Question about iRobot 5800 Scooba Vacuum
Scooba runs for a short time then the service light comes on
What can i do to fix?
  • Lynnrocks Apr 16, 2009
    My scooba runs for 1 to 3 minutes then the service light goes on. I've tried to clean the small fan blades with a Qtip and water. That worked for a while but now that fix is not effective.
    Any help would be appreciated.
  • 281 Answers
Have you emtied it and cleaned it good.take the battery out and let it stand for 30 minutes then try again
Posted on May 05, 2009
Hello. My scooba 5800 had a check tank light on. I used a straw on the valve and that fixed the problem. Now the scooba runs like nothing is wrong, but there is no actual cleaning going on! It goes the...
Hello, Take the battery out and hold the switch down for 30 seconds, to reset the curcuit board, then charge back up for 12 hours. this should take care of it. If I can help future please call @ 1561-848-3387 Thank you, Teresa. Clean Sweep Vacuums
Aug 10, 2010 | iRobot 5800 Scooba Vacuum
My scooba is not dispensing the water
Mine started doing thatafteri bought a new battery.
now i wet the floor lightly and let it run. after several minutes the solution comes out.
Jan 23, 2010 | iRobot 5900 Scooba Robotic Wet/Dry Vacuum
Scooba now stops sooner and isn't finished cleaning :-(
I had this problem and contacted irobot. An important fact was left out of the early edition user manual to not leave the battery charging for an extended amount of time. Because of this ommision, they sent me a new battery and a software upgrade for the scooba. I just followed the directions and attached the little device they sent to do the upgrade the scooba and it fixed the battery problem.
Hope this helps.
Jul 17, 2009 | iRobot 5800 Scooba Vacuum
Irobot scooba 5800 spins quickly then sets off backwards
Remove and clean all of the wheels, and make sure the cliff sensors under the bumper are clean. Tap the bumper with your hand-- really smack it a couple of times. It sounds like the Scooba believes it's stuck against an obstacle.
May 10, 2009 | iRobot 5800 Scooba Vacuum
When i charge,the service light is on and beeping
get back to the person that you bought it from i would think they would give you some kind of waranty.i don't trust buying from ebay .i hope you didn't pay a whole lot for it.send an email to ebay themselves.please leave feedback
May 04, 2009 | iRobot 5800 Scooba Vacuum
I fixed my scooba's check tank problem, now it has the service light on and keeps beeping 4 times
amber it might be a valve stuck get a straw and blow air into the solution valve under tank on right or try droping scooba 2 inches from ground as this might reset the ball valve .
Apr 25, 2009 | iRobot 5800 Scooba Vacuum
Service code 1
a red 1 is a pump malfuntion
Jan 02, 2009 | iRobot 5800 Scooba Vacuum
Stuck on check tank indicator
If your Scooba's Green Check Tank light is coming on immediately on startup, please try the following steps:
1. Remove and reseat Scooba's battery, ensuring that you hear it click into place.
2. Remove and reseat the brush head
3. Remove and reseat the vacuum port and filter. When replacing the filter, be sure to press firmly into the hole. There is a magnet on the filter that must connect with the magnet on the Scooba.
4. Fill Scooba’s Clean Tank with approximately 1 cup of cold water, shake vigorously, and empty it to remove any debris in the tank.
5. Empty the Dirty Tank, refill with water, and slosh it around to pick up any sediment. Empty the Dirty Tank again.
6. Refill Scooba’s Clean Tank with water, adding a pinch or two of table salt. Run the Scooba. If the issue persists, please follow the steps below:
With the tank removed, press the Power button and then the Clean button.
If the robot tries to start a cleaning cycle, power off the robot and repeat, pressing the Power button first and then the Clean button. If the pump makes a “whirring” or squirting sound and the robot does not start a cleaning cycle (Check Tank indicator will light), this indicates that the pump is working. Replace the tank and try starting a new cleaning cycle with the tank on.
If Scooba does begin a cleaning cycle the second time you press the Power and then the Clean button with the tank removed, the pump valve could be blocked with debris. Using a turkey baster, straw or sports bottle, force water through Scooba’s solution valve. Confirm that the baster, straw or sports bottle fits snugly over Scooba’s solution valve, push water through the system at least three times, and then try re-starting Scooba.
Below is a link to a diagram of these steps for visual reference:
Title: Scooba is not putting down cleaning solution
Nov 01, 2007 | iRobot 5800 Scooba Vacuum
iRobot 5800 Scooba Vacuum Logo
697 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
