Question about Dryers
Electric dyer taking 2 cycles to dry
What used to take 45 mins for so to dry a load of laundry is now taking 1 1/4 hrs at least. Could this be any other problem besides the heater coils?
  • 188 Answers
If there's heat inside the drum the heater coils are ok. Check the exhaust vent, make sure it's not kinked or squished behind the machine and that the outside vent is not clogged with lint. You should feel air blowing freely to the outside.
If there is no heat, first check for 240V at the outlet. If you have 240V, it could be the element, the hi-limit thermostat, the thermal cut-off, the timer, the motor or a wiring issue (loose or shorted)
Good luck!.
Posted on Feb 22, 2009
Takes 2 hrs to run a 45 min cycle
defo a heating element fault or an ntc fault. More likely to be the element though.
Mar 10, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Front load MDE2400AZW takes forever to dry stuff. A regular load takes 1 1/2 hrs to dry,but the heat is on, and it seems to work.
Make sure the lint trap in the door is clean. It has a plastic cover that opens. Disconnect the venting at the rear and run a load, if it works you have a restriction in the hose after the dryer or in the wall past the hose.
Dec 01, 2009 | Maytag MDE2400AYW Neptune Electric Dryer
Smells hot. does not dry. sticks on 20 min all cycles
just a quick suggestion
check your exhaust outside for proper airflow
Oct 11, 2009 | Maytag Neptune MDE7500AY Electric Dryer
Delic ate cycle taking too long to dry
This is normal because the delicate cycle is a low heat cycle.
Aug 01, 2009 | Dryers
Laundry not getting dry
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Jul 18, 2009 | Dryers
GE Harmony electric dryer model DPGT750EC1PL- very little heat - small rattle - takes hours to dry load of laundry... any ideas?
Check the following to address this issue.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 06, 2009 | GE Profile Harmony DPGT750EC Electric...
Dyer LSG7804ABE Gas Stackable very little heat
self help is right .first i would try a load with out the ducting.if you have good air flow and still didn't dry[because now youv'e elimanated the house venting as a possiable.replace your coils
Jan 02, 2009 | Maytag LSE7806A Top Load Stacked...
Kenmore elite smartheat quitpak electric dyer
try drying load with vent tube disconnected may get warm and dusty but if works ok recheck vent completely also be sure vent is not being flattened when dryer is pushed back to wall also remove lower panel(clips along top edge each corner about 3-4 inches in)remove blower housing 2-3 screws and clean housing
Dec 12, 2008 | Dryers
Dyer
hi thanks for the question i would check the venting make sure its clean to the outside if it is clean te check the element on the ge dryer theres 2 elements one could have failed thanks the appliance doc
Mar 24, 2008 | GE DBXR463EBWW Electric Dryer
Dryers Logo
64 people viewed this question
Top Dryers Experts
