Question about Epson Stylus C20UX InkJet Printer
It is telling maintenance call
Some parts have to maintained or replaced in your printer contact your dealer
  • Epson Master
  • 419 Answers
This is a standard error which indicates your waste ink pads in the base of the printer are full and need replacing.
I don't have anything specific for the C20UX but it is possible to reset the waste ink counter for that model using the SSC utility .
In terms of replacing, cleaning out or redirecting the waste ink flow your best bet is to get this:
Service Manual (C20 is same as C40 in many respects)
.. and either disassemble the printer to get at the pads [section 4.2.3 in that manual] (you'll need a washable work are and latex/rubber gloves) or to figure out how to redirect the waste ink flow from the cleaning pump into an external tank.
None of this is particularly easy so you may want to consider dumping it and getting a new printer..
Hope that helps.
Posted on Feb 22, 2009
How do I reset Z6100 maintenance counter?
POwer off the printer and then depress the Maintenance button now Power On the printer till it resets which is for few seconds
Jun 25, 2015 | HP Designjet Z6100 InkJet Printer
Parts inside in my printer are near the end of their service life
A Service Error where you get a message telling you that "Parts inside your printer at the end of their service life, contact your dealer for replacement", or "Parts inside your printer require maintenance or replacement, call your service company", is normally a Maintenance Request Error. The maintenance request error is actually a Waste Ink Ink Pad Error and usually your remedy is:
1. Replace the Waste Ink Pad/Pads with a new one/ones (many people ignore this one, and they just follow #2)
2) Reset the Internal Waste Ink Pad Counter by using SSC Utility
Download from this site http://www.ssclg.com/epsone.shtml and follow instructions.
I hope this information will be helpful. Thank you for using FixYa!
Jun 08, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I have an HP D4300 printer/scanner and I can't figure out how to open a in order to change cartridges. Please advise.
Installation instructions
Always install the tri-color print cartridge in the left side of the print cartridge carriage.
Install the black or photo print cartridge in the right side of the print cartridge carriage.
To replace a print cartridge
1. Verify that the printer is turned on.
2. Load Letter or A4 plain, white paper in the paper tray.
3. Open the printer cover.
Chapter 10
64 Maintenance Maintenance
4. Wait until the print cartridge carriage moves to the right side of the printer and is idle
and quiet.
5. Press down on the print cartridge, and then slide it out of the print cartridge carriage.
6. Remove the replacement print cartridge from its packaging and carefully remove the
plastic tape. Hold the print cartridge so that the copper strips are on the bottom and
facing toward the printer.
1 Remove plastic tape
CAUTION: Do not touch the print cartridge ink nozzles or copper contacts.
Touching these parts will result in clogs, ink failure, and bad electrical connections.
Do not remove the copper strips. They are required electrical contacts.
Install print cartridges 65
Maintenance
7. Slide the print cartridge at a slight upward angle into the carriage until the cartridge
snaps into place.
8. Close the printer cover.
Align print cartridges for optimum print quality.
For information about storing print cartridges, see Maintain print cartridges.
For information about recycling empty print cartridges, see HP inkjet supplies recycling
program.
WARNING! Keep both new and used print cartridges out of the reach of children.
Download manual for proper guidance. http://h10032.www1.hp.com/ctg/Manual/c01438085.pdf
I hope this works for you. Goodluck!
Mongkey
"Understanding explains better..."
Jan 22, 2011 | HP Office Equipment & Supplies
My hp laserjet 4015 is displaying an error 50.3 after printing smarged copies
Thank you for contacting FixYa with your printer inquiry.
The 50.3 is a fuser Temperature error. If your pages have toner and image but are smudging or smearing you know the fuser is not heating and needs to be replaced.
If your printer is still under warranty contact HP Customer Care for warranty replacement of fuser part numbers: RM1-1082 for 110 volt, RM1-1083 for 220 volt. (888) 999-4747.
If your printer is out of warranty, suggest you purchase a maintenance kit part # CB388A HP maintenance kit for LaserJet P4014 P4015 P4515, includes other needed high wear parts.
