Question about Zebra LP 2844 Thermal Printer
Hi, after I run "test print", it only print "q816; q1218,20.."
  • bobsunarta Mar 09, 2009
    My zebra did not print the label (blank) ?
  • manr Mar 23, 2009
    Won't print shipping label
    Prints out
    q816
    Q1218,20
    OD
    D10
    S4
    ZT
    JF
    N
    GW0,14,101,1174
Ur ***
Posted on Mar 18, 2009
Printing blank labels
Hi Sam,
Try running this steps on the printer:-
  • Turn on the printer.
  • Open the printer,remove the labels roll and re-load it again making sure its correctly done.
  • Close it and then turn it off and on.
  • Try printing.If still cant print,
  • Turn it off,press and hold the green feed button and then turn it on.
  • Release button after first flash of led light.
  • The printer runs a print test.
  • Now try printing.
Hope this helps.Thanks!
Nov 03, 2011 | Zebra LP 2844 Thermal Printer
My printer say out of paper
Turn printer off and on.
Check to see if there is a print queue and then load the papers to end the printing.
Try also turning the printer off and unplugging it from power and restarting your PC.
Plug printer back and connect with the PC and then turn them on.
You can also check for paper jams in the paper paths and manually remove any stuck papers.
Run a print test by:
  • Press setup on the printer menu
  • press 1 and then press 4
  • Press start color/start black.
  • Your officejet now runs a print test.
Please rate this answer.
Oct 23, 2011 | HP Officejet 4110 All-In-One InkJet...
Have changed all cartridges on epson nx400. test shows 3 ink cartridges printing, except for the black ink. have run clean head utility, ink has charged. downloaded and installed printer driver. Found an...
Hi
The ink reservoir doesnt have to be completely empty to fail. Replace the cartridges. Some of the jets or all of them may be clogged especially if you have not used your printer in a while. If there are cleaning instructions in the manual clean the jets and then try to print from the printer's self test
Goodluck
Mar 09, 2011 | Epson Stylus NX400 InkJet Printer
Hi my printer won't print black, test colour work but no black, therefore all text to print is blank. I have replaced the ink with a new one and cleaned it 5 times, still no black ink. Thanks
Hi
Clean it manually by removing the black ink cartridge and rub the print head into a paper with rubbing alcohol until ink flows more. Then run the print nozzle to clean the print head thoroughly. After, try to print again.
If not, dip the print head only into hot water for 5 minutes and then run the print nozzle.
Let me know if you need more help
Mar 08, 2011 | Brother MFC 420CN All-In-One InkJet...
Hi, Wonder can you help my printer keeps printing off test page everytime it is turned on. this is only happening since i changed the cartridge, never did this before. thanks
Your printer is printing alignment pages, because the cartridge alignment was not completed since you replaced them. Follow the below steps to complete alignment.
  1. Turn the printer OFF and then turn back ON.
  2. Wait until the alignment sheet prints out fully.
  3. Place the alignment test page over the scanner glass.
  4. Press start color scan button.
  5. The printer "power" light will start flashing, indication the alignment process.
  6. After the printer stops flashing, turn off and then ON the printer.It will not print any test pages further.
We need to run alignment test every-time while we replace ink cartridges.
Regards
Riztech
Nov 27, 2010 | HP Photosmart Premium C309A All-In-One...
MY HP laserject P3005 printer makes alot of grinding noise but prints fine,is there anything i can do
Hi lexdalex,
Test the cartridge, if you have an old cartridge then insert the cartridge and try running a test print. If the grinding noise is gone, then it is the cleaning blade on the cartridge.
Al
Aug 02, 2010 | Office Equipment & Supplies
Xerox Phaser 6350 printer freezes up and restarts by itself.
Hi dpluu:
Try this procedure:
Engine Test Print
Isolate printer hardware problems to either the Engine Control or Image Processor
Board by running the Engine Test print. If the print is successfully printed, focus on
the Image Processor Board or its components (RAM, Hard Drive, Configuration
Card, etc.). If the print fails, refer to Section 4 for print engine troubleshooting help.
1. Press the Test Print button located on the Rear Panel.
2. The printer prints the 600 x 600 test print unless an error status from the Engine Control Board is present. The test button is in the back of the printer and say's Test Print.
Hope this helps
May 22, 2009 | Xerox Phaser 6350/YDT Laser Printer
Monitor doesn't display any thing
Try disconnecting the video cable and connecting it again. Turn on. If that fails, you need to try other fix.
Ok, this fix requires to open the thing. Once open:
1) Remove ONE memory stick. Turn on. If nothing, replace the other memory sick and replace the ONE previously removed. Nothing yet?
2) Check if the processor fan is running. If so, remove the processor from its slot and clean the grids of the heat sink and fan, replace the processor and heat sink and turn the PC on.
Apr 14, 2009 | Computers & Internet
Will not receive print message from computer, will print test pag
Hi there, try to stop and restart the print spooler (control panel/Administrative Tools/Services, scroll down until you find Print Spooler, then double click on it. Stop button and then start), and try to print again. If that didn't solve the problem, it must be a printer drivers problem. Try to roll back the old drivers under printer properties.
Good luck
Mar 30, 2009 | HP LaserJet 1300n Printer
Printout blank
Hi Seng, Run a self test from the printers control panel. 1. Press the printer?s ON LINE button to take the printer offline. 2. Press the Control Panel MENU button until TEST MENU appears on the display. 3. Press ITEM until SELF TEST appears on the display. 4. Press ENTER. The Self-Test will print. 5. Press ON LINE to return the printer to the online state. If it prints than you have a software issue if not it's hardware. For Software Check the Density Settings. Make sure it's not set too light. Also try printing from another app, maybe you have a corrupt print job. If you have a hardware issue come back here and I'll help you sort through those. Let me know, Dude
Nov 23, 2006 | HP LaserJet 4 plus Printer
Zebra LP 2844 Thermal Printer Logo
160 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
