Question about JVC AV-27720 27" TV
Sound is fine, picture not
I used to be able to jiggle the cable connection and the picture would tune in, but now it's just a few horizontal lines with a partial picture that flickers in and out in one or two of them; screen is 2/3 blank
is it worth taking to a repair shop?
  • 89 Answers
You have a vertical deflecttion chip that is going bad. Probably a LA7832. There is also a good chance that you have a leaky capacitor and bad zener diode. The capacitor is east to get , the zener diode part # is MTZJ75. These repairs are usually best left to a professional
Posted on Mar 12, 2009
Switched from cable to satellite via hdmi cable. Now there are scrolling jagged horizontal lines and no audio.
try running the auto tune program in the set as what you describe may be out of tune for the stations
Sep 05, 2015 | Panasonic TH-42PD25U/P 42 in. Plasma EDTV
Need help with horizontal hold on 1971 Sylvania TV
it is better to use audio video input of your tv .syncronisation problem in the Rf stage cannot be solved easily.
May 24, 2014 | Televison & Video
My AKAI PDP4273M 42" Plasma has thin horizontal lines that flicker across the screen and then the picture jumps and flashes red and green distortions on the screen acts like interfearance of some sort if i...
This sounds like a loose solder joint, or overheated component. I know this may sound like a **** question, but have you tried tapping the TV to see if it goes away? If it does, you will need a tech to re solder the loose component. I have also seen this type of line and color bleed problem, believe it or not from poor cabling or loose connections.
Mar 09, 2010 | Akai PDP4273M Television
Horizontal lines/"snow"
it sounds as iff it the arial connections ?? are the problem check the connections you may need new cable? use 75 ohms cable
Apr 23, 2009 | RCA 20F610TD TruFlat TV/DVD
Horizontal lines on TV when PSP connected
the cable is contaminated, try using another cable.
now i believe there are two red cables on the component cable two jacks for audio and three for video
check those two red jacks and see if they aren't mixed.
Jun 08, 2008 | Sony PlayStation Portable (PSP) Console
Sound but no picture
Basic repair for skilled TV repairman = solder connections on
vertical output IC.........Can be done in home.....T.
Nov 28, 2007 | Sony KV-35S42 35" TV
Flickering of screen (comes and goes) and weird DVD/reception problems
Depending on how old this set is, there might be a bad Hyper board bad. good Luck
Jun 29, 2007 | Toshiba 43H70 43" Rear Projection...
No picture
You have short in the cables and they need to be replaced.
Jun 26, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Beautifull picture except for a jiggling black line in pricure
your tv is having horizontal problem take it to a tech in order that the hrizontak deflection circuit be checked it also might have abad yoke
Dec 28, 2006 | Samsung TXF2899 28" TV
Black comes across right side of screen
Sounds like you've got whats called a cold solder connection somewhere in the horizontal width control circuit or a connection in the sweep section. Should'nt be two expensive but unless you have had some soldering and troubleshooting experience I would leave this on to the pros. Good Luck
Jun 02, 2006 | JVC AV-36D502 36" TV
Televison & Video Logo
42 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
