Question about Saeco Classico Espresso Machine
No power outlet is ok, but machine won't turn on
  • Anonymous May 24, 2009
    Machine won't come on.  Outlet OK.  I took an ohm meter and traced the hot side of the circuit and right away, on the first leg from where the cord enters the case, the power wasn't getting to the main switch. There is some sort of fuse located in this line, covered by a heavier piece of insulation - its very small and says something like "microtemp" and then some numbers and letters.  I can hardly read it it's so tiny.  I jumped this fuse with some alligator clips and everything came on again, so I guess that's it.  I need to replace this, I think, for fear of catching the dang thing on fire.  I think my wife might have left it on for a whole day, which might have caused it to overheat.
  • 1,089 Answers
Hi
There is a fuse on top of the boiler that is under a clamp. It is covered by heavy insulation that will slide out of the way. The fuse is a 192C thermal fuse. You should be able to get one from
Radio Shack. It should come with crimps, because you can't solder them in.
Posted on Jul 18, 2009
Sewing machine was shocked it won't turn on when plugged
this is all i can find out at the moment.Check the electrical outlet for power and reset the house circuit breaker if the outlet is dead. Replace the outlet cord if it's worn or damaged. Unplug the sewing machine and check for loose wires. Replace the on/offswitch if it's defective.
Sewing Machine Won't turn on ' Symptom Diagnosis - Sears PartsDirect
https://www.searspartsdirect.com/sewing-machine-repair/symptom/SMAC2200003.html..
or go to this link might help you out.. Sewing machine won turn on Google Search
Oct 23, 2017 | Sewing Machines
Plugein but no power
Check power outlet is working by trying another appliance, if it is ok you will need to either get a qualified engineer to trace the voltage through to see where it's failing. If the power outlet and flex are ok next step is the on/ off switch, and any fuses/safety cut outs . Alternatively if you disconnect it you can check continuity with a test meter . Caution high voltages when connected to the outlet.
Apr 18, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Power won t stay on
1.check outlet to make sure it's ok
2.could be power cord
3.could be connection between power cord and sewing machine
4.could be short in wiring
if it continues, I suggest to have the machine checked
Jan 17, 2014 | Sewing Machines
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
Craig tv plugged in stand by light won't come on and tv won't play
It could be. But make sure the power outlet is ok. Please try on a different power outlet.
Aug 25, 2012 | Televison & Video
Tv won't turn on
Have you checked whether the power outlet is ok? Have you tried connecting the TV to another power outlet? If so, there is a defect inside and should be handled only by a qualified service technician.
Aug 13, 2012 | Sony KDL-52W5100 TV
Siemens xlm1600 drum doesn't turn - motor running - full load of wet washing. Inlet/outlet checked and cleaned - ok. Won't even turn when empty. Whats up?
something jammed between outer drum and inner drum or bearings jammed, if any off these then belt will be burnt Re: Jeff
Apr 12, 2012 | Siemens Washing Machines
Machine won't turn on Hot Point washer, checked outlet ok
Have you tried to run it for a cycle? What exactly does not come on? Is the lid totally closed?
Apr 03, 2012 | Hotpoint VBXR1090D Top Load Washer
The machine won't turn on at all. Tried t in several functioning outlets and it won't power up. Only 6 months old. Keurig B60
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Aug 11, 2011 | Keurig B60 Coffee Maker
Saeco Classico Espresso Machine Logo
124 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
