Question about IOGear MiniView GCS62 2-port KVM Switch
Keybrd quits working on laptop after ctl-alt_del to reach login
Switching between PC and IBM Laptop PC works fine. When I switch over to usb on IBM Laptop the video and mouse work fine but the keyboard quits working after ctl-atl-del to reach login prompt. On board laptop keyborad is onresponsive as well.
  • Anonymous Mar 02, 2009
    I have same problem, but have found if I leave the external keyboard disconnected and login using the keyboard on the laptop I can login ok. However what I noticed is that if I then plug in the external keyboard and hit a key what ever was typed keeps printing over and over again and I hqave to unplug the xternal keyboard to get it to stop.
    President:
  • 2,923 Answers
Repeating keys? This is a common problem for KVM switches if you go beyond the devices' capability. As you can see, GCS62 is a PS/2 KVM switch and it was designed to work only using a regular PS/2 keyboard.
This KVM switch does not support PS/2 to USB adapter. It might work but it's not guaranteed to work correctly. This does not work properly if you have a docking station for the laptop. It might work for couple of months then it would stop.
You smay isolate the problem by following the steps below:
1. Connect the keyboard directly to the computer to see if you will get the same problem.
2. Power cycle the KVM switch by disconnecting it from the computers and leave it unplugged for a minute or two.
3. Avoid using hybrid connection (PS/2 converted to USB) only for testing purposes.
4. If that work, then you know the answer is that this KVM only designed an work correctly with native PS/2 connection.
Posted on Apr 06, 2009
How do I get it to go into bios when pressing f2 doesn't work?
Per the internet site, it depends upon the model of laptop. Here are some examples:
Laptops - Access Bios Settings Key
Issue
The most common Access Bios key is the "DEL" button or "F2". This depends on the laptop model, however, and can be confusing if you do not know which key to press.
Solution
Here is a list of laptop models and brands with the keyboard commands / key for accessing the BIOS Setup:
Acer: F1, F2, CTRL+ALT+ESC
ARI: CTRL+ALT+ESC, CTRL+ALT+DEL
AST: CTRL+ALT+ESC, CTRL+ALT+DEL
Compaq 8700: F10
CompUSA: DEL
Cybermax: ESC
Dell Laptops:
Dell 400: F3, F1
Dell 4400: F12
Dell Dimension: F2 or DEL
Dell Inspiron: F2
Dell Latitude: Fn+F1 (while booted)
Dell Latitude: F2 (on boot)
Dell Optiplex: DEL
Dell Optiplex: F2
Dell Precision: F2
eMachine: F2
Gateway 2000 1440: F1
Gateway 2000 Solo: F2
HP (Hewlett-Packard): F1, F2 (Laptop, ESC)
IBM: F1
E-pro Laptop: F2
IBM PS/2: CTRL+ALT+INS after CTRL+ALT+DEL
IBM Thinkpad (newer) Windows: Programs-Thinkpad CFG.
Micron: F1, F2, or DEL
Packard Bell: F1, F2, Del
Seanix: DEL
Sony VAIO: F2
Sony VAIO: F3
Tiger: DEL
Toshiba 335 CDS: ESC
Toshiba Protege: ESC
Toshiba Satellite 205 CDS: F1
Toshiba Tecra: ESC then F1 or F2
Toshiba Notebook [Newer models]:
  • Turn on the computer by holding down the power button while pressing the ESC key
    • The machine will beep, then display:
    • Check System, then press [F1] key.
  • Release the ESC key
  • Press the F1 key
Laptops Access Bios Settings Key
Apr 03, 2015 | Computers & Internet
Power is going to laptop but it will not turn on. Was just using it w/out power cord. Plugged power cord in and it won't turn on. Tried, Alt, ctl, delete but nothing...:(
Try switching the outlets that you're using the power your laptop. You may have a faulty outlet which could be why it isn't giving off any power to the power cord. Next, try unplugging your power cord, then taking out the battery, plugging back in the power cord and turning your laptop back on. If the laptop turns on, the problem may be with your laptop's battery. If the laptop still doesn't turn back on, put the battery back into your laptop, and see if it works. If it still doesn't work, try taking it to a place like Geek Squad in Best Buy.
