Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Stop switch The stop switch broke off on my Husqvarna 36/41, 16'' bar and I need to know where the hookup is
  • 181 Answers
One end of the blue wire goes to the ignition coil and the other end goes to the stop switch.
Posted on Feb 25, 2009
Husqvarna 445 start/stop switch won't stay in choke
remove the top cover and see if the pins are broken from the sides of the lever
Sep 05, 2012 | Husqvarna Garden
I just purchased the new Husqvarna MZ6128 Zero Turn. Was dropped at home on Sunday.. with the parking brake on and deck in the traveling mode and handle bars in neutral it will start..when returning the...
Read the manual. These so called "problems" are standard safety features that someone should have gone over with you. Sounds like poor salesmanship. When starting the mower the bars should be out and the park brake pulled. Then disengage the parkbrake and pull the arms in to drive the mower. Do exactly the opposite to get off the mower. I just bought one today every model I looked at was like this.
May 24, 2011 | Husqvarna Zero Turn Mower Z5426
GTH2548 drive spring broke and I replaced it. Tractor would not start. Replaced battery, start switch, seat switch and PTO switch. Tractor will now start and runs well. However, when PTO switch is...
yes when the belt broke it grabe the wires that goto the cluch frome the pto switch and thay have bar spots on them and are grounding out i just done one that was doing the sam thing all you have to do is fix the wires and that should fix ya up thanks for your time mickey
Sep 08, 2010 | Husqvarna 25HP Hydrostatic 54"Cut Garden...
I have a husqvarna 575xp which i bought used.It was running great for 3 weeks when the motor started to race, the stop switch didn't seem to work in this state so i had to use the choke to shut it down. I...
You need to inspect the throttle mechanism at the carburetor. When you pull the throttle trigger, it should move the throttle arm to it's 'full on' stop, and when it is released, the arm should come back to the idle stop screw. If the action seems to be indefinite, take the throttle trigger mechanism apart (make notes of part placement as you go), and clean it of sawdust and dirt. Don't run the engine until the throttle is working correctly. The 'stop' switch may also be full of sawdust, or the connecting wire may be damaged. Make sure the carburetor fasteners are tight as an air leak behind the carburetor can cause engine racing. Hope this helps!
Aug 05, 2010 | Husqvarna Chain Saw 20" Bar
Husqvarna 435 xtorq chainsaw will not start. you flip the start stop switch prime the gas and pull until its supposed to turn over and does nothing. switch it off of choke and does nothing. thought maybe...
Remove the spark plug and check for blue, snappy spark. If nothing, try a new plug--set gap at 0.020". If still nothing and machine is still under warranty, take it back to your dealer for free repair. The problem could be the ignition switch or the ignition module. Hope this helps!
Apr 14, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Hazardd switch on steering column broke cant stop lights blinkin
You don't need to remove the column off to replace the hazard switch.
1. Take a pair of neede nose pliers and just pull the old one out.
2. Lube up you new one and just slide it in.
The part numbers for the hazard switch are: 15174447 (retails for $16.23) & 15177379 (retails for $18.42). You have to look for the bar code on the top of the turn signal (multifunction) switch. If the number is 26083635, 26083636, or there is no bar code use the 15174447 hazard switch. If the barcode number is 26090641, 26090642, 26096832, or 26096833 use the other hazard switch (15177379). Now these numbers came off of the recall that was for the 2000 & 2001 S/T trucks so they may not work back too far. But I know that one of those switches works back to 96 (and maybe 95).
Thank you for using Fixya and this should take you about 5 min to replace. Good luck
Mar 29, 2010 | 1996 Chevrolet Blazer
I have a Husqvarna 445 chain saw and it does not get enough oil to the bar and chain. I have to stop saw after about 10 minutes of cutting because it freezes the chain so I remove bar and chain clean out...
Your Manual nor IPL mention an oiler adjustment..
445 IPL (may not be your saw)
Is this the original bar? A longer bar requires more oil and your saw is not equipped to supply it.
http://weborder.husqvarna.com/order_static/doc/USA/2007/I07000/I0701086.pdf
Detail B (Clutch/Drum/Oiler)
We are seeing many of these does not oil/oils to much problems with these no adjustment models. I recommend you contact Husqvarna, there may be an unannounced recall/repair. If they aren't willing to help you consider contacting your Atourney General and the BBB.
Contact Husqvarna here:
http://www.husqvarna.com/us/homeowner/support/customer-support/
It has an outboard clutch, the oil pump is behind it. If you attempt a repair this will be helpful.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed.
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of starter cord or nylon rope be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I’ve ever removed had a left handed thread (tighten it to loosen it).
    Let us know how it worked for you.
Source for Manual and IPL:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Nov 24, 2009 | Husqvarna Chain Saw 20" Bar
Should kick back bar stop chain when forward or back?
I think stop is forward, being designed to stop the chain if your hand slips off the handle.
--W/D--
Aug 06, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Husqvarna 359 EPA - no spark. I replaced the spark plug. is there a reset button? What do I check?
check the kill switch button wire see if it broke off that happened to mine an dcaused a no start and if the air filter is not clen it won't run eaither.
Jun 27, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna 55 ignition coil
first thing you need to do is check the wire for any bare spots or if it is melted to some thing inside the saw.if neither is present then the coil will be bad.call husqvarna,the coil should have a lifetime warranty on it.hope this helps,let me know
Apr 16, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
149 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
