Question about Homelite Garden
Homelite 240 chain saw will start & run for about 2 min then when
When u start to cut it turns off.????
I put fresh gas mix in it.
  • lfoster01 May 11, 2010
    Is it bogging down and then cutting out under load? is it smoky or not when it stops?
    President:
  • 2,220 Answers
Delete this; no response to clarification since Feb.
Posted on Sep 16, 2009
New plug, use up one tank of fuel, refuel and saw will no longer start. Plug deposits are white. Put in new plug and will run. Tree cutting, not brush so running hard. Any thoughts?
If you're cutting pine (and more so if your chain is a bit dull and tending to make more dust than chips) you may well have plugged the air filter with resin.
Jul 27, 2016 | Husqvarna 240 18" 38.2cc Gas Powered Chain...
The chain saw is brand new. It starts OK but after I make one cut it stalls (Every time).
Do you have the proper gas-oil mix? It should be 40:1, which is 3.2 oz of oil/synthetic oil to 1 gallon of fresh gasoline. Make sure you push in the choke after starting it. Also make sure the chain brake is off (chain should move freely by hand when the saw is TURNED OFF.) If gas mix is right, choke is turned off after starting and brake is off, take it back to the dealer/store.
Aug 29, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
On a gas chain saw, do you mix the gas
there is usually a fuel/oil ratio (i think yours is 50:1) you must buy the 2 cycle oil and mix it with gas at the ratio reccommended by the manufacture. the bottle may say 6 oz per 1 gallon = 50:1 So 1 bottle of 2 cycle oil for every gallon of gas. mix them in a proper fuel can. then let the cutting begin.
Mar 17, 2011 | Homelite ZR10926 16 Chain Saw
Just got a homelite 33cc 14 inch chain saw, do you mix gas and oil on this chain saw?
Yes you do! The ratio is 50:1 fuel to oil. Be sure to use a modern synthetic saw oil available at home centers, hardware stores, and saw dealers. Be sure to use fresh fuel and mix the two in it's own container. Be sure to shake the container thoroughly each time just before refueling to prevent oil starvation in the engine. Don't make up more than one gallon at a time unless sawing is your business. Hope this helps!
Dec 15, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
I need to know the amount of oil to mix with one gallon of gas for 18 inch homelite chain saw
You need to mix 2.6 ounces of 2-cycle oil (NOT motor oil) with one gallon of fresh gas to get a 50 to 1 mixture. Most 2-cycle oil is sold in small bottles this size and have directions on them to get the correct mixture.
Sep 09, 2010 | Homelite Garden
Hi how to tune homelite 330 chain saw carby, idle
Before adjusting anything, check the fuel filter, air filter, and muffler for plugging. Check the condition of the fuel lines for decay or other damage. Tighten all carburetor fasteners. Make sure you have fresh fuel mix in the tank. Does the primer bulb pull fresh fuel into itself when pumped? Turn both jet screws CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting and should allow the engine to start and run. Start the engine and allow it to warm up, then pull the throttle full on. Adjust H needle CW until the engine starts to speed up, but still 4-stroking. Proper final adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW for fairly good idle, but still allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine will continue to run. Hope this helps!
May 09, 2010 | Homelite ZR10926 16" Chain Saw
Port in front for oil and the back is for gas and mixture
Hello Andre;
I think you are saying you put oil/fuel mix in the oil tank and bar oil in the fuel tank; discovered your mistake drained both tanks and refilled with the correct fluids. Now the saw runs but smokes excessively. I think it will do no lasting harm. After you have run a few tanks of the correct mix (50:1) through the saw. Remove and clean the muffler and spark arrestor, reinstall them. Inspect your plug if any evidence of fouling replace it. I think you will be cutting with this saw for years.
Yes the additional smoke is caused by a very oil rich mixture and should abate with each fresh tank of fuel. If the chain is not moving ensure the chain brake is not engaged.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 23, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
My chain saw (14 inch gas powered) would not
Modern chainsaws have the ability to run without turning the chain via the chain-brake. To set the brake the uppermost handle is pushed forward (toward the chain) and a firm snap should be heard and felt. To release the brake you pull the same handle back (towards the engine) and get the same "snap".
Concerning oil leakage: Bar/chain lube collects on the inside of the clutch cover and the sawdust mixes with it as you saw. A surprising amount of oil gets absorbed in the sawdust and later seeps back out when the saw is at rest. If the level of oil in the tank noticably drops after sitting overnight you may have a leak...otherwise it's normal.
As for a running chain that wont cut, it is common for chains to be installed backward and the unit still function perfectly (it just won't cut wood). See the proper chain orientation here. In this photo the chain travel is from left to right.
Sep 26, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Garden Logo
254 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