Hope this helps!
-Anonymity
Feb 25, 2011 | Toshiba Satellite C655S5085 Notebook
My ibm laptop keyboard has frozen. All else seems
Please press ctrl+Alt+Del simultaneously and the task manager will be opened up.There you will get the option to shut down.
If the task manager itself is not openeing up then please press and hold the power button for 10 sec and it willlose then you may restart the machine in safe mode and restore it to a previous config.
Thanks.
Jan 06, 2010 | IBM ThinkPad T42p Notebook
Laptop will not start,
looks as though your hard drive is u/s Try and see if it is visible in the bios pages, if not replace it. Bios being, when you switch on you press f2, or ctl-alt.del or just del key. This puts you into the BIOS which tells the computer what it can and cannot do. The 1st page should have your hard drive listed, if not then replace it.
Jan 05, 2010 | Advent Netbook
A disk read error occurred press ctl-alt-del to restart goes back 2 same scrn
Sounds like the hard drive has errors.
Boot to a windows XP cd.
Repair using the windows console.
at the repair console type:
chkdsk /R (hit enter)
Let that run, it takes a long time.
If it's able to repair the drive enough for operation it will.
If it cannot you will be forced to replace the hard drive.
HTH
Aaron
May 23, 2009 | IBM Aptiva E 2170 PC Desktop
Have an IBM ThinkPad T30 2366 Notebook. Windows boots up. I do the normal Ctrl-Alt-Del and then presented with Windows login screen. My problem is that 1 letter on each row of the keyboard does not work...
Hi there.
Keyboards tend to do this from time to time, and is quite common.
You can use a USB keyboard to access your PC until you have a replacement keyboard for the laptop.
If the USB keyboard is not recognized hit F2 (on start up), enter the bios and set it to defaults, save the changes and exit, the computer will restart and you should be able to use a USB keyboard to access your account.
Good luck and thanks for using FixYa!!
May 14, 2009 | IBM ThinkPad T30 2366 Notebook
Which key to enter to bios to format pc IBM pentium III
del.. button on your keyboard old models may require F6
Nov 19, 2008 | IBM ThinkPad T23 Notebook
Wont come on
I have same problem with HP Compaq Presario V6000. LEDs are lit. Cooling fan stops after a short while. A faint click sound can be heard soon after switching. I tried Ctl Alt Del. But no joy. I gone through the troubleshooting in web. Found follwing remedies.
1. Hardware problem. 2. RAM to be re-seated. Cooling fan to be cleaned. 3 Probable BIOS problem. But I have not yet tried all these. Awaiting to procure proper tools. Thank you Baby Antony
Feb 28, 2008 | Acer Aspire 1640Z Notebook
Keyboard problem
Does the ctl alt del work if you try then during the early part of the start up process, before Windows loads? If they do then I would suspect a problem with Windows as a result of your previous infection OR perhaps you are still infected with something. You can easily eliminate most infections by running complete hard drive scans using virus, spyware and root-kit scanners. I would suggest trying AVG?s free versions of each which can be downloaded here: http://free.grisoft.com/freeweb.php/doc/2/. If the ctl alt del key sequence does not work during the boot process you may just have a keyboard that is going bad. Of the 20 plus laptop keyboards that have I have replaced over the years only two were due to physical damage. The rest just developed bad keys, usually clustered together and usually getting worse over time. Here is a link to a keyboard tester program. This should confirm if the keys are bad: http://www.softplatz.com/Soft/Utilities/Other/Keyboard-Tester.html Let us know if you have any other questions and don?t forget to rate this post.
Apr 07, 2007 | Acer TravelMate 662LCi Notebook
IOGear MiniView GCS62 2-port KVM Switch Logo
269 people viewed this question
Top IOGear Computers & Internet Experts
Greg Cann
Greg Cann
John Anderson
John Anderson
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
