Question about Sharp Viewcam VL-NZ100U Mini DV Digital Camcorder
Trying to record and display says Eject cassette
When I try to record on tape it won't record it just says Eject The Cassette. Can somone tell me whats wrong with it and/or how to fix it? And also does this camcorder have night vision?
  • dawnwelborn Feb 23, 2009
    I did check the slide lock and it is set to record not save. Any other suggestions?
  • Sharp Master
  • 5,568 Answers
May be a stupid suggestion but check the slide lock on the cartridge to make sure it is in the record position.
'Night vision' is a term applied too loosely; it originally referred to the original 'starlight' scope that uses a special tube capable of actually amplifying light particles (photons).  More recently, the phrase has been applied to devices capable of 'seeing' into the infra-red spectrum. Since too much IR sensitivity affects the quality of any digital camera, the sensors are normally designed to be less sensitive to that wavelength.
The fact that none of the specifications mentions the minimum usable light level is bothersome. Most digital cameras (and camcorders) have 2-3 lux ratings which is not in the category of 'night vision' at all.
Posted on Feb 22, 2009
  • Steve Allison
    Steve Allison Feb 23, 2009
    If you have already tried with another cassette and gotten the same results, then the sensor (which could be optical or mechanical) is malfunctioning.
    About the only thing left you might do, is check the sensor's location in the deck to see if it has some obstruction causing the problem.
    You should be able to find its location by looking in the area occupied by the slide window for a recessed LED/photodetector or a mechanical finger that is used for sensing.
    I think it will be the former LED/photodetector.
    Beyond that, it isn't likely that any user can fix the problem.
Why does the tape get caught in my toshiba rd-xv45kb recorder when i try to eject the cassette and the tape snaps
Not sure about the Toshiba but generally when inserting a cassette it is lowered onto the tape drive. There is a device that will register the presence of a tape which used to commonly be a phototransistor or similar mounted on a short post that is covered by the cassette.
Once the machine knows a tape has been inserted, when play is pressed two vertical rods move towards the heads dragging the tape with them enough for it to make contact with the sound head and wrap part of the way around the video head to make playback possible.
When stop, forward or reverse winding or eject is pressed those two rods move back to the starting position and the surplus tape is wound back into the cassette.
If a cassette ejects leaving a loop of tape that can mostly be pulled out little damaged the reeling in mechanism isn't working. If the tape is jammed and comes free only after breaking the rods aren't returning to the start position.
Engineers use an empty cassette case suitably modified so once the vcr cover has been removed the operation can be observed. The problem might be a worn belt or rubber drive wheel or a problem with the hidden linkages - or it might be an electronic problem.
Apr 22, 2017 | Toshiba Televison & Video
Pioneer CT-W208r won't eject tape.
These dual cassette decks were throw away units in most cases. The belt inside and the grease in the cam mechanism is in bad shape and the deck can not cycle through the steps it need to so as to reach stop. Only stop mode will allow the door block to release. The tape can safely be extracted by a Technician. The deck need work. Dual cassette decks are not always worn the repair cost.
Dec 23, 2013 | Pioneer CT-W208R Single Cassette Deck
Tapes won't go down, and then eject.
Have you tried to force eject the cassette. May be the ribon of the tape has come out. Try using another cassette.
Mar 24, 2009 | Panasonic PV-V4522 VHS VCR
Eject the tape from a Dictaphone 1243 voice recorder
The top cover slides down, and then the cassette should easily lift out.
Mar 15, 2009 | Dictaphone 1243 Handheld Cassette Voice...
Zenith xbv713 won't record on vhs tape
is the tab on the cassette in place? if it has been removed the cassette will eject automatically when pressing the record button.
Jan 05, 2009 | Zenith XBV713
My Camcoder says eject the cassette
Use a Sony head cleaning tape they work perfectly and you let them run there 10 second corse. Then your sharp will run perfectly...
Dec 20, 2007 | Sharp Viewcam VL-Z7U Mini DV Digital...
D-eject problem
try cleaning tape? maybe tape path is outta balance. try new tape?
Dec 14, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
My ZR30mc video recorder will not eject cassette
Take the side panel off to see whether the tape is damaged and will not retreat into the cassette ( this will prevent ejection ). Remove old damaged cassette and insert new one. If the unit chews the new cassette camera should go in for VTR service.
Sep 01, 2007 | Canon ZR30MC Mini DV Digital Camcorder
Sharp Viewcam VL-NZ100U Mini DV Digital Camcorder Logo
323 people viewed this question
Top Sharp Video Cameras Experts
NOEL
NOEL
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
