Question about Dishwashers
When i turn my Viking dishwasher on the motor starts to run but no water comes out. It was humming along for several hours before i realized that nothing was really happening. I turned it of and then tried again but the same thing happened. It sound like a motor and/or pump working but no water enters the chamber. Thanks, Jonathan
  • 3 more comments
  • jskow Feb 22, 2009
    how do you check if the ventilators are clear? The drain is clean but other than that there doesn't seem to be anywhere else where something could be blocked? Thanks- Jonathan
    I filled the bottom with water. It drained but it doesn't seem like it sprayed. i
    This was a well thought out response. a bit technical for my comfort level but much better than "Turn it off and call a repair person". Thanks
  • Alex Keen May 11, 2010
    This sounds like you have a air in the pipes, the best bet is to disconnect one of the pipes and blow through it untill water comes out like a stream, this what you will know there is no air left in this.
    Disconnect the pipe from the pump.
    Hope this helps
    Alex
    Scholar:
  • 124 Answers
It sounds like the Water Supply Solenoid is bad. I would change that and let all of us know what happens.
Thank you for using Fix Ya!
Don't forget to rate the overall satisfaction of this solution.
Posted on Feb 22, 2009
    President:
  • 2,976 Answers
There is a small filter at the pump, where the water enters. Shut off the water supply, remove the supply hose and clean the filter with a toothbrush or just by rinsing backwards. Hard water deposits clog the filters quite easily. Do not run the unit without the filter. It will damage the pump.
    Scholar:
  • 165 Answers
Have a look to make sure something has not fallen into the pump assembly, sometimes a hard piece ( like a pit ) or small utensil can fall into the pump and make a grinding style of a noise.
This is often the fill valve. You can test the fill valve coil for continuity with a ohm meter, no needle movement = bad fill valve. You can also test the fill valve for 120 volts at the fill valve with a volt meter, power there and no fill = bad fill valve. No 120 volts there, you will have to trace power back to find the trouble maker. Test things like the float and float switch, wires and timer. Fill valves are very bad for working once or twice and then quitting, if your dishwasher fills the first and second fill cycles and then no more water through the rest of the cycle, replace the fill valve. You will need to remove the access panels to get at the fill valve. Dishwasher fill valves also have a screen built into the valve entrance, this can also get all clogged up and need to be cleaned.
  • 1,031 Answers
Check the water inlet valve for clogging
  • 3 more comments
  • Starnley Johnwells
    Starnley Johnwells Feb 22, 2009
    anotherway is to remove the water valve, leaving the electrials plugged up,
    turn on the unit and see if water comes out of the valve (use a cup or
    towels to catch any water, of course) and see if youll get water If you don't get water then the valve may be faulty
    also checked the float valve and see if it's not stuck up.
    Water Valve - The dishwasher uses a single solenoid water inlet valve to
    allow water to enter into the tub when it calls for water. If the
    valve has become clogged you will experience this symptom. Check to
    make sure you have water getting to the valve and that the supply from
    the house is not turned off. Check for any loose or bad connections to
    the water valve. When you start a cycle the valve should read 120
    Volts AC. If it's getting the voltage and not water is not getting in,
    replace the valve. If its not getting voltage you may either have a
    bad timer or the float is stuck
    dish washer valve
    The Float Switch - This is a safety built in so that your dishwasher doesn't overflow. As the water level inside the dishwasher rises, so does
    the float. When it reaches a certain point, it breaks the power
    getting to the water valve. It is possible to have excess soap or
    dishes or whatever the case, cause the float to be stuck in the up
    position. These are located in the front of the dishwasher on either
    the right side or left side, usually covered with a cap. The switch is
    directly underneath the float. You will have to remove the kick panel
    to access the switch. The switch is an open or closed switch. When
    the float is up, the switch is open and you have not power to the
    valve. When the float is down, the switch should be closed and power
    should be getting to the water valve.
    float switch
    • Unjam the motor if jammed
    • Unjam the pump if jammed
    • Test the motor
    • Test the motor start relay
    • Check the drive belt
    President:
  • 2,559 Answers
Either the fill switch(Float switch) is dirty and sticking,or bad
Or the water supply solenoid is bad.
You can test everything else by manually filling the bottom of the dishwasher with water and running it.(If it sprays and drains,Etc.. then all else works)
  • Randy Hough
    Randy Hough Feb 22, 2009
    Check the drain,It is more than likely clogged.
    Sergeant:
  • 326 Answers
Either the ventilations are getting blocked so the pump should be checked is it fully cleaned and clear/or the motor windings are gone faulty so the motor is necessary to replace.do not keep it on till it get repaired to avoid further damage.
Hobart dishwasher wont fill and motor hums
Hi SubaruB4
it may be the electric valve where the water comes in if it doesn't open when switched on water wont enter
Dec 26, 2017 | Hobart Dishwashers
Water not coming into dishwasher, motor keep running
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble
No Water entering Dishwasher
heatman101
Jan 06, 2011 | Viking 24 in. Professional Series VUD141...
Hi - my Viking dishwasher has developed a problem where the pump runs continuously, whether the power switch is ON or OFF. After the power is turned ON, the troubleshooting guide indicates that there is...
if you open the kick plate, you'll see the pan below the motor and check for leaks. The leaks will trigger the sensor to pump water out. Once you dry out the pan, the pump motor will stop and you should be able to reset the program.
Oct 15, 2010 | Viking DFUD042 Built-in Dishwasher
No water
Check the incoming water to the dishwasher. If the filter is clogged clean it and re fix. Strainer is located on the machine inlet junction where the hose is fitted.
The humming sound is due to motor running without water. When you rectify the inlet flow fault, pour additional water manually into the wash chamber and run the cycle. This to remove trapped air in the pump due to dry run.
May 28, 2010 | Caloric 24 in. CDU300C Built-in Dishwasher
When I start the dishwasher it seems like the motor hums,water comes on but then it stops. When I open the door the control panel is flashing pots and pans and heavy when I had selected normal for the...
Pl refer user manual. In general flashing light may mean : no water flow, salt chamber empty, door not closed etc. It all depends on the error code message designed.assigned by the manufacturer.
Apr 30, 2010 | Viking DFUD142D Built-in Dishwasher
Dishwasher just hums, faintly, when I turn it on.
motor is locked up.. if you let it hum faintly for a couple min it will cut out most likely.. thats the thermal trip built into the motor.. the motor assm needs to be replaced..
Apr 10, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
Dishwasher starts to fill then just hums
Sounds like a motor problem. Behind the chopper is an access to the impeller, try turning the impeller or the chopper blade and see if the motor will rotate. If it doesn't, then something is stuck preventing the motor from running.
Mar 07, 2009 | Dishwashers
Frigidaire dishwasher does not clean
the start switch in the motor is probably bad,it could also be the motor relay.if you can get to the motor run the unit and while it hums try to turn the motor.it also could be something is stuck in the motor let me know.
Aug 13, 2007 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher fill with water then just hums
the hum is probably the main pump powered up but not turning. the pump is an induction motor and a usual fault is the motor capacitor. try to access it, find the value of the capacitor and replace. it is a cheap part
Apr 02, 2007 | Kenmore 24 in. 16039 Built-in Dishwasher
Dishwashers Logo
44 people viewed this question
Top Dishwashers Experts
