Question about Maytag Dryers
Light comes on, no motor noise & dryer doesnt start
  • Maytag Master
  • 3,361 Answers
A blocked exhaust vent has caused the thermal fuse to blow.
Replace the thermal fuse and hi-limit switch. They come as a set.
Posted on Feb 22, 2009
Eaton Viking 5 Dryer wont turn on
The door switch is a 3 way switch. Though the light comes on when the door is open the other part of the switch may be out for the dryer to start.
Feb 19, 2015 | Dryers
Electrolux How To Repair
if you are hearing the motor running and it is heating you might have a broken belt
Nov 23, 2013 | Dryers
My Fisher and Paykel Dryer wont spin... The lights will turn on and press start and it makes a noise like it wants to spin, but it doesnt... the last few times I had to mannually move the inside around,...
This usually means that your belt is broken once you replace the belt in the dryer it should turn the electric motor in the dryer and you should be fine
Feb 07, 2018 | Dryers
The dryer doesnt tumble when on.the heating coil comes on and it makes a noise like the motor is on but its not spinning
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Feb 09, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Electric dryer was running fine.had towels in there an opened door to check how wet an noticed it was really hot inside an then closed it an went to pull knob outward to start the dryer again an it...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 28, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Dryer makes a bussing sound when start button is pushed but doesn't start
It sounds like your motor has gone bad....it will buzz really bad when it is tring to start and cannot...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Asker's Testimonial " Thanks so much for your help. Now that you'v mentioned it, the buzzing does sound like it's coming from the motor. I'm,now, more comfortable in call " -
Apr 10, 2010 | Roper Dryers
Maytage neptune dryer wont start
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
Feb 24, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer problem
You need to listen for the motor working ? Open the dryer door hold the door switch in and start the dryer . A buzzing sound may indicate a bad motor. If you hear a slight spinning noise ,it may just be the belt.
Sep 24, 2008 | Dryers
Dryers Logo
59 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
