Question about HP Photosmart 3210 All-In-One InkJet Printer
Only on Quicken to 3210 all-in-one printer. Paper starts to feed then indicates paper jam, wait long enough and paper feeds with crinkle and no print.
    Scholar:
  • 82 Answers
I would check the paper path on the printer where it is crinkling the paper. More than likely there is some small piece of paper or something that is causing it. Does it only do this out of quicken? I wouldn't think so if the paper comes out damaged....
Posted on Mar 10, 2009
When I hit print when the paper starts to feed the pushbar paper feed does so fast causing the paper to start slightly off caqusing a paper jam.. Is there anyway to adjust the feed
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper.The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Nov 03, 2011 | Canon Pixma iP2600 InkJet Photo Printer
The paper does not feed correctly so that the paper goes into the machine crooked causing a paper jam.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Aug 27, 2011 | Canon Office Equipment & Supplies
I am using Canon Pixma MP145. Paper gets jammed every time i want to print. Paper gets pulled in only from right side and it gets jammed, but printer does't show any error. I have to pull the paper...
Jul 14, 2011 | Office Equipment & Supplies
Magicolor 5440dl manual feed jams paper as it feeds into printer. paper gets about half way. paper is not smashed or crinkled.
If the paper was damaged we can presume that there is a blockage, however your jam sounds like the paper is not in the expected position at the expected time (ie a sensor is not reporting that a peice of paper has reached it) so this can be cased by
1. rollers slipping on the paper from
a/ slippy media - try a different paper (even as a test)
b/Build up of paper dust on the rollers- If you can see the roller, power off and wipe with cloth
c/ Roller ware - If you can see the roller and have a mild abreahisive like wire woll If you can see the roller and give the rollers a rub
2. Sensor failure-Try Powering off then unplug wait 2 minutes and then power back up, this will reinitilise a sensor
Sep 10, 2009 | Konica Minolta magicolor 5440 DL Laser...
Manually feeding paper
Even if manual feeding is an option the paper must be able to fit the paper tray in order to feed it through the printer.
Jan 20, 2009 | HP Photosmart 3210 Printer
Please give me the name of a printer that WORKS with writing checks in Quicken using Windows Vista 64. My HP all in one does not - printer jams every time.
HP will work. The jam is a paper problem not a hardware or software issue. Try line feeds without printing. HP also makes the best printer paper so don't skimp on that. Moisture in the paper is the most common paper jam problem aside from debris getting into the rollers. If line feed fails then physically inspect the whole paper path. I have Canon, Epson, Dell, HP and Lexmark printers with Quickbooks Pro. They all work. Paper is your problem barring a banana falling into the rollers. Never leave paper in a printer for a long time as it will stick to itself. Steve
Oct 21, 2008 | Computers & Internet
Paper tray does not feed at all or may jam several papers
The rubber wheels that feed the paper in can be too soft to grip the paper.
After a long dicussion with the help desk, HP supplied me with a special Paper Feed Cleaning Kit for the 3200 series. This comprises a scraper device that you insert into the paper feeder, and a driver CD. I had to use it three times, Now everything woerk fine.
Jun 19, 2008 | HP Photosmart 3210 Printer
Paper feed problem
Check all this-----
1.check the printer paper feed roller jam.
2.check the paper sensor, It is working or not.
3.check the paper tray(clean it)
4.service the printer, (If possible).
Goodluck
Mar 10, 2008 | HP Photosmart 3210 Printer
Paper will not feed correctly, keeps jamming up.
There IS something stuck in the feed path. If the paper starts to feed and then crinkles on the feed side, there is an object stopping the paper moving forward.
Lay the machine on it's back and take a sheet of very stiff card (A5 size approx) and push it through the paper path in reverse. So start where the paper would normally exit and push the card in. You may need to lift the pinch rollers just behind the print head by hand to aid the card through. Keep the card to the side that would normally crinkle but beware of the paper sensor flag. If you force it you could break it off.
Once you get past the pinch rollers behind the print head, push a little further then start to move the card in and out but along the length of the rollers. You should find that sufficient to push out whatever is in the path and having the machine on it's back will help it fall clear of the feed mechanism.
If it does not fall out using this method you will have to remove the covers and try to remove the ASF to get at the object.
Oct 14, 2007 | Canon PIXMA MP170 All-In-One InkJet...
HP Photosmart 3210 All-In-One InkJet Printer Logo
175 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
