Question about HP OfficeJet D135 All-In-One InkJet Printer
The electricl connection (printer end)
Need to know a way to take off bottom of printer to check out the
power source from the computer. There seems to be something
loose. I have tried other outlets to be sure it is not an outlet. It is
definately in the machine but we can't get at it. My husband seems
to think there is a loose wire and he can fix that easily but we don't
want to break parts to get at it.
Do you have a solution --how to get the bottom off near the
power source?
    New Friend:
  • 52 Answers
You probly can't take the bottom off an HP printer. All the HP printers use the base of the printer to assemble the printer on. You can take the covers off, but I have never removed the covers on you type of print, so you will just have to start trying to pop the off. Most HP prints have a few screws, and the rest just pop off.
Does this printer take 120 volts in or does it have a power converter between the wall and the printer? If it is 120, does the power cable unplug from printer or is it made to the printer?
I have seen power cable connectors go bad and become loose and your power will come and go.
Posted on Mar 05, 2009
I know I need a 5 volt dc power adapter but I don't know the size of the end piece that connects to the speaker can you help me thank you.
Jean, take the speaker with you to the source or electronics shop and they will match you up with proper universal adapter.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
power adapters
Amazon com Universal 5V 1 2A AC Power Supply Electronics
5V Power Adapter eBay
Feb 27, 2016 | Audio Players & Recorders
I have a lead from my tv usb, to the samsung tablet, but i dont know how to get it to connect
Step 1 Connect one end of an HDMI cable to the Samsung Galaxy Tab HDTV adapter.
Step 2 Connect the other end of the HDMI cable to a free HDMI port on your television.
Step 3 Connect your Galaxy Tab's travel charger to the other end of the HDTV adapter. Plug the travel charger into a power source, such as an electrical outlet or a computer's USB port.
Step 4 Plug the HDTV adapter connector into the Galaxy Tab's "Power/Accessory Interface" port. The port is on the bottom of the device.
Step 5 Turn on the TV. If your TV has multiple HDMI ports, use the remote control to switch to the correct one. Press the "Source" or "Input" button on the remote to switch ports. When you're using the correct port, the TV will instantly display whatever is on the Tab's screen.
Feb 05, 2015 | Samsung Galaxy Tab 2 7in. WiFi Tablet, 8GB
Cant figure out how to hook them up
Two audio input cables are supplied with the speakers. If your computer has a stereo mini jack, use the cable with a stereo mini plug. Otherwise, use the cable with RCA plugs on both ends. Match the colors on the connectors to the colors on the jacks, red to red and white to white.
The speaker cable is already attached at one end to the accessory speaker. Plug the other end into the TO ACCESSORY SPEAKER jack on the powered speaker.
1. Connect one end of the audio input cable to AUDIO INPUTS A. 2. Connect the other end to your computer's AUDIO OUTPUT jack. We recommend using LINE OUT if your computer sound card offers more than one option. 3. To connect a separate CD-ROM, or another source, repeat steps 1 and 2 using AUDIO INPUTS B.
You must connect the AC power pack to operate the speakers. 1. Plug its cable end into the power jack on the powered speaker. 2. Plug the power pack blades into the wall outlet. 3. Turn on your computer sound source or external sound source.
Jun 27, 2011 | Bose MediaMate Computer Speakers
I have a 1995 cheverolet silverado pick up and my brake light will not come on bulb, is good, fuse is good change the brake light switch an it still will not come on
there is a known problem with the circuit board the bulbs sit in ..most parts stores sell them in the "help" section or "dorman products" section if you want to check it properly you will need a test light and a friend...first thing you must attach the test light end to a good ground source put the other end in to the electricle connector one wire at a time of the brake switch push the pedal if it illuminates on a wire only when the pedal is pushed it is getting powered up and functioning next go to the back of the truck and do the same with the tail light ..use your friend to push the pedal and test for power present in a wire only when the pedal is pushed if that is there then the power is getting to the tailight next you must check for ground so put the test light end on power you might need a piece of wire to extend to the back carefull probe the plug if the test light illuminates there is a good ground there and you need to change the board
Nov 21, 2010 | 1983 Chevrolet Silverado
Need to know how to install ink cartridges
Perhaps the Lexmark X7350 User's Guide will be able to help you. Just click on the link to download: Scroll to Maintaining the printer, Page 70, for the instructions on how to install the ink cartridges.
In some cases, the ink cartridge carrier won't position itself in the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the white tape in the middle inside the printer. The other end of it is connected to the carrier. Gently slide the carrier to the center. Load the cartridges. Close the cover. Plug the printer back to power source.
Thank you for choosing Lexmark.
Aug 27, 2010 | Lexmark X7350 All-In-One InkJet Printer
My dell computer connection seems bad. The power
i think u need a new power cord , y not taking it to a IT store
Apr 15, 2010 | Dell Inspiron 6000 Notebook
Printer doesn't turn on
Check the printer cover and close it properly before turning it on you may reinsert the cartridges as well
Sep 07, 2009 | HP Officejet 6310 All-In-One InkJet...
Printer will not turn on
Check power source. Also, if you have a voltmeter, check the power going into the printer. If all is good there, unplug the printer from the computer and try to power it on. If it powers up while not connected to the computer, this could indicate a problem with the USB cable or the port on the computer. Try another cable or available port (if you have one). If the printer is connected via an external USB hub, try connecting it directly to the computer instead. If none of these work, post back here & I'll assist you further.
May 29, 2009 | HP Photosmart C6180 All-In-One InkJet...
Need help to hook up IBM color flatbed scanner
Attach one end of a parallel port cable to the parallel (printer) port on your computer and the other end of the cable to the computer port on the rear of the scanner. If you have a printer connected to your computer, you must disconnect the printer cable from the computer before connecting the scanner cable.
If you have trouble attaching a cable connector to a port, be sure that you are connecting the correct end of the cable to the correct port.
IF. . . you want to use a printer WITH your scanner, attach one end of the printer cable to the printer port on the rear of the scanner and attach the other end of the cable to the printer.
Plug in power cord and then power up PC.
Power on scanner. Install drivers. Restart PC to activate EZ Station buttons.
Oct 11, 2008 | IBM Color Scanner Flatbed Scanner
Aspire 9301 awsmi
Shut down the computer and turn off the printer.
Disconnect the printer cable from either the printer or computer.
Unplug the printer's power cord from its power source.
Restart the computer and log onto a desktop.
Shut down the computer again.
Reconnect the computer to the printer.
Plug the printer power cord back in and turn it on.
Once the printer cycles through its power on self check, power the computer back up and log on to a desktop.
The icon should be gone now if you have followed these steps completely and in this order.
Please don't forget to rate and thanks for using FixYa.
Sep 07, 2008 | Acer Aspire 5050-3242 Notebook
HP OfficeJet D135 All-In-One InkJet Printer Logo
Ben Johnson
