Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wf860
My machine is stuck on f-12 i cant get any other buttons to work what do i need to do?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
F12 is an electrical connection problem between the 2 circuit boards of the machine. it may be a loose connection or more likely a new power board required.
Posted on Feb 28, 2009
Washing machine has 1 minute left on cycle stuck door wont open programme not finished
Try the following, may work:
Press the Start/Cancel button together until all the console Led's illuminate
  1. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  2. Default screen should return. Switch off.
  3. Wait for 2 minutes to try the door. If helped click.
Apr 18, 2013 | Hotpoint Ultima WF860 Front Load Washer
I have a hotpoint ultima wf860 washing machine when trying to do a wash it just keeps saying test what is wrong with it ?????
SomeHotpoint's are designed to go into test mode when the start button and the on/off button are pressed at the same time. If you are stuck in Test mode, simply hold the start button down until it comes out of test mode, then hold both the start buttons and the on/off button down until you see 'D:end' (or similar message). Now try a normal wash programme again and hopefully it should be fine. If it goes into test mode by itself, then it may be an indication that there is a real fault, or a faulty programmer board. hope this helps.
Sep 26, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint washer will not start when you press
  1. Press the Start/Cancel button together until all the console Led's illuminate
  2. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  3. Default screen should return and you can select a new programme
May 23, 2010 | Hotpoint Ultima WF860 Front Load Washer
Child lock button is stuck
hold the button in for about ten seconds this should unlock the panel
Sep 06, 2009 | Hotpoint Ultima WF860 Front Load Washer
My hotpoint wf860 child lock button pressed by accident ,now no buttons work want to give fast spin,then wash next load.
Try holding down 'options' & 'select' together the light changes OR 'dry' & 'spin' OR hold down 'end of cycle'. Works for other machines, tell me what did it.
Feb 26, 2009 | Hotpoint Ultima WF860 Front Load Washer
My hotpoint wf860 washing machine is stuck on f-12 iv tried switching it off and on but still saying f-12 can you help?
f12 is an electrical connection problem between the 2 circuit boards of the machine. it may be a loose connection or more likely a new power board required.
Feb 22, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpopint Washing Machine WT741 flashing F-12
Resolved the problem.
Switched off the power to the machine. hit the on /off button and the f-12 error code disappeared .
On reappling the power to the machine the orignial programme continued to completionj
Jan 29, 2009 | Hotpoint Ultima WF860 Front Load Washer
Cant find filter on my hotpoint Ultima
Good luck. All modern washers that I know dont have the filter you need. If a clean out is needed you will have to clean out the pump.
Jan 26, 2009 | Hotpoint Ultima WF860 Front Load Washer
f-05 , pressure sw stuck on full this is a faulty switch
Jun 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima 840
hold child lock button down for 2 seconds you will then hear a beep done.
Jun 10, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
203 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
