Question about HTC Touch P3452 Smartphone
Will not boot up
Replaced battery and phone will not boot up. it asks if i want to restore default and loose all user data. i press no but nothing.....i press yes and it starts to laod but at the end goes back to the screen asksing me to do the same thing
    President:
  • 1,223 Answers
Hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if not solved then go to www.htc.com for latest Rom update downlaod and update backup ur data first
Posted on Feb 23, 2009
I need forget security code
hi Sunil kumar
try this one
note all data will be deleted
*#7780# FOR SOFT-RESET- does not delete user info such as contacts, sms, etc
How to do it:
- at Standby Screen type-in => *#7780#
It will ask for "Restore all phone settings-phone'll restart...."
Then it asks for security code enter factory default => 12345
*#7370# FOR HARD-RESET- deletes all user info
How to do it:
- at Standby Screen type-in => *#7370#
FOR FLASHING- TOTAL RESTORE: (Do this if your phone does not boot up) - you can say this one gives you the "New" OS, and of course deletes all user info
How to do it:
1) Remove the battery, and then wait for about 20 min or so before putting it back
2) Press and hold these three keys together -Green dial key, Star key[*], Three key [3]
3) switch ON the phone.
4) Do not let go the three keys until you see the WELCOME screen displayed and just let it complete the boot process
Jul 07, 2014 | Nokia E63 Cell Phone
Tip
How To Reset Your Sony Ericsson Vivaz
<b>Factory Reset</b><br />This will delete all user data.<br /> <br />Soft reset to delete user data, such as contacts, messages, and downloaded games:<br /> <ol> <li>Tap <b>Dialer</b> and enter <b>*#7780#</b>.</li> <li>Tap <b>Yes</b> to restore all original phone settings.</li> <li>Enter the lock code (0000 by default) and tap <b>OK</b>.</li> <li>The phone restarts.</li></ol> Hard reset to delete user data and all settings:<br /> <ol> <li>Tap <b>Dialer</b> and enter <b>*#7370#</b>.</li> <li>Tap <b>Yes</b> to restore all original phone settings.</li> <li>Enter the lock code (0000 by default) and tap <b>OK</b>.</li> <li>The phone restarts.</li></ol>
on Feb 15, 2011 | Sony Ericsson Vivaz Cell Phone
What is a problem when My Phone does not displaying the keypads when im trying to type sms or mms
Software of your phone is corrupted. easiest way out is to factory restore your phone....BUT THIS WILL EREASE ALLL USER DATA INCLUDING PHONE BOOK ENTRIES STORED IN THE PHONE MEMORY....However sim and memory card data will not be effected.........to do this...go to settings and select restore factory settings/full factory restore...ur phone will ask for security code....for code refer user manual..or enter code that u have previously changed.......if this fails then switch off phone,....remove battery....reinsert battery....press volume up,and Power button for about 15 seconds.........till boot mode appears and u get some text written on screen....using volume up key scroll thru the text and select erase all user data/restore....now press power button for about 2-3 seconds......process begins........restart phone.......this should solve the problem...........but if still problem persists then u will have to visit a service person who will flash ur set using special tool loke...volcano box.
May 20, 2014 | HTC Hero Smartphone
Why won't the number 1,0 and space bar button work?
Have you tried a battery pull...... restart by removing the battery while your device is Powered On , try it and see if you're able to access your keyboard . you can try factory default to reset phone ...When you restore the factory default settings, all personal settings are reset. Follow these instructions to restore the factory default settings.
All phone data will be deleted. Data on your SIM isn't deleted.
1. Find "Security Wipe"
  • Press the Menu key twice.
  • Scroll to Options and press the Navigation key.
  • Scroll to Security and press the Navigation key.
  • Scroll to Security Wipe and press the Navigation key.
2. Restore factory default settings
  • Highlight Emails, Contacts, etc., User Installed Applications or Media Cardand press the Navigation key.
  • When the box next to the menu item is ticked (V), the selected data will be deleted.
  • Highlight the field at the bottom of the display and key in blackberry
  • Scroll to Wipe and press the Navigation key to restore the factory default settings.
  • Follow the instructions on the display to set up your phone and prepare it for use.
May 13, 2014 | RIM Blackberry Curve 9320 Smartphone -...
How do i unlock security code from my Nokia
check
How to do it:
How to do it:
How to do it:
master reset ^_^
Apr 22, 2014 | Nokia 2690 Cell Phone
Tablets wont boot up just shows arnova on screen and shuts down
I had same problem looping startup just showing Aenova screen, i tried the pin thing ended up doing a factory reset IT WORKED WAHEY!!
How can I do a Factory Reset on my tablet? If your tablet freezes often or if you get error messages during the start up of your tablet, you can use the recovery mode to reset your tablet to its factory settings, removing all installed applications as well as any data or content.
Your tablet must be up to date with the latest firmware - downloadable from the downloads area of this website.
To access Recovery mode on the ARNOVA 10bG3
To access to the recovery mode:
1. Hold down the volume button + and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button +.
The ANDROID green robot is displayed.
