Question about Lexmark X642e All-In-One Laser Printer
Cant find counter on my lexmark x642e can any one help, I have no manules .thanks
  • DDPTech May 11, 2010
    Counter for what? Maintenance counter?
    If so, go to the configuration menu to see that, or reset it.
  • 3 Answers
Maintenence counter is in Configuration Mode.
Power on the printer while holding down the 2 & 6 buttons. Continue holding buttons for 20 seconds. You will find the counter in Maintenence counter and can reset it there.
Posted on Dec 09, 2009
Lexmark x642e error message 954.95
Seems you have a bad interface card.Try replacing it.
Nov 05, 2011 | Lexmark X642e All-In-One Laser Printer
I WORKING ON A LEXMARK X642E WHICH CAN NOT SEND OR RECIEVE FAXES. WHEN TRY TO GO INTO FAX SETUP MENU IT SAY MODEM FIALED TO INITIALIZE!!
It possible that this is a bad modem, try turning off printer and unplug fax. If you are getting same error message, you need to get a replacement of the modem card.
For further assistance please contact Lexmark Technical Support.
Jun 29, 2011 | Lexmark X642e All-In-One Laser Printer
I installed a maintenance kit (fuser, charge roller, transfer roller & pickup rollers) in my Lexmark x642e and I'm still getting light horizontal lines approx. every inch or so thru the page
Have you tried a different cartridge? Was there much spilled toner inside the printer? If you go into menus, and then help menu you can print a print defect guide that you can line up on your print and it will tell you exactly which part is causing the issue.
Mar 06, 2011 | Lexmark X642e All-In-One Laser Printer
Hello, I got an Lexmark X642e with 900.80 error (when the ADF scanner is connected). When scanner is not connected, the printer is accessible via network and can print w/o any problem. Firmware is...
A 900.80 error indicates a problem with the current print job or with a part within the scanner unit of the printer. Please click on the link below to see instructions on how to go about the procedure.
http://bit.ly/qxvmNN
For further assistance, please call Lexmark Technical Support.
Jan 05, 2011 | Lexmark X642e All-In-One Laser Printer
HOW TO RESET LEXMARK X642E FUSER KIT COUNTER
Hit the menu button or the Key Button
Go into the configuration menu
Touch the arrow that says "Reset Maintenance Counter"
Select the Yes button. as you can not manually change the page count number.
It will reset the counter for you.
Oct 15, 2010 | Lexmark X642e MFP Laser Printer
Rear door paper jam
Here are some articles on rear door paper jam on Lexmark X646e printer. Just click on these links: http://bit.ly/blkK1m ("202 Paper Jam" Message on a Lexmark X642e, X642e or X644e Multifunction Printer) and this link: http://bit.ly/awNDER (A 202.xx (x = any number) Paper Jam Message Is Appearing on a Lexmark X64x Series Printer). These are some guidelines on how to resolve the rear door paper jam on your printer. If you need more assistance, don't hesitate to contact Lexmark Technical Support. Thanks.
Jul 22, 2010 | Lexmark X646e All-In-One Laser Printer
How to install Lexmark X642e printer
Read the manual and follow the instruction provided by your Printer Lexmark.
Just read it.
Nov 23, 2009 | Lexmark X642e All-In-One Laser Printer
Lexmak x642e
Have you powercycled the printer? Is the printer showing ready, currently?
Mar 09, 2009 | Lexmark X642e All-In-One Laser Printer
Lexmark x642e MPF Reset maintenance counter
Power printer off. When printer is powered off, hold down the check button and the right arrow button and hold these down while powering printer back on. Hold the buttons down for 10-20sec....
When printer is finished you are at the config menu. Hit down once, and you will see reset maint counter. Hit menu twice... and you will see resetting...
Then hit back twice to get to the main menu and use your up/down arrows until you see exit config menu. Hit enter and it will reboot printer back to the regular menu.
Feb 02, 2009 | Lexmark X642e All-In-One Laser Printer
Hi~
You can reset the maintenance count by going to the Configuration Menu.
Step 1: Turn off your X64x printer
Step 2: Hold the 2 and 6 buttons while the printer is off
Step 3: Turn on the printer but don't release the buttons yet. Keep holding those buttons for about 10 secs
Step 4: On your Operator Panel, you should see "Configuration Menu"
Step 5: Scroll down and look for "Reset Maint Count" and select it.
Step 6: Exit Config Menu and powercycle your printer (turn it off then back on)
Hope this is helpful... =)
<<ichtuscheeky>>
Jan 30, 2009 | Lexmark X642e All-In-One Laser Printer
Lexmark X642e All-In-One Laser Printer Logo
388 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
