Question about HP LaserJet 1320 Printer
Paper Jam HP 1320 Paper jam in the area of salve stop the paper
  • Anonymous Feb 25, 2009
    The paper keeps pwning my printer. The printer will pick up the papaer, but half way through it will just jam.. No broken pieces. it just happens.
  • delimantjean May 06, 2009
    Printer HP 1320 just pickup a paper, half way is jammed and then stop printing
Rolo fusor danificado, como obter part number deste componente?
Posted on Mar 23, 2009
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Hp 1320 don't stop printing
my hp printer 1320 always prints two papers one of them is white.
what caused this problem?
Nov 02, 2012 | HP LaserJet 1320 Printer
I have an HP Laser Jet 1320. The error light with the triangle and the explanation point is flashing. There is no paper jam. I have turned off the unit and plugged it back in. Can you please tell me what...
Its indicates attention..1. door open 2. cartridge missed 3. no paper in tray 4. paper jam.
open the door there is notch which pushes the switch check notch broken? reinsert the cartridge check, load paper in tray check paper sensor flag strucked. Lift registration assm plate any paper partials under clean it..
Sep 07, 2011 | HP LaserJet 1320 Printer
My printer chew one side of paper laserjet 1320
Is the correct model number: HP Deskjet D1320 Printer ? Was printer working properly at one point? May be resulting from failure to fully clear a paper jam:
Paper jam
To clear a paper jam
1. Remove the paper from the paper tray.
2. If you are printing labels, verify that a label did not become detached from the label sheet while passing through the printer.
3. Turn off the printer.
4. Remove the rear access door. Press the handle to the right, and then pull out the door.
5. Remove the paper jam from the back of the printer, and then replace the rear access door securely.
6. If the paper jam cannot be removed from the back of the printer, raise the printer cover, remove the paper jam from the front of the printer, and then lower the cover.
Caution Remove the paper jam carefully as it is possible to damage the printer when removing paper from the front.
7. Reload paper in the paper tray.
8. Turn on the printer.
9. Reprint the document
if this does not help I would suggest installing a new driver from: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=ca&docname=c00211293&product=1839853&
Trust this is helpful. :)
Dec 08, 2010 | HP LaserJet 1320 Printer
Attention light keeps flashing - won't print
Hello.
The most common reason is that you have paper jam.
Opne the front cover and remove the cartridge if necessary to look for the jammed paper. Other areas to check: paper tray and the back of the printer (door).
Hope this helps.
Aug 17, 2010 | HP LaserJet 1320 Printer
Prints one page double sided, then goes to error light and stops printing
what is the error ?
does it says Paper jam, Open the print cover and remove paper jam..
If this the error repeating then make sure,
1. u r not overfilling the paper tray
2. put the printer on a hard surface (not on a half out surface)
3. from now on be gentle with the paper tray.
4. unplug the printer everytime u r done or atleast overnight.
thanks
Jul 30, 2010 | HP LaserJet 1320 Printer
Paper jam in hp laser 1320
Unplug the power cord and open the cover and remove toner and try to look I inside around the roller and try to manually roll the roller and if you can see the paper try to pull is slowly.
Have a nice day and do not forget to rate please...!
Feb 10, 2010 | HP LaserJet 1320 Printer
Pickup is not pickup the paper when the paper are less in hp laserjet 1320n
please check any light is red.May be paper jam or cartridge is disable
Nov 22, 2009 | HP LaserJet 1320 Printer
Hp laserjet 1320 paper jams constantly. not even one page prints. what could be the problem?
could actually be the paper your using. make sure your using at the very least multipurpose paper or laser paper. check to make sure your settings for paper is also set to regular paper and not cardstock or special paper or anything else
Jul 30, 2009 | HP LaserJet 1320 Printer
Paper Jam & Flashing Light
take everything out and look at all the rollers and printer path and look in the back of the printer
Jan 15, 2008 | HP LaserJet 1320 Printer
HP LaserJet 1320 Printer Logo
201 people viewed this question
Ben Johnson
