Question about GE (PSS26MSRSS) Side by Side Refrigerator
Water dripping from water shute just above ice maker;
The water shute seems to have a slow drip just above the ice maker. So it is eventually freezing and/or dripping down the back of the fridge into the fan. My guess is the water valve has a leak?
2 questions.... What could be causing the leak? And is it something easy enough we can do ourselves or should we have a technician do the repair?
Thank you!
  • 74 Answers
Yes the water valve is not sealing correctly and if left untreated can cause issues with freezing up the pipe work and causing water to run down the back of the machine. the poor seal could be caused by grit or limescale getting trapped . it is very easy to change for someone who is diy minded.
Posted on Feb 26, 2009
Hi, my Haier ice maker seems like there's water dripping when when the ice drops in the tray so the water that drips together with the ice freeze together and makes it difficult to use single blocks.
yes ive seen this before , it turns out that the automatic valve that lets the water in isn't shuting all the way off , something is maybe stuck inside it (no water filter on line ??) also you could just replace the valve too , that works too !!
Jan 10, 2017 | Haier Refrigerators
LSC27926ST REFRIG/freezer. Ice maker is leaking water that freezes on items in freezer, ice is messed up and had to unclog ice maker. Still a logjam of ice around ice maker. has been churning out ice...
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn't take much to eventually block the fill tube.
Sep 10, 2011 | LG LFX25960ST Stainless Steel French Door...
Water freezes when going into ice maker model # ed25rfxfw01 whirlpool
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
Mar 24, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Ice cube maker not working. I saw water frozen in the plastic shute leading to the ice trays.I used a hair dryer to melt the ice in the shute. The white gear IS turning. Still no filling of water. Door...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Jan 02, 2010 | Whirlpool ED2FHEXN Side by Side...
KitchenAid KSCS25INSS01 ice maker intermittent failure. It periodically stops making ice for days. I noticed it occurs when there is heavy use on the RO unit that supplies it. The drop in water pressure...
no you dont want to go there !
there is a chance that your water valve is dripping and water are in the line...also there is a heating kit for your fridg that prevent that ask your local tech.
Dec 30, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Not making ice
Sep 24, 2009 | GALAXY Microsystems 25.4 cu. ft....
Ice maker leaking inside freezer compartment, water dripping down from unit
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Sep 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Icicle are forming around icemaker port inside of freezer compartment drips seem to come from around inmaker feed water area.
Sep 17, 2009 | Kenmore 53642 / 53644 Side by Side...
Ice maker seems to be dripping water onto ice in ice container
Watch it when it fills with water. The fill tube could also be stopped up with ice. The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Jul 12, 2009 | Kenmore Freezers
Ice maker won't stop dripping
If your i/m is dripping you most likely have a crack in the ice mold, you should replace the ice maker.
Jan 01, 2009 | Sub-Zero 650 / O Bottom Freezer...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
111 people viewed this question
Top Refrigerators Experts
Gere knutson
KJ4QOB
Da Doc
