Question about Maytag Atlantis MAV6000 Top Load Washer
The moter stops when my maytag washer changes cycles
The motor is hot to touch at this point. The model is mav4057aww I think that the belt needs adjusting.
    Problem Solver:
  • 20 Answers
Motor is most likeley bad no adjustment on belt i change motor on this make 3 .4 times a week
Posted on Feb 23, 2009
How do I check the solenoid for the agitate/spin cycle?
This is a known problem with the motor, not the solenoid!!! You may have to replace the motor. A way to check is when it stops, unplug the power cord and touch the motor side frame. If the motor is hot that's your problem. Be sure to unplug the power plug to the motor and look inside the connector for a burnt spot. You might just need to replace the connector.
Jan 21, 2014 | Maytag Ensignia MAV4757AWW Top Load Washer
What is blck powder under the motor of belt drive Maytag washer MAV4057AWW
The powder is belt wear. Not to worry though, they last a long time. There is always some wear on all belts as they slide into the channel on the pulley.
Jul 22, 2013 | Maytag Atlantis MAV7551 Top Load Washer
How to replace belt on maytag washer mav6451aww
not sure on model but if its like any other washer look to see where the belt runs around should run around motor and a big wheel looking thing that joins to tub on the moter there should be three nuts and bolts 2 to keep it aginst bulk of washer an 1 that should be able to ajust losen this one move the motor so there is enough room to put new belt on make sure that the belt goes in the runners of the motor and drum part use a large screw driver to lever the motor so belt goes tight and still with the tension on belt fasten the nut up harder to describe than actually do hope this helps ivan uk
Aug 25, 2012 | Maytag Washing Machines
Maytag Performa, Noisey spin cycle, now does not work
the belt may be old and stretched/slipping...if it is stretched and slipping it will cause the squealing .............otherwise, check the pulley for the belt/motor to see if it is okay and the motor itself copuld be worn out if the belt looks ok............be careful, you can get zapped if you touch a wire and also if the motor is burned up it can cause a fire so watch carefully and you should be able to see which of these possibilities are the problem..............
Feb 13, 2010 | Maytag PAV2300 Top Load Washer
How to adjust new belt on maytag washing
sounds like you have a bad transmission. can you lift the top up so you can see what it is doing when it is trying to spin. does it adgetate and spin at the same time? If yes you have a bad transmission. also if you get 2 people one looking inside of the drum and the other turning the big pulley in one direction it should turn the whole drum in the other the agetator should go back and forth. Tell me what happens thanks.
Jun 10, 2009 | Maytag MAV4755A Top Load Washer
I have a Whirlpool Washer Model LXR6232EQ0. Yesterday something happened after it drained during the rinse cycle. It wouldn't spin. It makes a noise like the moter is trying to spin but there is a slight...
I have a Whirlpool Washer Model LXR6232EQ0. Yesterday something happened after it drained during the rinse cycle. It wouldn't spin. It makes a noise like the moter is trying to spin but there is a slight tinkle once in a while. Could it be the motor coupling or do you think it is the clutch. The agitator doesn't spin at all. does it have a belt?
Mar 17, 2009 | Whirlpool Washing Machines
Notmstarting or stopping possible cycling issue
overheating the moter bad panal replace main controller board ok thx for using fix ya .
Feb 04, 2008 | Dishwashers
"howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Jul 25, 2006 | Maytag SAV5701A Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
102 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