3. Once the ANDROID green robot is displayed, press simultaneously the volume button + and the ON/OFF button.
The Android system recovery screen is displayed.
a. Use the volume buttons to navigate
b. Use the ON/OFF button to select an option
To restore the default parameters of your tablet:
1. In the Android system recovery, select Wipe data/factory reset;
2. Select Yes -delete all user data.
3. Select Reboot system now.
Your tablet reboots. Redefine your parameters through the wizard.
Your tablet is restored to its default settings.
To access Recovery mode on the ARNOVA 9G3
1. Hold down the Home button and press the ON/OFF button.
2. Once the ARNOVA boot logo is displayed, release the Home button.
To access Recovery mode on the ARNOVA 8cG3/8bG3
1. Hold down the volume button - and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button -.
Sep 16, 2012 | Tablets & eReaders
My micromax x600 mobile asking input phone lock code
visit www.hard-reset.com or see the result.Hard reset
Cold boot method: Hold the "Power Button" of the Pocket PC with one
hand while holding the stylus tip to push in the "Reset Button" with the
other. Simultaneously release both the "Power Button" and "Reset Button".
Appropriate situation: If a previous reset has already been attempted and
the Pocket PC is still unable to maintain normal operations, has no
response, or if the screen is frozen.
Before executing the preceding "Cold boot method", please carefully
consider the following instructions and then decide on the cold boot
method.
1. After a cold boot is performed, if no buttons are pressed, when Pocket PC automatically completes the system startup process, the last display will be the Today screen. This is identical to the reset result.
2. If a previous reset has already been attempted but the Pocket PC is still unable to maintain normal operation, consider the following solution:
After cold boot, hold the End Button eten_glofiish_x600_hard_reset_soft_reset_5.jpg on the bottom right of Pocket
PC until the system inquiry screen is shown, and then release the End
Button. Next, please read thoroughly through the instructions on cold
booting before continuing carefully.
Erase all data and load default?
The default is "No." If Yes or No was not
selected, after a few seconds the system will
automatically execute the default No.
If you long press Left Soft-Key for a few
seconds to select "Yes," then the system will
erase all data and load default. After your
Pocket PC restarts, follow the instructions on
the screen to complete.
Caution!
1. After performing a cold boot, the system will retain Microsoft Windows
and pre-installed programs. If you answer "Yes" to the question displayed
after a cold boot, other items such as the user's input data, newly installed programs and user settings will be lost.
2. There are two ways to retain your data, loaded default and registry:
Perform a Reset.
Performing a Cold Boot, and answer "No" when the above question
displays.
Jun 27, 2012 | Eten E-Ten GloFiish X600
I forgot my keypad lock password. is ther any way i can reset it or something
hi this is the steps how to reset your phone
REMEMBER:All User Data such as contacts, messages, pictures, videos, and music will be permanently deleted. Ensure that the microSD memory card is also removed as it will be erased with the Restore Phone option. To reset the handset, to the factory default settings
  • From the standby screen, press Menu
  • Then Press Settings
  • Press Phone and Press Reset Phone
  • Press Yes to Reset the handset's settings to the factory defaults and Enter the Password then press on OK (Default is last 4 digits of the phone number
To restore the handset, to the factory default settings and delete all data
  • Press Settings and Press Phone
  • And Press Restore Phone
  • Press Yes to Reset the handset's settings to the factory defaults and Enter the Password then press on OK (Default is last 4 digits of the phone number)
  • If prompted, re-enter the Password to confirm then press on OK
thank!
Apr 17, 2011 | Samsung Solstice SGHa887
When i dial a number the phone cuts off and restarts
Please try resetting the phone to default settings and it should work. The default code should be the last 4 digits of your phone number unless you have changed it.
Restoring Phone Memory to Factory Conditions
This returns all settings to their factory default value and erases all user data including pictures, video, music, messages, contacts and downloaded applications stored on the phone.
  1. From the home screen tap MENU.
  2. Tap Settings & Tools.
  3. Scroll th screen up and tap 7.Phone Settings.
  4. Tap 5.Security, You're prompted to enter the lock code.The default lock code is the last four digits of your telephone number.
  5. Enter the Lock Code and tap DONE. The security menu appears in the display.
  6. Tap 5.Restore Phone. A prompt appears in the display asking if you wish to restore default settings and erase all user data including pictures, videos, music,messages, contacts, and downloaded applications stored on the phone.
  7. Tap Yes to reset and restore default settings or tap No to return to the Security list.
Mar 15, 2011 | Samsung Glyde SCH-u940 Cellular Phone
I need to format my mobile sony ericsson vivaz HD 8i plz
Master reset for Vivaz
Restore phone to factory default settings
Restoring your phone can be useful if you lend out the phone or just want to restore your phone to factory default settings and delete all user data.
To make a soft reset to delete user data, such as contacts, messages, and downloaded games:
  1. Tap Dialler and enter *#7780#.
  2. Tap Yes to restore all original phone settings.
  3. Enter the lock code (0000 by default) and tap OK.
  4. The phone restarts.
To make a hard reset to delete user data and all settings:
  1. Tap Dialler and enter *#7370#.
Note: When making a hard reset of all content, you may lose content that was in the phone when you purchased it.
Hope this help and if this helpful RATE please.
Feb 09, 2011 | Cell Phones
HTC Touch P3452 Smartphone Logo
134 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
