Question about Leisure HOMEPRIDE Electric Fireplace Heater w/ Remote
Gas fireplace will not stay lit
Marco gas fireplace. After following startup instructions flame goes out when releasing the purge button.
There is a probe that is in the one of the flame... This once heated builds up enough pressure do to the heat to keep the shut/off valve open... (reason, if the flame went out the gas would continue to flow) this "thermocouple is replaceable !! contact me at homeprohandyman@verizon.net
Posted on Feb 23, 2009
Lighting the pilot, starting the fireplace
Turn on the gas, hold the pilot flame button down and light the pilot flame, continue to hold the button for at least three min's, release the button pilot should stay lighted.
Jan 06, 2017 | Majestic Heating & Cooling
Oven lights but then flame goes out as soon as I release the knob
The flame sensor seems to be bad.
When I light my pilot light, it stays on till I release the button ...
askville.amazon.com > Home > Home Improvement
Mar 18, 2008 - Similar Questions: light pilot stays till release button suggestions ... If you have held it for a long time and it still won't stay lit, then your thermocouple is bad.... the gas valve doesn't think a flame is burning the gas coming out of the pilot ... less likely but somewhat common is the gasvalve... if the knob you are ...
Troubleshooting Gas Range and Oven Problems ' Back ...
blog.etundra.com > Tundra's Tech Talk
Dec 15, 2015 | Fisher Paykel Fisher & Paykel 24-in...
Majestic gas fireplace mmodel majestic fireplace 36CDVXTRN will not stay lite after 20 minutes.
If you are able to , open the burner box , the igniter has a thermocouple ( might look like a thick wire that would be in the flame if it were on). If it gets corroded or junked up it will not register the flames presence and will shut off the gas). Take an emory cloth and polish it. Hope it helps.
Feb 05, 2014 | Heating & Cooling
Pilot light wont stay lit on gas logs
If the pilot lite comes on, but will not stay on after it has had enough time to heat the thermocouple, you got a bad or the wrong thermocouple. It does take some time to heat that thermocouple.
Nov 26, 2013 | Woodland Direct CD Vent Free Gas Log Set...
My fireplace wont stay lit with the glass on the min i take the glass off it will stay lit i have a good vent and it is propain could it be that there ant enough gas presure it is a heat n glo 6000 the...
The reason this is happening is that the overload switch, which is part of the safety features has gone bad. That's why the burner will only light with the glass off. The orange color of the flame from the pilot flame is normal for propane.
Unfortunately, this is not a DIY fix. If you can find a qualified service technician, that's the best way to go. As, Heat-n-Glow fireplaces are a basic, builder box line. And as such, have some quirks that other, more expensive gas fireplaces don't have.
Hope this helps solve your problem.
Feb 18, 2011 | Heating & Cooling
Pilot don't stay lit after the gas control knob is release.
The thermocouple is bad and you will have to replace it...
The thermocouple is the thing that sticks up in the flame to sense that the flame is on... if it goes bad the pilot flame will not stay lit when you release the button...
heatman101
Dec 05, 2010 | Williams 3501922 (NG) Gas Compact Heater
I HAVE A DESA LP VENTLESS FIREPLACE AND THE PILOT WILL NOT STAY LIT
the heater makes use of a millivolt generator which generates a small dc voltage (500-750mv) that is applied to the pilot valve of your main gas valve. when you light your pilot, the flame bathes the generator with a flame. after a delay you release the pilot button. if the generator is working, the pilot valve will stay lit. if the generator is not working the flame will go out as soon as you release the pilot button. change the generator.
Oct 13, 2009 | Desa International Heating & Cooling
Gas fireplace pilot flame won't stay lit.
Hi , you can try and pull the panel on the bottom of fireplace out and check the adapter in fireplace. Sometimes they go bad. When you open in also check to see if there is an adapter plugged in and a option to use the battery operated function. If this goes bad the pilot will not stay lit.
Dec 27, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Marco gas fireplace
Turn the knob on the gas valve to pilot, push in and hold. You can push the red button to light the flame, but I always use a flame lighter of some sort, just because its faster and the spar-ker may not be working. Anyway, push the button in, and hold it after the pilot flame is on for a minute or so then let up on the button. If it stays on turn the gas knob to on and that's it.
Dec 15, 2007 | Heating & Cooling
Pilot light will not stay lit
is it full of dust my hot water used to do the same till i blew the dust and fluff out
Nov 18, 2007 | Heating & Cooling
Heating & Cooling Logo
848 people viewed this question
Top Leisure Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Steve
Are you a Leisure Heating and Cooling Expert? Answer questions, earn points and help others
