Question about Epson Stylus CX6600 All-In-One InkJet Printer
Won't read Cyan cartridge
My printer won't read a new Cyan cartridge. Actually, it told me it was empty but it wasn't. I replaced it, and it won't read. I have unintalled the printer, reinstalled it, removed the USB, replaced it, nothing works. Help please!!!!
  • cedarstrip Apr 27, 2008
    Error light (exclamation point) is on (red)
    Display screen reads "Error"
    "Cyan ink out - replace cartrige press color button to begin"
    I have replaced the cartridge, restarted everything.. Printer responds to nothing.. always comes back to this error condition..
  • Anonymous Mar 18, 2014
    new cartridge but printer is saying to replace cyan
    Scholar:
  • 161 Answers
The cartridge could be bad. The cartridge might not be in slot well. And the printer could also be bad. The software might need to be uninstalled and then reinstalled restarting your computer several times as well to reset everything. Try downloading printer drivers and software from printer maker support page. Check for known solutions at the printer site.
Posted on Aug 06, 2007
Hi, I have re-filled the black toner cartridge, but the display says it is still empty. The red light is on and it won't print. Any suggestions please? Many thanks.
you need to use the menu on the printer and find the selection that says printer options-> ink cartridge-> new ink cartridge. what happened is you never told you printer that you were installing a new cartridge so it thinks that its still the old one. The printer actually never checks cartridge levels it just makes predictions based on how many pages you have printed.
Jun 30, 2011 | Samsung CLP 300 Laser Printer
My cyan cartridge shows as empty. My black
No. You need all the cartridges installed with functioning chips for your printer to work. The reason why you need all the colors when all you print is black is because a small amount of color prints when you print black. The manufacturers want to make up their R&D costs on the printers by selling lots of expensive ink.
Nov 25, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Light cyan ink didn't work on epson 1400
Get yourself a couple of sets of empty cartridges from cobraink.com.
It is so easy to fill your own from the removable rubber cap, on the top of the cartridge. Not to mention what you will be doing for the environment.
I have been using these for over a year and have saved a ton of money
This man also sells the ink that you will need. ALSO tell him to send them empty, otherwise he will automaticly send them full of "pigment "ink, because you want to use an ink dye
Al C
Jul 22, 2009 | Epson Stylus 1400 InkJet Photo Printer
After installing new cyan cartridge, display reads No Cartridge
look at the ink cartridge and and first see if the ink covers the top of the cartridge. there is a little part of the ink cartridge the best way to explain it, is there is a tab,. that tab goes into a sensor. if the tab has ink on it, then you mostly like have a problem with the sensor itself. but if there is no ink, the printer is correct. i have had several people bring printers with those type of problems, and when they bring the cartridge i look at it, and they are practically empty.
thanks
Jun 26, 2009 | Brother MFC-5440CN All-In-One InkJet...
False error empty cartridge
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Jun 01, 2009 | HP Photosmart C6280 Printer
My Brother DCP135C printer won't read my new cartridges
Do a hard reset on printer to restore factory defaults.
Sep 20, 2017 | Office Equipment & Supplies
Cyan ink was full - now it's empty a day later?
Aug 04, 2008 | Brother MultiFunction Center MFC-440CN...
Screen reads "Near empty Cyan" but I just replaced the Cyan ink cartridge, its full.
If the firmware update doesn't work, you can reset this error.
Unplug unit. Remove offending cartridge. Plug unit back in, wait until all startup noises have stopped. Open lid and reinstall cartridge. This will solve the fault as long as the sensor is working.
Also, please be aware, you should not have to change a cartridge if it says "Near Empty", only if it says "Ink Empty Magenta".
Also, please make sure none of your other cartridges are empty. I have seen this over and over. Two cartridges empty at the same time, and the person replaces one of them but thinks they actually replaced the other one.
Turn the power off and pull all the cartridges out. Look a the side of the cartridge, you should see a window with a little plastic tab sticking out. This tab should be blocked by a black float inside the cartridge. If you cannot see the float, and the tab is clear with no ink in it and no float tab blocking it, it means the cartridge is empty even if you still see some ink in the bottom.
To be sure plug the machine in without any cartridges. When all the noises have stopped, open the lid and install the cartridges. If you're still getting an error saying either a cartridge is not installed or is empty, then one of your cartridges is empty. Redo the previous paragraph.
Oct 05, 2006 | Brother MFC-5440CN All-In-One InkJet...
Epson Stylus CX6600 All-In-One InkJet Printer Logo
132 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
