Question about Altec Lansing 621 Computer Speakers
Cannot ajust volume
Computer volume works ............ but speaker control only works for off/on
  • 46 Answers
Adjust the volume through computer audio properties
Posted on Feb 23, 2009
I was given the LS11 speakers and have connected them to my computer. However when I click on the volume icon in the tool bar to ajust the volume it does not work.
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Mar 06, 2011 | Logitech LS11 Speaker 2 Speakers
How do you open the speakers? I need to change
You can open the front grill by sliding out from one corner. Once the grill is removed, open the speaker by unscrewing four screws using a philips star screwdriver. Once opened, you can spot the pot (brown circular device). mostly it requires only cleaning. You can use a syringe to pour some Isopropyl alchohol to one small opening at the side of the pot. make sure the power is disconnected before you try this. _397.jpg_396.jpg
May 22, 2010 | Creative Labs SBS 15 Computer Speakers
Volume control does not work prperly. What causes erratic volume settings?
Dust in the rheostat (that part that controls the volume when you turn the volume from MIN to MAX); it's causing the control to be "non-linear".
Replace the computer-speakers, if you're talking about the volume-control built-in to the speakers.
Jan 23, 2010 | Audio Players & Recorders
WE HAD VOLUME ON THE COMPUTER BUT ONE DAY THE SOUND WAS GONE
get a new sound card or try other speakers and volume ajustment
Oct 03, 2009 | E-Machines eMachines Desktop PC
Bose Companion 5 Speaker System won't work
check if the volume control needs to be replaced. volume controls gets bad in due time coz of the carbon layer which gets thinner and thinner till it gets cut off
Aug 12, 2009 | Bose Companion 3 Computer Speakers
I pluged in my speakers but the sounds are very low and wierd
you cant get echo on a specker there not made for that just normal sound
Nov 16, 2008 | Ozaki DT-500 3-Piece Speaker System...
My speaker are very low, can't ajust, and have a roar. coming from both speaker.
adjust the sound effect, make the bass low.... if your using wmp, you can adjust this in the mixer or equalizer..... please rate my solution
Oct 27, 2008 | Acer Aopen MS698 Computer Speakers
Not playing
the volume control does give you more control on the volume of the speakers but yea if you just get a cable going from one end to the other and it doesnt have a volume control it will work no problem just control the volume from the task bar, it will work i can guarantee that because i have the same speakers and i tried it out and works perfectly fine, you cant tell the difference because there isnt one just control from task bar!
Sep 12, 2008 | Creative Labs Inspire 4400 Computer...
Altec Lansing 621 Computer Speakers Logo
192 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Brian Sullivan
Brian Sullivan
Carlos L. Burgos
Carlos L. Burgos
Gomez
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
