase synthetic blend compressor oil sold at lowes and other stores. It will increase the life of your machine. Sells for about $7. for 16oz. For normal use use standard air compressor oil sold at lowes, home depot and even at wal mart. Wal mart's Super Tech Air Compressor oil sells for less than $3. and works well. Do not use motor oil with detergent as this type of oil causes carbon deposits to build-up in the head and discharge hose which will eventually clog the check valve and lower efficiency. If you remove the plastic sight glass, use caution, because this part easily cracks. Purchase a spare sight glass and keep in your tool box. Good luck
Jan 18, 2009 | Makita MAC2400 Electric Powered Air...
Makita MAC5200 Electric Powered Air Compressors Logo
1,419 people viewed this question
Top Makita Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Makita Air Tool and Compressor Expert? Answer questions, earn points and help others
