Question about McCulloch Garden
I took the front off to try and clean. When i did the wiring came unplugged. They are not color coded. So i don't know what wire goes where. Need diagram to put back together. This is on a Mcculloch fh160b pressure washer.
  • howie69 Feb 23, 2009
    I was trying to clean out the cob webs and dirt. When the front came off the eletric wires that go from the switches onthe front to the eletric pump on the inside came unplugged. They are put together with male and female spade connectors. They are not color coded. So i cannot tell what wire goes to what wire.
    JERRY ABELL May 11, 2010
    hello mr h, could you please tell me what front of what you removed,what wires are you talking about.
  • 132 Answers
SOURCE: wire harness diagram will give you the cars wires, u may want to just by a harness adapter, cutting wires=bad
Posted on Jan 02, 2008
  • 92 Answers
SOURCE: % hp Honda Motor runs on choke
Dear LC39B,
Is it possible you are blaming the wrong part of the machine? Did you try the Honda Motor on its own? I am asking , because if the pump of the washer has some fault or a bit jammed, this will demand a lot of power from the Honda. You can try the Honda with no water connection and no gun.
Regarding the Honda motor, you should check the electrical system also. I am saying this because you did not mention it, in your service procedure.
Posted on Nov 05, 2008
need codes to hook up radio to 1999 buick century
Posted on Mar 07, 2009
cape cod bob
  • 292 Answers
SOURCE: need the wire color code
you will find a free pdf service manual here. with wiring diagrams
Posted on Apr 04, 2009
SOURCE: drained the gear oil out of pump
Yes, fill'er up.
Posted on May 03, 2009
Headlight plug wiring
Checout utube videos or buy a haynesmanual for rebuild data. Try to matchup what u mite think it is...u can only blow a fuse
Sep 07, 2015 | 2005 Pontiac Aztek
I need to find the wiring codes for my radio so i know which color goes to what?
Car Radio Constant 12v+ Wire: Red
Car Radio Switched 12v+ Wire: Green/Black
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Yellow
Car Stereo Dimmer Wire: Black/Orange
Car Stereo Antenna Trigger: Green
Left Front Speaker Positive Wire (+): Black
Left Front Speaker Negative Wire (-): White
Right Front Speaker Positive Wire (+): Blue
Right Front Speaker Negative Wire (-): Red
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Green
Right Rear Speaker Negative Wire (-): Orange
Oct 15, 2012 | 2008 Hyundai Veracruz
My shredder jammed so I took the top off of unit in order to clean. When I pulled the top back it pulled all of the wires loose. Being inexperienced I should have made a "diagram" of where the...
I'm afraid i cannot help you to tell you where each specific wire goes first because the wire colors mean nothing without sources and destinations but i can tell you this:Each wire has an elastic memory so that the shape it had before you opened it should remain the same. This means that you can deduce where each wire goes. Also you should have an electrician do the connections as there could be some voltage/amperage issues.
Jan 01, 2012 | Office Equipment & Supplies
Brother took off wall sensor wiring and now I don't know what colored wires go together
The solid white wire from each sensor goes to terminal #2 and the white wires with the black tracers go to terminal #3.
Sep 21, 2011 | Sears Craftsman LiftMaster Chamberlain...
I need to know the which color of wire goes to what pin number on the connector that on the back of alpine CDA-7995.
You need a wire harness for your vehicle make. Its like 15 bucks. You plug it into your car harness where the radio goes. It has a little peice of paper to tell you what the color codes are. You need to know what the wires on the receiver are though. For example mine are labeled with small tape that say ground,front left, right rear, Ect. Leave good feedback if this helps. Thanks
May 09, 2011 | Alpine CDA-7995 CD Player
Color code for turn signal wires
Hi and welcome to FixYa,
Honda in general uses standardized wiring scheme:
  • green - common ground;
  • light blue - right turn signal;
  • orange - left turn signal.
Good luck and thank you for asking FixYa.
Aug 21, 2009 | 1985 Honda CB 700 SC Nighthawk
Need a stereo wire color code for 2000 subaru outback limited
The sell a nifty little invention at Wally-World. Its called a wire harness...look for it in the auto parts section. it will wire directly to your stereo wires and then just plug & go... if your subaru wires are missing the harness on the end, its a whole different ballgame, and its gonna be fun...try this...
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Red
Car Radio Illumination Wire: Green
Left Front Speaker Positive Wire (+): Brown/White
Left Front Speaker Negative Wire (-): Green/Black
Right Front Speaker Positive Wire (+): Red/Yellow
Right Front Speaker Negative Wire (-): White/Black
Left Rear Speaker Positive Wire (+): White/Red
Left Rear Speaker Negative Wire (-): Red/Green
Right Rear Speaker Positive Wire (+): Blue/Green
Right Rear Speaker Negative Wire (-): Red
Let me know how it goes!
May 17, 2009 | 2000 Subaru Outback
Color codes for my jvc arsenal kd-ar560 wire harness
Hello jlj2382,
Here's the wire colors for your KD-AR560:
Black = Ground (to vehicle chassis)
Yellow = Constant 12V (power)
Red = Accessory (to vehicle accessory terminal)
Blue/White = Remote turn-on lead (to remote amp)
Orange/White = Illumination (to vehicle light control switch)
Brown = Cell Phone terminal
White = Left Front Speaker positive (+)
White/Black = Left Front Speaker negative (-)
Gray = Right Front Speaker positive (+)
Gray/Black = Right Front Speaker negative (-)
Green = Left Rear Speaker positive (+)
Green/Black = Left Rear Speaker negative (-)
Violet = Right Rear Speaker positive (+)
Violet/Black = Right Rear Speaker negative (-)
Hope this helps.
Apr 24, 2009 | JVC Arsenal KD-AR560 CD Player
Audio wiring problem
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: White/Red
Radio Illumination Wire: n/a
Radio Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: n/a
Radio Antenna Location: Rear Glass
Front Speakers Size and Location: 6 1/2′ Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size and Location: 6′ x 9′ Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Apr 05, 2009 | 1998 Honda Accord
Cold water valve
Hi Yes I fixed it myself! lol I just tried every combo of wires that there was, and it is working gr8! Ty so much though, for having a site like this! I even called the Equator company and they could.n't tell me! Again it is fixed and thank so much! Rose
Apr 01, 2009 | Equator EZ 3600 CEE Front Load Washer /...
Garden Logo
122 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
