Question about Gateway MT3705 Notebook
NO AUDIO OUTPUT .DEVICE INSTALLED RED X OVER SPEAKER ON BOTTOM RT CORNER
Hi, go to start search and type cmd search will return cmd.exe right click on this and select 'run as administrator' at the prompt type:-
net localgroup Administrators /add networkservice
press enter then type:
net localgroup Administrators /add localservice
exit
press enter and restart your computer
Posted on Apr 04, 2012
    Filmmaker:
    Uploaded 5 video answers.
  • 98 Answers
Go to Device Manager> Audio> Disable the Audio card>then refresh the list> then restart the comp. If this dosn't work then re-install the driver for it
Posted on Mar 06, 2009
Audio device
Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers. Right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated. If you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply Hope this helps
Jan 16, 2013 | HP Compaq 6730s Notebook
I dont have any sound, I got a message bottom right corner when I click on speaker icon "No Audio Output Device is installed" I think I need drivers for X-220 speakers, I can't find them...
You don't need a driver for the speakers, but a driver for the sound card installed inside your computer. If the computer came with that sound card then you can find the proper driver from the manyfacturer website -> Support section.
Sound drivers need to be reinstalled sometimes after iTunes updates or video game installs.
Mar 02, 2011 | Logitech X-220 Computer Speakers
Sound output is low nowadays even at full volume whereas before it was ok. I didn't change anything with my computer nor did I change my speakers.
Two possible causes.1) Vol Settings changed in windows2) Bad hardware
1) Check your system's sound settings:
For Xp
  • Goto Control Panel
  • Double Click Sound and Audio devices / Sound, Speech, and Audio Devices
  • In device Volume Click Advance
  • Master Volume Control Window will open
  • Increase all the volumes to max, also make sure that Mute us UNCHECKED.
OR
  • From the bottom right corner of your screen in system tray, double click a small speaker icon and open Master Volume Control.
For Vista and Windows 7
  • From system tray (its at bottom right corner of your screen) double click on small speaker icon, it will open Volume mixer
  • Increase the volume to max.
2) If this does not work, then test your speakers by connecting it to some other system and vice versa.
If you get desired sound volume when you connect some other speakers to your system, then you have to change your speakers. And if your speakers are working fine on other system then you may have to purchase a new sound card.
May 17, 2010 | Computers & Internet
No audio
probably audio driver is not installed on your system install it.or it is not working so reinstall it.
Apr 07, 2010 | Compaq Presario 700 470024-192 Notebook
There is a red x next to the speaker at the bottom right on my screen and it says no audio output device installed
it means you need to load the sound driver go to your laptop manfacture website, choose download drivers, choose your device and your operating system and dowload the audio driver and u will be fine.
Jun 21, 2009 | Toshiba Satellite U305-S5097 Notebook
There is no sound coming my laptop. Everything seems operational but there is still no sound being produced. At the bottom right hand corner, there is a white "x" in a red circle next to my speaker icon. I...
Go to Control Panel - System - Device Manager - Sound, video controllers and uninstall the driver. Restart your laptop and reinstall the sound card driver. Good luck.
Jun 13, 2009 | Lenovo 3000 C200 Notebook
No audio output device installed
Where are you checking? In the Device Manager?
Go there and disable the sound device and then reboot and enable it again. (If you get there and see a device disabled, just enable it and check again to see if you have sound).
Try this and report back if you still have problems.
Please be aware that Microsoft has an excellent online troubleshooter for Vista available here
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 02, 2009 | Microsoft Windows Vista Home Premium with...
Gateway MT3705 Notebook Logo
428 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