Excellent Illustrations:
http://www.printertechs.com/tech/mkinst/P4015/mk-p4015-2fuser.php
Maintenance Kit Contents:
Contents
1. What is included in a LaserJet P4014 P4015 P4515 maintenance kit?
2. Fuser installation.
3. Transfer roller installation.
4. Cassette feed/pickup rollers.
5. Tray 1 (manual feed) pickup rollers/feed rollers.
6. Reset the maintenance count.
Please rate this solution and post a comment if you need additional assistance.
Jan 19, 2011 | HP LaserJet 4350 Printer
My printer is reading Replace maintenance kit, what does that mean? I just replaced the ink cartridge about two weeks ago. Please help.
The maintenance kit generally has to do with paper path components/fuser/other misc imaging components. It is just regular maintenance. Contact your Ricoh dealer and they should take care of you.
Jun 08, 2010 | Ricoh Aficio AP410N Laser Printer
Need Datacard CP60 printer service/repair manual.
Contact TulsaBiz.net or MidwestIdSolutions - Can offer assistance as a Datacard CP model is Dealer only you can only get information from a datacard dealer
Jan 08, 2010 | Office Equipment & Supplies
I have a Xerox 8500 DN and it is not recognizing the maintainence kit, have tried compatible and OEM Xerox kits but can not get to identify. on troubleshooting Test: 57 Drum Maint. Kit :Ck DM contact...
The maintenance kit needs to touch contacts to reset it.
There is a camshaft 020K14800 which may be cracked and therefore doesn't position these contacts. I suggest replacing this.
Whit
Item, Inc.
Nov 16, 2009 | Xerox Phaser 8500/DN Printer
Epson R200 printer error, Parts inside your printer are at the end of their service life. See your printer documentation.
A Service Error where you get a message telling you that "Parts inside your printer at the end of their service life, contact your dealer for replacement", or "Parts inside your printer require maintenance or replacement, call your service company", is normally a Maintenance Request Error. The maintenance request error is actually a Waste Ink Ink Pad Error and usually your remedy is to replace the Waste Ink Pad/Pads with a new one/ones and then reset the Internal Waste Ink Pad Counter. If you just reset the counter and don't replace the pads, then your printers old pads will eventually overflow and normally start leaking ink out the bottom of your printer.Some people actually wash the ink out of the old pads, by holding them under running cold water. Then they simply dry them out and reinstall them back into their printer. The choice on what to actually do, is yours to make. I would at least recommend getting that Waste Ink Counter reset procedure and performing it first, to make sure your printer will then work.
Try this reset app
http://inkjetprinterhelp.us/sscserve.exe
Aug 15, 2009 | Computers & Internet
Error 80-maintenance
80 Scheduled Maintenance
The operator panel displays this message at each
300K page count interval. It is necessary to replace
the fuser assembly, transfer roller, charge roll, and pick
rolls at this interval to maintain the print quality and
reliability of the printer. The parts are available as a
maintenance kit.
Description Part number
Infoprint 1332/1352 Infoprint 1372
115 V Maintenance kit 56P1409 56P1855
220 V Maintenance kit 56P1412 56P1856
100 V Maintenance kit 56P1413 56P1857
I have new Maintenance Kits in stock at this time. You have the option of doing the kit on exchange or outright. Your Part # should be 56p1409 if you are in the US.
Please give me a call for pricing of if you have any other questions.
Thanks
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 x240
AOL IM: RORYMRP
rcardenas@mrp.to
Jul 07, 2009 | IBM Infoprint 1352 Laser Printer
Still having paper feeding issue
Yeah it should make contact with the drum, but it moved up and down to make and break contact with a clutch.
What I strongly suspect is that you have a bad registration clutch. That drives the rollers just out of the paper tray and is very prone to failure.
If you want to try and replace that let me know, I can get you the part number to order and tell you how to replace it. It really is not hard to do at all.
Just removal of the left side cover and a couple of clips.
Jan 07, 2009 | Xerox Phaser 8400 Laser Printer
Epson Stylus C20UX InkJet Printer Logo
89 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
