Question about Viking Dishwashers
Hope this is fast enough... here is a short video on how to fix your 'no fill' problem...
http://www.partselect.com/Repair/Dishwasher/Will-Not-Fill-Water Checking the water inlet valve and Float in Dishwasher
Posted on May 16, 2017
SOURCE: dishwasher won t fill
I had a similar problem with a Kenmore; the problem turned out to be that the float was stuck. On the bottom of your dishwasher there should be something that looks vaguely like a plastic mushroom - that is the float. Just tap it gently and see if it goes down a bit. If it does, gently move it up and down a few times to make sure it's moving freely (make sure to leave it in the down position) and then try to launch a cycle. Good luck!
Posted on Mar 18, 2014
Mar 18, 2014 | Siemens Dishwashers
Mar 09, 2013 | Bosch 24 in. SGS43C12 Classixx...
Feb 16, 2013 | Bosch Dishwashers
Aug 22, 2017 | GE GLD4560RSS Builtin Dishwasher
Ice maker stopped making
ice. For this problem you have check few things. First thing, is the water
filling in the ice maker chamber and then ice maker not making ice? Or, the
water is not filling in the ice maker chamber so it's not making ice. If the
water is not filling in the ice maker chamber then it's clear that ice is not
getting made due to no water in the chamber. For no water filling, the problem
is either water supply valve turned off so water is not filling. Turn on the
water supply and it will fill. But if the water supply is turned on then the
other possibility is ice blockage in the water fill tube. There is a tube from
which the water runs and enters the ice maker chamber. If this tube is blocked
then water will not enter the chamber. The tube needs to be defrosted, by using
hair dryer. This procedure melts the ice collected in the tube and
water starts running again. But if water fill tube is completely
clear and no ice blockage or any other blockage. Then other possibility is
water valve. This water valve is for letting the
water in the ice maker. The water valve open only for 7 seconds and
in this time the water fills in the ice maker chamber and then water
valve closes and the same procedure runs again in the next water
filling cycle.------- The main valve on the back of the fridge section. This main valve lets the
water enter the refrigerator .In most of the cases the fault is water valve . ------------- The other above possibilities which I gave you is
water not filling in ice-maker chamber so it's not making ice. But
now consider that water is filling in ice maker chamber but it's
still not making ice. Then the problem is ice maker unit itself. This unit is
controlled by main board. But in most cases if water is filling the ice maker
but it's not making ice then its faulty ice maker unit. So see if the problem
is water not entering the ice maker then the water fill tube is frosted by ice
or the water valve is faulty. Replace the valve.
You can get required
parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
Jul 08, 2011 | Refrigerators
the tube and water starts running again. But if water fill
tube is completely clear and no ice blockage or any other blockage. Then other
possibility is water valve at the back of ice maker unit. This water valve is
for letting the water in the ice maker. The water valve open only for
7 seconds and in this time the water fills in the ice maker chamber and then
water valve closes and the same procedure runs again in the next
water filling cycle.------- For your information I will mention that there are
two valves. One is the main valve the back of the fridge section. This main
valve lets the water enter the refrigerator and other valve is at the back
of ice-maker section. This other valve lets the water to enter the
ice maker. In most of the cases the fault is water valve at the back of ice
maker section. ------------- The other above possibilities which I gave you is
or the water valve at the back of ice maker is faulty. Replace the valve.
Apr 26, 2011 | GALAXY Microsystems 25.4 cu. ft....
Here
is a tip that will help you to find out why water will not come into
the dishwasher...
Dishwasher Trouble No
Water entering Dishwasher
heatman101
Jan 06, 2011 | Viking 24 in. Professional Series VUD141...
Here
the dishwasher...
heatman101
Dec 07, 2010 | Zanussi Dishwashers
Jul 20, 2010 | GE 24 in. GLD5560LSS Stainless Steel...
Jul 24, 2009 | Dishwashers
80 people viewed this question
