Question about Memorex MTT3200 CD Shelf System
MT3200 won't eject (open)
Nothing happens. Worked in the past. Switch set to CD
  • mrdbane Feb 22, 2009
    Should be MTT3200. Sorry
  • Anonymous Mar 19, 2009
    I have the exact same problem. The CD drawer suddenly won't open.
JVC xl-fz258 won't open to eject cd, won't play
The basic problem is that the drive mechanism has failed. The problem with CD ejection can be caused by binding in the tray or a weakened ejection motor
Dec 02, 2012 | JVC XL-FZ258
I just bought a used pontoon boat with a Clarion Marine M235 radio/cd player. The previous owner said there is a cd stuck in the player and won't eject or play. The display says "no cd" but I...
you have to open the unit cover to remove the CD, its probably tried to eject it and its past the point that shows one in the slot which is causing the player to say NO CD , once opened, use great care in moving anything, and keep track of where everything goes,
Jul 04, 2011 | Audio Players & Recorders
Mazda5 6-CD changer stopped working
Hi! I am experiencing the same thing! Have you find any solution? Thank you!
Mar 19, 2010 | 2008 Mazda MAZDA5
Can't eject cd magazine - E-99 error message
I had the same problem. I opened up the unit and found out that there is a plastic gear that moves the loader. When worn the loader can not load tha magazines nor change cd's. I replaced the gear and the cd autochanger worked fine.
Gerald,
Kenya.
Dec 01, 2008 | Kenwood KDC-C717 10-Disc CD Changer
DVD/CD ROM does not open
There should be a small hole on the front panel of the DVD-ROM. Take a paper clip and insert it into the hole and push to open the tray. If the DVD-ROM tray continues to malfunction, you'll need to replace it. DVD-ROMS run anywhere from $25.00 to $75.00.
Oct 01, 2008 | E-Machines emachines (emachinees) CD-ROM...
Cd door will not open
same thing happened to me. turn the system off, unplug it. then back on and after you switch to CD mode (for some reason the CD tray will not eject unless in CD mode), once the system tries to lock on to a specific CD tray, hold the eject button down for 5 seconds. that worked for me. may have been dumb luck but can't hurt.
Aug 27, 2008 | Venturer CD2770 CD Shelf System
Will not play dvd,will not eject dvd
We had the same problem and found we had a disc stuck in there... I stronlgy advise not to open it unless you have some idea on what to do. We opened ours and got the cd/dvd out and luckily it still worked!!!
Jul 24, 2008 | JVC TH-M303 System
Cd tray won't open
their is an tiny hole in the cd tray.. f their is... u insert a pin that cn fit to it you estimate the pin head is... while pushing the eject button
Jun 05, 2008 | Compaq (CDD480172) CD-RW Burner
CD won't eject....
you need cleaning and maintenance on your radio if you want to eject the disk theres a little tiny button on the face you will need a pin push it in and this should eject your disk
Sep 27, 2007 | Kenwood KDC-215S CD Player
Memorex MTT3200 CD Shelf System Logo
76 people viewed this question
Top Memorex Audio Players & Recorders Experts
Greg Cann
Greg Cann
 Grubhead
Grubhead
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
