Question about Bosch Logixx WFR 2866 Front Load Washer
Bosch Logixx 1400 -WFR2866gb - drum wont turn, All the programmes and dials appear to work (can hear pumps working). Belt OK, motor not turning, but turns extremely freely by hand, no brush tension.
  • 1294 Answers
SOURCE: Bosch logixx 1600 workshop manual
Look for user manuals at
Posted on Mar 14, 2008
SOURCE: bosch 1400 exxcel
The machine thinks the drain is blocked.. check the pump and outlet pipe for buildup of dirt.
I noticed holding start down for several seconds whilst powering the machine on, then turning it off / then on again would clear the machine's idea of where it was during a program. Does this affect the error code you're seeing?
Posted on Jun 11, 2008
  • 44 Answers
SOURCE: I can't locate brushes on Bosch Logixx 1600 wasshing machine
usally the brushes are at the back of the motor but depending on motor they could be inside . to get to these you need to remove the 4 screws wich hold motor together. but 1st thing to check is to look at armitor on motor and see if you can see a line going round in the middle. if there is the motor will probley need to be replaced as the motor will have burnt out. but motors are very expensive o these machines. hope this helps
regards dan
Posted on Mar 19, 2009
  • 662 Answers
SOURCE: bosch logixx 1400 express washing machine spin is
The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
Posted on Jun 15, 2010
  • 414 Answers
SOURCE: f:23 code logixx edition75
Usually means there is water in the base pan and the flood safety has been activated. If you tip the unit forward a touch you will most likely find that water is expelled from the bottom front. The machine should work but obviously the source of the leak has to be found. Check door gasket for tears etc, water valves and drain hoses.
Hope this helps.
Posted on Jul 07, 2010
I have replaced the carbon brushes in my logixx 8 machine after error code F43 appeared .the machine works ok but the washing stays soaking wet on the wash programmes
Make sure the pump wires have not got accidently dislodged when changing the brushes. Also check the program cycles, you may have accidently selected a "no spin" cycle.
Mar 10, 2015 | Bosch Washing Machines
My Bosch logixx 1400 makes a loud noise when it drains the water. I look into the pump housing and it's clean and the pump impellor turns freely, with a slight bit of resistance. Do I need to get a...
These pumps have a tendency to be noisy, if it's still functioning and you can put up with the noise it will work fine. You could replace it if you wanted to though.
Mar 10, 2012 | Bosch Washing Machines
Drum wont turn
hi take the back off the washer the belt might have snapped if the belt is ok the other fault could be the brushes on the motor 2 black plastic blocks sit either sid e of the motor these are made of carbon and wear down can stop the motor working hope it helps
Nov 23, 2011 | Bosch WFMC 3200 Front Load Washer
Hi I have a Bosch WFL226 MAXX. The wash programmes seem to work OK - the motor operates the drum and the pump works fine and drains the machine. The water level vacuum switch seems ok (it stops it...
Bosch WFL226 MAXX This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Dec 21, 2010 | Washing Machines
Can I get a user manual for a Bosch Logixx 1400 washing machine?
Below a user manual for Logixx 1400. There are different models corresponding to Logixx 1400, if the manual below does not apply, please ask a new question providing full model number as on service tag.
Bosch - Bosch Logixx Sensitive Automatic washing machine
Sep 24, 2010 | Washing Machines
Motor not turning at all. Water goes in and pumps
Since you say relay sounds are heard, it shows the command is OK. The power to the motor is not reaching. It could be relay contact problem.
If you have a option of only spin, try this option. If it works the motor is OK. Otherwise you have to trace the power line and test it through a electrical line tester.
Apr 01, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Classixx 1200 - Drum not turning
It could be the motor itself (is there any overheating smell from the motor) or it could be the capacitor which controls the motor. I had a similar problem and it turned out to be the motor brushes. I replaced the brushes and all was OK.
The only other thing that could be wrong especially if it overfills with water is the water level switch (this is a pressure switch on the side of the washer) You can easily check this by removing the hosepipe to the switch and blow gently into it, you should hear a clicking sound) This might be the clicking that you heard so it is probably Ok.
Aug 08, 2017 | Bosch Washing Machines
Bosh washing machine won't do any programmes
If it fills then the next phase is to agitate.
To do that the motor must drive
Can you hear a whirring sound from the machine if you get close to it if so then the belt driving driving drum may have snapped.
If not then the motor brushes may have stuck or have worn out.
Does the machine programmer advance by itself or are you turning the dial
May 23, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Logixx WFR 2866 Front Load Washer Logo
156 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
