Question about Little Giant SPS25 Water Removal System with 1/4 HP Sump Pump with Vertical
Water pump removeal from bmw 3 series e46 2001
Ive removed all the bolts but still cant get water pump out.....help ..bob
In the face of the water pump there are two bolt holes (10mm). screw in two 10mm bolts equally and it pushes the pump out as you tighten them in. good luck
Posted on Mar 16, 2009
I'm replacing a water pump on my 1990 BMW 525i and I don't no how to remove that thing where the spark plugs go and the rotor 2nd I'm also need to remove the timing belt cover can I get the 3rd bolt out...
STOP what you are doing before you damage something!! Whatever you are trying to remove is not the water pump. Neither the sparkplugs nor the "timing belt" cover needs to come off. Remove the fan belt. Remove the fan (the nut is LH thread- means it turns left to tighten and right to loosen). You will need a large wrench (32mm) availible at sears.The water pump is directly behind the fan and is held in by 4 10mm bolts.
Aug 17, 2014 | 1990 BMW 525i
Hello. ive tried taking the water pump off my car as it is broken but i cant remove it. ive removed the 3 5mm bolts and the 6mm bolt holding it in place but still cant remove it. please could you tell me...
Often there is a paper gaskit and sometimes a jointing compound is applied which acts like a glue.
It has presumably been there for years and the heat and jointing compound makes it stick. Get a chunky lump of wood, hold this on the pump and hit the wood with a heavy hammer. The wood will prevent any damage to the casing and the blow will shock it off.
You will need a new paper gaskit when putting back on. Let me know if that does the trick!
Dec 17, 2010 | Plumbing
Im trying to remove the water pump from my bmw 316i 1996 but i cant get the fan off, hav removed the allan key bolts for the outer part of the fan but cant get the centre piece off to gain access to the...
To get the viscous clutch of the water pump you first need to remove the belt pulley and remove the water pump. Then put the impeller of the water pump in a vice and using a 32 spanner screw the viscous clutch off. Note that the bolt on the viscous clutch is of left hand thread so you have to unscrew the opposite way to a normal bolt.
Sep 09, 2010 | BMW 318 Cars & Trucks
What must be removed to replace the water pump on a 1998 bmw 528i?
Not much really. I did my son's on the road in 20 degree weather. Remove the fan nut 1.250" wrench...left handed thread with the special tool. Remove fan, and shroud at the same time. Remove belly pan so you can drain the radiator. 16mm socket and 1/2 socket wrench to move the idler pulley tensioner. You move it not remove it. You move it enough to release serpentine tension. Remove belt. and 4 bolts holding the water pump pulley. Now the water pump is exposed. remove the bolts or nuts holding it in. go get some 6mm x 30mm hex bolts and use them to pry out evenly the water pump. That's it. reassemble, don't forget the o-ring.
Jun 12, 2010 | 1998 BMW 5 Series
How to replace a water pump on a 1995 bmw 318is
  1. Disconnect the negative battery cable. Drain the cooling system.
  2. Remove the distributor cap and rotor. Remove the rotor adapter, the dust shield and the distributor housing.
  3. Remove the fan. The fan must be held stationary with tool 11 5 030 or some sort of flat blade cut to fit over the hub and drilled to fit over 2 of the studs on the front of the pulley. Remove the fan coupling nut; left hand thread-turn clockwise to remove.
  4. Remove the belt and pulley.
  5. Remove the rubber guard and distributor and or upper timing belt cover.
  6. Compress the timing tensioner spring and clamp pin with the proper tool.
Observe the installed position of the tensioner spring pin on the water pump housing for reinstallation purposes.
  1. Remove the water hoses, remove the 3 water pump bolts and remove the pump.
To install:
  1. Clean the gasket surfaces and use a new gasket.
  2. Install the water pump in position. Note the position of the tensioner spring pin. Torque M8 bolts to 16-17 ft. lbs. (20-24 Nm) and M6 bolts to 6-7 ft. lbs. (8-10 Nm). Connect the hoses.
  3. Release the tensioner from the holding pin. Install the upper timing cover. Install the pulley and tighten the bolts to 6-7 ft. lbs. (8-10 Nm). Install the belt and tighten.
  4. Install the fan, distributor housing and dust shield. Tighten the rotor adapter to 39-47 ft. lbs. (55-65 Nm). Install the rotor, O-ring and cap.
  5. Add coolant and bleed
Dec 30, 2009 | BMW 318 Cars & Trucks
Where is the thurmostat on a BMW318I 2003 series thanks
Your Thermo in in the front of the engine located near the Water Pump! You will have to remove the Belts to access it... There are only (2) bolts holding it in, It should be an 8mm or 10mm Bolt. Please make sure that you have new seals when you replace the thermo, don't re-use the old one's they may began to leak!
Hope this help!
VADER!
Sep 16, 2009 | 2003 BMW 3 Series
How to remove water pump from bmw 318 1995. I have all the bolts off and it still won't come off
Tap it lightly with a soft faced mallet to break the seal that it shares with the engine. If this doesn't work, use and inspection mirror to see if you've missed a bolt along the bottom that you could not see.
Jul 06, 2009 | 1995 BMW 3 Series
Removing water pump
remove the radiator to have better access.
remove all the belts
now here is the hard part you need to make your own tool or buy the bmw tool to hold the fan belt pulley by the 10mm bolts some how there are many tools that you can use for this just be creative sometime weding a bolt or a big screwdriver does the job too in between the pulleys than loosen the 32mm nut which you can get that wrench at a bicycle shop for a few buck unless you have a bench grinder and can grind a 32mm down to half its thickness or buy the bmw fan pulley wrench and holder there expensive than just remove the water pump. Sometimes they will not come out very easy just to let you know the times I've changed them in my car or others I have had to beat on them with a Hammer to break them off they seize up in there pretty darn good and once you break them you have to continue till its out I recomend any water pump that has a metal impellar or you might end up being stuck doing this job again in the next 6 months make sure the part is German trust me its worth it. Good luck
Jun 26, 2009 | 1994 BMW 3 Series
Need to replace the water pump for a 1995 bmw 318 series
you need a manual you have two types of 1.8 engines .one type you got to remove timing cover. the other 1.8 engine you got to press it out by using 2 bolts.your fan has left hand screws. so you need a manual it make you job easier.
Apr 12, 2009 | 1996 BMW 318
Little Giant SPS25 Water Removal System with 1/4 HP Sump Pump with Vertical Logo
294 people viewed this question
Top Little Giant Electrical Supplies Experts
 Kenneth
Kenneth
Mike
ken skalski
Are you a Little Giant Electrical Supply Expert? Answer questions, earn points and help others
