Question about Karcher K2.26 Electric Power Washer
Where can i put lubricating oil for karcher jet wash machine
What sort of oil have i to use
  • 1 more comment
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    hello mr m,what are you lubricateing on a electric power washer
  • JERRY ABELL
    hello mr m,what are you lubricateing on a electric power washer.
  • Anonymous Mar 15, 2014
    What type of lubricant?
  • 14 Answers
It sounds like you are referring to the oil in the swash plate housing. You can use a multi grade motor oil such as 20w50 or 10w40. Fill to about half way over the swash plate. If the old oil has gone amilky colour, please replace the oil seals first.
Posted on Mar 11, 2009
Testimonial: "post was very helpful and i am going to replace o ring rubber seal where i suspect oil is leaking and also fill it with oil.Thanks very much"
    President:
  • 389 Answers
Hi,  There is nothing to lubricate on the Karcher 2.26
Posted on Feb 22, 2009
What grease or oil do i need to lubricate the bearings and wobble plate on my Karcher pressure washer.
Use a Teflon based grease. Contact an auto parts store to buy it. The grease is usually colored blue.
Jul 16, 2016 | Karcher Garden
How many milligrams of oil does Karcher 15" Upright Vacuum CV 380 need
Precision measurement of lubricant is completely unnecessary. Simply apply a sufficient amount of lubricant to all parts to partially saturate all pivots and bearings without applying so much as to make a mess.
May 06, 2015 | Karcher 15" Upright Vacuum CV 380 15"-...
Water coming out of detergent pipe from top for karcher 3030 B jet wash.When i start using the jet wash there is not enough pressure and water starts coming out of detergent pipe.How can i stop water...
remove deterfent pipe,unscrew detergentnozzle carefully, inside is spring and ball bearing, clean and re-fit, replace if missing. spring on upstream (soap) side
Apr 03, 2014 | Karcher Garden
HOW MUCH OIL DO WE PUT IN KARCHER3030B AND WHAT SORT OF OIL
you need to know where oil is coming from. pump or motor? both will use normal motor oil
Mar 30, 2014 | Karcher Garden
How much oil do I put in my Karcher 570 jet washer
Most small engines take about a quart.
You'll find "small engine oil" at any auto parts store or store that sells small gas powered devices.
Oct 16, 2012 | Karcher Garden
What type of fuel do i need to use for my p/w? Does it require oil/gas mixture? Thx.
Your Honda would be a four stroke engine, so your fuel would be straight gas, you will notice on the base of the engine there is a location to put oil, a 4 stroke engine is lubricated by the oil in the base of the crankcase. On a two-stroke engine.oil fuel mixture lubricates the crank so it has no provision to add oil to the engine.
Feb 19, 2011 | Karcher 2500 PSI Pressure Washer
I can use my Karcher K3 jet wash as long as i hold trigger down
Most pressure washers have ball lock type fittings on the hose connections. What happens is the little steel balls get a bit of corrosion and do not lock the male fitting properly with the female coupling. Load up the fitting with some Oil or WD 40. Then connect and disconnect the fitting several times to losen up the balls and springs. Should the spring in the coupling break you will get the exact symptom your describing.
If the OIL / WD 40 does not do the trick then you may have to change out the quick disconnect coupling.
Kelly
Apr 18, 2010 | Karcher PSI Electric Pressure Washer
Why is my karcher jet wash smoking excessively?
could be bad piston rings, or if its a 2 stroke engine (probably not) then you could have too much oil in the oil/gas mixture. maybe even too much oil in the crankcase.
Oct 07, 2009 | Karcher 2500 PSI Pressure Washer
BR400 FLOOR SCRUBBING MACHINE.The unit is not putting water down.The pump is working.Any ideas?
We contacted Karcher technical services and sorted the problem in two minuites.It was a "pinched " water feed pipe caught in the casing Thanks
Nov 25, 2008 | Washing Machines
Karcher K2.26 Electric Power Washer Logo
1,624 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
